12-20-2016, 07:40 PM | #1 |
196
Rep 386
Brake question
I am taking the e92 M3 to the track this spring and likely much more after that.
Does anyone have a comparison between a BBK that will fit on 18" wheels vs a BBK that requires 19". For example StopTech ST40 vs StopTech ST60. I'd prefer to stick with 18s because of tire cost and from what I've read only the ST40 will work on stock wheels. I currently have DINAN 19s and I'd like to not run those. I have a set of OEM 219s for track duty and will likely go to an 18" square setup. |
12-20-2016, 07:58 PM | #2 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-20-2016, 09:03 PM | #3 |
11586
Rep 12,726
i don't know about a comparison, but it is a fact that bigger isn't necessarily better when it comes to brakes. you really don't need a huge 380mm rotor and calipers that fill half the barrel of your wheel. sure they look cool, but know they are designed with aesthetics in mind.
other things to think about when exploring bbk's; pad shape availability, ease of pad change, rotor ring replacement cost. most importantly- performance. an added plus is reduction in rotating, unsprung weight. this is the kit i have. it has been a fantastic kit. scroll down to read about it. https://www.essexparts.com/essex-des...p5060355mm-e92
Instagram; @roastbeefmike
12-21-2016, 10:50 AM | #4 |
93
Rep 356
Check out this thread.
BBK - Wheel Fitment Compatibility Database http://www.m3post.com/forums/showthread.php?t=787497 |
12-21-2016, 10:52 AM | #5 |
196
Rep 386
Thanks for the input. After searching and reading quite a bit (no comparisons found). I think I am going stock brakes and pads my first track day and go from there. Although I will flush my fluid with new stuff.
12-21-2016, 10:56 AM | #6 | |
196
Rep 386
Thanks!! |
