BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      12-21-2016, 09:49 PM   #1
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Meaty Fitment
Whats up guys, looking to switch out from the stance look to the meaty look.
First question, Im getting some Forgestar SDCs in 19x9.5/11 offsets in the mid 20s and was wondering if I can fit a 275/30 and 305/30 setup with something like a Hankook V12 tire and still be pretty low? or would I really need to run a 265/295 setup? I don't want to have to use spacers and would like to be pretty flush. I am currently running KW Clubsports.
Thanks in advance!
      12-21-2016, 10:30 PM   #2
becausephilchow
175
Drives: 08 E90 M3
Thanks in advance!
I think you'd be fine with a V12 with camber dialed in.
Though, define "pretty-low", everybody has a different opinion.
      12-21-2016, 10:42 PM   #3
dj_dub
IG: @dj_dub
dj_dub's Avatar
1803
Drives: 2010 BMW E90 M3 - SG/FR 6MT
I think it might work but there's a chance of slight rubbing. IMO a 265/295 setup would work better...also, I don't consider 30 series tires to be meaty. I prefer 35 series tires for that meaty look with bigger sidewalls. All my opinion of course as looks are subjective.
Here's my car with Hankook V12s 255/35 & 285/35 on 19x9.5 & 19x11 wheels but I'm using 7.5mm spacers all around to clear my calipers. To me, this is meaty and completely flush. If you aren't gonna spacers, your could get away with a wider setup for sure.
IMG_3282a by dj_dub, on Flickr
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
      12-22-2016, 06:56 AM   #4
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
I would like to have the least amount of tire gap as possible, the set up above me is what I would be looking for. I know Id have to adjust my camber from how it sits now, its like -2 something right now.
      12-22-2016, 06:59 AM   #5
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
That looks awesome man! I think your offsets are lower than mine to start with. By meaty I mean a wider tire, not necessarily taller. I am just ditching the stretched look but figured if I went with a 30 profile I could still go just as low considering the height of the tires. I just don't want to run spacers this go around but at the same time don't want to get stuck with too wide of tires. I think they will fit because everyone says V12 run skinner than most brands.
      12-22-2016, 07:38 AM   #6
CIFUM3
CIFUM3's Avatar
103
Drives: 08 E92 M3
Should have went with a higher offset on the back wheels. I'm on a 305/30 19x11 +33 with stock camber
Performance
ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe
Looks
M colors grill - CF trunk - Sapphire Blue Forgestars F14
      12-22-2016, 08:38 AM   #7
RD1M3
57
Drives: '11 JZB E92 M3
Agree with ^. You should be ok with the 275 fronts, but I'm running 19x11 +25 on 295/30 MPSS and pretty low on KW sleeves and rub on dips. Not sure how much narrower the V12's would be, but I'm guessing a 305 would be tough to fit without more of an offset.
'11 Jerez Black DCT E92 M3 - IND | MPE | KW HAS | Forgestar F14 | Mode Carbon V1 FRP
      12-22-2016, 09:29 AM   #8
last1left
last1left's Avatar
175
Drives: e92 M3
Wow what a nice look, aggressive and phat
      12-22-2016, 09:35 AM   #9
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Do either one of you guys have pictures of your setups? Also what are you running on the fronts? I thought the V12s ran narrow enough to where a 305 in them was the same width as a 295 in other tires.
      12-22-2016, 10:01 AM   #10
dj_dub
IG: @dj_dub
dj_dub's Avatar
1803
Thanks man! ...you are right, my offsets are pretty low to begin with. And I totally understand your feelings on stretch and spacers. I too used to love the stretched look (came from the VW/Audi scene) but love the more meaty look now and didn't want to run spacers with these wheels as well, but I had to clear my calipers...no choice.
Nah I'm good. The offsets on these wheels were calculated to run 295/35 without spacers (no desire to run 305s) before I decided to/got some big ass brake calipers. Unfortuntely they do not clear the calipers and I had to run spacers and step down one size in tire. All good though, still looks nice.
Thanks bro, I appreciate it!
      12-22-2016, 12:40 PM   #11
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Well I guess Im stuck for the moment, I just don't know if the 275/305 will fit and allow me to go as low as I want to.
      12-22-2016, 05:43 PM   #12
jaekeem
BMW Noobie
jaekeem's Avatar
61
Drives: e90 M3 e46 M3 Macan S Model S
I think its a coin toss with a 305 hankook tire. It really comes down to your offset being spot on.
I'm on a beefier tire the michelin pss on the same size wheels you listed at 295 in the rear and 275 in the front. My current alignment is within OEM specs and at my current lowering I have no rubbing in the rear or front.
I don't remember my exact offsets but I got my wheels from eas and went with their recommendations for the m3.
2011 F10 535i | Build Thread | Power Mods & Dynos
      12-23-2016, 08:54 AM   #13
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
That looks great! What are you lowered with? Im on clubsports and want to make sure they will not be getting in the way if i go with the 305.
      12-23-2016, 09:33 AM   #14
CIFUM3
CIFUM3's Avatar
103
Drives: 08 E92 M3
19x10 +25 275/30
19x11 +33 305/30
Performance
Looks
      12-23-2016, 09:57 AM   #15
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
19x10 +25 275/30
19x11 +33 305/30
Awesome, any a$$ shots?
      12-23-2016, 10:21 AM   #16
CIFUM3
CIFUM3's Avatar
103
Drives: 08 E92 M3
19x10 +25 275/30
19x11 +33 305/30
Not at the moment but I'll find some and post them up. Pics don't really do justice to fat tire fitment.
Performance
Looks
      12-23-2016, 10:18 PM   #17
///MPower15
///MPower15's Avatar
501
Drives: 2011 E92 M3
19x10 +25 275/30
19x11 +33 305/30
Looks great? What are your camber specs?
      12-25-2016, 05:05 AM   #18
Ingenio
Ingenio's Avatar
Australia
180
Drives: 2008 Space Grey E92 M3 (6MT)
I'm running 9.5" et18 and 11" et27 with 265/30s and 295/30s respectively. Also lowered on KW HAS.... all good, no rubbing
      12-25-2016, 09:16 AM   #19
j2nicee
j2nicee's Avatar
55
Drives: 2009 E92
Damn!!! What brand of tires?
Ok ok I'm going with the 265/295 set up and will run a small spacer if I have to.
      12-25-2016, 09:57 AM   #20
last1left
last1left's Avatar
175
Drives: e92 M3
So clean!!
      12-25-2016, 09:55 PM   #21
Ingenio
Ingenio's Avatar
Australia
180
Michelin PSS of course!
      12-27-2016, 11:18 PM   #22
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
do you mean 265/35 and 295/35?
m3post
