12-22-2016, 03:39 PM | #1 |
467
Rep 818
Turning Rotors
For a track car, it seems like rotors end up cracking way before they get too thin. I came across this article on the ECS site that talks about turning the rotors to remove the surface cracks/crazing:
http://ebcbrakes.com/articles/surfac...n-brake-discs/ Seems like it would be a good way to get more life out of your rotors. Anyone ever tried this? |
12-22-2016, 03:51 PM | #2 |
1478
Rep 2,672
It makes sense but you may have trouble finding a shop to turn slotted or drilled rotors as the cutting bit can get stuck on the slots and holes. I have turned regular flat rotors that were pad deposited before and they were perfect after turning, hadn't really thought of it for surface cracks though, nice.
On a related note, I have been using PFC08 pads which wear very flat (no visible grooves) but get super hot and cause a good amount of cracking as a result. I wanted to switch to more aggressive pads anyway and am trying Pagid Blacks next which claim to eat into the rotors and cause grooving (hoping they eat away the cracks). Would be interesting to use a combo of pads like this to maximize rotor life but I'll admit it's more of a theory and fun experiment than anything else.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
12-22-2016, 03:55 PM | #3 | |
467
Rep 818
12-22-2016, 05:29 PM | #5 |
467
Rep 818
Not until my existing rotors are toast. Even then I'm on the fence because it would put me in the B2 class for Bimmer Challenge. I don't really have any issues with brakes other than it takes longer to swap pads so hard to justify the expense.
12-22-2016, 05:34 PM | #6 |
11586
Rep 12,726
Well what are you planning on if you keep oem brakes? Replace with new oem rotors? Slightly used rotors?
I will be replacing the rings on my bbk for the first time in a little bit. It's always talked about how a bbk can save money in the long run... it's now quite clear to me now that this is true- a set of rings is just a few hundred bucks more than a set of pads.
Instagram; @roastbeefmike
12-22-2016, 05:40 PM | #7 | |
467
Rep 818
12-22-2016, 06:07 PM | #9 | |
467
Rep 818
12-22-2016, 06:14 PM | #10 | ||
11586
Rep 12,726
Keep in mind, I say "a day", but when I make it up to Laguna, I do double run groups and every lap but the last lap is a hot lap. Two of those days were at Laguna. I might be putting these rotors through what would be some people's equivalent of 15+ days depending on the track and coordinator (track time and brake demand).
12-22-2016, 11:48 PM | #11 | |
Retired Curmudgeon
2985
Rep 4,047
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
12-23-2016, 12:26 AM | #12 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
25 days on mine using nothing but DS1.11
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
macdude357467.00 |
12-23-2016, 06:50 AM | #13 | ||
185
Rep 936
You'll find me at the track
BMW CCA Club Racing #905 Instagram: scottynotpippen |
macdude357467.00 |
12-23-2016, 08:06 AM | #14 | |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-23-2016, 09:46 AM | #15 | ||
11586
Rep 12,726
12-23-2016, 11:39 AM | #16 |
467
Rep 818
12-23-2016, 04:35 PM | #18 |
2147
Rep 2,527
There isn't really a minimum thickness per se with the AP Racing rotor. What I was told, was that it would crack long before you got to it - but essentially, all the J hook slots would be gone when you were there. There was plenty of depth left in the slots when I decided to replace them.
macdude357467.00 |
12-23-2016, 09:00 PM | #19 | |
1571
Rep 8,076
On my E46 M3, I've ran through 4 sets of pads (1 PF01 and 2 Stoptech SR34s and 1 SR33). My rotors were at 30.8mm (32mm new) but the heat cracks were getting to the point of making the rotors useless. Luckily, the rotors discs are the same size front and rear on the E46 so I just swapped the fronts to the rear.
12-23-2016, 09:40 PM | #20 | ||
11586
Rep 12,726
12-23-2016, 11:19 PM | #21 | |
3221
Rep 6,218
btw pfc08 was eating up my rotors and not providing great braking and feel for me personally. i like rotor friendly aggressive pads like carbotech and gloc pads. but then after a few events you need new pads but rotors last forever. i was looking for pfc rings but apparently they don't make them for our chassis. didn't know stop tech had some. but last sunday at button willow the weather was perfect and my oem brakes felt like bbk!
12-24-2016, 09:24 AM | #22 |
11586
Rep 12,726
only time i don't get a proper cool down lap is at laguna seca. kinda sucks, but they do it this way to maximize run group times. if you see a checkered flag at turn 8, they want you off the track in three more turns... its maybe 1/2 mile of "cooling down" at the downhill portion of the track. what is customary, is guys doing huge circles in the large parking lot area behind the paddock for a cool down. other than that, i'm pretty good about getting everything cooled down before parking the car.
