12-06-2016, 10:27 AM | #1 |
Apex. Clean. Repeat.
66
Rep 109
Thinking spacers, ZCP wheels which spacers do I need to make it flush but no rub
Thinking spacers, ZCP wheels which spacers do I need to make it flush but no rub?
12-06-2016, 10:33 AM | #2 |
HMFIC
372
Rep 522
Drives: 2016 F80 M3
12mm in rear and 15mm front
12-06-2016, 10:41 AM | #3 |
///M Powered for Life
11490
Rep 10,329
12-06-2016, 01:11 PM | #5 |
F15 daddymobile
2350
Rep 3,510
there's a thread in the wheel/tire section dedicated to spacers and what sizes to use on which setups. take a look down there. depends on what tire setup and how lowered you are. most people run 15/12, but that will rub if you up the tire sizes to 255/275.
B8bydesign680.00 |
12-06-2016, 01:51 PM | #6 | |
680
Rep 1,527
Drives: '11 BMW M3
15/12 to be conservative, I eventually went with 18/15 on the stock tires to be a bit more aggressive.
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak |
12-06-2016, 02:26 PM | #7 | |
66
Rep 109
12-06-2016, 02:41 PM | #8 |
680
Rep 1,527
Drives: '11 BMW M3
That's correct, 15mm for the front and 12mm for the rears with factory tire sizes. Are you lowered or planning on lowering?
12-06-2016, 06:56 PM | #10 |
66
Rep 109
12-06-2016, 06:58 PM | #11 |
Stop the hate, get a V8
3850
Rep 8,625
Google "scrub radius" and decide for yourself.
Past: 2011.5 M3 sedan ZCP |
12-06-2016, 07:25 PM | #12 |
748
Rep 4,429
Me pushing the limits!! 20mm rear spacers, lowered on B&G springs 285/30/19. No rubbing!
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
12-06-2016, 07:46 PM | #13 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
459
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
Selling 10 and 15 mm with lugs if ur interested. That's the best set up with zcp wheels
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
12-07-2016, 12:18 AM | #14 |
501
Rep 1,236
12-07-2016, 07:46 AM | #15 | |
748
Rep 4,429
12-07-2016, 07:47 AM | #16 |
F15 daddymobile
2350
Rep 3,510
///MPower15501.00 |
12-07-2016, 08:40 AM | #17 | |
748
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
You can't get quite the same look/fitment on the coupes.
12-09-2016, 05:37 PM | #18 |
54
Rep 404
Drives: E92 M3
how do you widen the rears?
i have a square zcp set up (19x10 all around) and i want to know what spacers i should run to make it flush like that ^ |
12-10-2016, 06:21 AM | #19 |
748
Rep 4,429
They were done by a shop in Cali named either flossin or flossman. Not sure. They were done before I received them. 20mm in the rear will get you flush but depending on your brand and size tire will determine whether or not you may rub. I'm running cont. DW 285/30/19.
12-10-2016, 08:51 PM | #20 | |
54
Rep 404
Drives: E92 M3
i want to run either michelin pss or toyo r8 not sure which yet for the square setup.
i was thinking 245-35-19 w 10mm spacers on the fronts and 285/30/19 w 20mm spacers for the rears. i have airrex that i will be installing too, made the transition from coilovers to air so this should be interesting Quote:
01-22-2017, 05:15 PM | #21 |
24
Rep 414
So what size spacer fits with upsize tires?
01-23-2017, 06:11 PM | #22 |
BimmerPost Supporting Vendor
1427
Rep 2,650
Great information floating around in here. Keep in mind that tire brand, tire size, camber specifications and vehicle ride height can all effect fitment from one car to another. Use other members as a benchmark, but be sure to take into account where your car/setup may be a bit different.
As mentioned, we have also found that 15mm front & 12mm rear are the most popular sizes to use with ZCP wheels and OEM tire sizes. A "flush fitment" is subjective. Some enthusiasts are after an aggressive stanced look, while others may interpret flush entirely different. I do not mean to over complicate the situation, but we are dealing with millimeters here. I always urge enthusiasts make their own informed decision instead of taking forums posts as gospel. Last, if you are running spacers of any width, always be sure to purchase the the appropriate extended hardware for proper installation. - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 01-23-2017 at 06:17 PM.. |
