12-06-2016, 01:05 PM | #1 |
152
Rep 984
Swift springs installed but no drop
I installed Swift Spec R springs on my 2011 E92 ZCP during Thanksgiving weekend. I love how the springs ride and handle but im really disappointed with the drop or lack there of. I knew it would be very mild and since my car is ZCP would be 10mm less... but the rear did not drop at all! The advertised drop I should've gotten was 15mm front and 8mm rear (25mm/18mm advertised by Swift -10mm) The front did drop by half a finger but the rear is exactly the same as stock. I did make sure the rear springs sat in the rubber perches correctly too so that its not the issue. I've already driven over 100 miles on the springs hoping they would 'settle' even though I read conflicting reports that these springs don't settle or droop over time but the rear of my car is still the same height as stock. Comparison pics below, first is stock ZCP and second is Swift springs... you cant even see a difference and the car doesnt look lowered. Has anyone had this issue with Swift springs not lowering their ZCP M3?
2004E46M36MTCBCinn 'Clubsport'
12-06-2016, 01:22 PM | #2 |
F15 daddymobile
2352
Rep 3,510
I'm not ZCP but mine lowered to no finger gap in the rear to a 1/2-1 finger gap in the front. e90 M3 with EDC here.
also if those pics were taken directly after install give it some time and drive around the block. the suspension settles over the first 500miles, but also if you parking brake is pulled it won't drop if its directly after. drive around the block and re-measure.
12-06-2016, 01:39 PM | #3 | |
152
Rep 984
12-06-2016, 02:27 PM | #4 | |
F15 daddymobile
2352
Rep 3,510
that's odd. and you said everything is seated correctly? Whats the part number on the box/springs? maybe you got the wrong set?
12-06-2016, 02:35 PM | #5 | |
General
63578
Rep 24,716
Too low looks cheap for a road car , and for me your drop looks perfect . I heard only good things from Swift I would love to drop my car with Swift but I'm screwed by the yearly Belgian car inspection . And that really sucks !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
12-06-2016, 02:41 PM | #6 | ||
152
Rep 984
Do you really think they settle with more miles? I read that the Swifts actually dont have any settling process and that they dont droop over time due to the material used. Quote:
///M Power-Belgium63578.00 |
12-06-2016, 02:54 PM | #7 | |
General
63578
Rep 24,716
After he drove 2K miles he saw it a little lower . Here is a car with the "final" drop on Swifts ...( drop looks perfect to me )
12-06-2016, 06:16 PM | #8 | |
F15 daddymobile
2352
Rep 3,510
the cars posted in this EAS thread are all lower than yours http://www.m3post.com/forums/showthread.php?t=790330
12-07-2016, 11:28 AM | #9 |
Supreme Allied Commander
3856
Rep 54,414
Drives: F80 M3
Make sure you torque everything down with the suspension loaded.
12-07-2016, 02:53 PM | #10 | ||
152
Rep 984
Yep final tightening to torque values was done with the suspension loaded, car was backed onto ramps and I torqued down the 4 rear bolts...but regardless i don't see how that would affect the ride height.
12-07-2016, 02:58 PM | #11 | |
General
63578
Rep 24,716
12-08-2016, 01:39 PM | #12 |
152
Rep 984
Thank you my friend. I was curious to see how the Swift look side by side with OEM non-ZCP springs. At least this proves that on the ZCP cars its the springs that are 10mm lower not the rubber springs perches like some have said. Also your friends Swift springs have the same part number sticker as mine did so thats good at least I know my springs are correct.
Still I'm really bothered how my rear is not lowered yet. I'm even considering trying to move the springs around in their perches with my hands. I really dont want to take apart the suspension again since it was such a PITA to install the rear springs!
12-08-2016, 02:48 PM | #13 | |
3856
Rep 54,414
Drives: F80 M3
Make sure you springs are seated in the perches as well. |
12-12-2016, 10:01 AM | #16 | |
152
Rep 984
Yeah the front did drop I mentioned that in my post, my issue is with the rear that did not drop. If you make the same image for the rear compare i doubt there's much difference if at all.
