11-27-2016, 01:19 PM | #1 |
409
Rep 632
Drives: 2011 E90 M3, 2018 F87 M2
Cool Shirt Install
My wife (and sponsor) was kind enough to surprise me with a cool shirt kit a few weeks ago for our anniversary, and I finally got around to installing it. Project was pretty straight forward, and I bought some additional wire and a fuse tap kit from Amazon and some hardware to bolt the tray down from Lowe's
I still have a passenger seat, so the trunk seemed the most logical spot. Don't think it will get much use until later on in the spring out in CA, but back on the east coast it will get a ton of use. Step 1: Removed the plastic tray in the trunk Step 2: Bolted the cooler bracket to the plastic tray Step 3: Installed the plastic tray and the cooler. In retrospect, I think I will move the bracket or rotate the cooler 180 degrees so the coolant lines are not pointed at the battery. The coolant inlet/outlet connectors are very secure, but my design should be more disaster proof. The plastic tray is well set up to catch drips or spills. Step 4: Ran the wiring and installed the on/off switch. Fuse tap was easy enough and I taped and zip-tied up the wiring. Ran the coolant line as well.
11-27-2016, 01:25 PM | #2 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
i have mine mounted the same way. I removed the plastic tray and when with this: http://www.hardmotorsport.com/hard-m...-filler-plate/
lighter and cleaner looking. You will love the cool suit best addition to my car so far.
11-27-2016, 02:35 PM | #3 |
3221
Rep 6,218
Cool. I'm thinking of getting the karting version. Just throw the bag behind the seat.
11-27-2016, 02:49 PM | #4 |
776
Rep 1,718
the bagged version is nice if you dont want to hardwire it or have multiple cars to run with. This is what my father runs. It works really well but the ice does not last as long as the cooler is much more effective than the insulated bag. But either is a great choice.
11-27-2016, 06:02 PM | #5 |
Retired Curmudgeon
2985
Rep 4,047
Cool shirt was the best mod I ever bought for my race car.
Tip: use old margarine or yogurt containers to freeze blocks of ice instead of using cubed ice. The blocks last a lot longer. Just stack them in your cooler and use cube ice to fill the gaps (if any).
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
11-27-2016, 06:30 PM | #6 |
409
Rep 632
That is a great idea. Thanks!
11-27-2016, 06:59 PM | #7 | |
776
Rep 1,718
12-02-2016, 08:07 AM | #8 |
1478
Rep 2,672
Are you thinking 6 qt or 12 qt version? Then I'm also thinking about the best place to plug this in as I use my central 12v plug for my GoPro. If it can work on USB power I have a two USB adaptor I can use.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
12-02-2016, 08:25 AM | #9 | |
409
Rep 632
E Support 12v Car Add-a-circuit Fuse TAP Adapter Mini ATM APM Blade Fuse Holder Pack of 5 https://www.amazon.com/dp/B00SUTYYS2..._9qyqybM5AKG24
///Mobbin1478.00 ThunderMoose745.50 |
