11-24-2016, 05:10 PM | #1 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
Works Bell System lasted about a year and then failed. The switches just failed flat out. And Turnersgroup is a waste of time.
I have moved on to the KMP set up and its plug n play and great customer support. And M Button!! https://www.kmpdrivetrain.com/produc...wheel-m-sport/ Alright so here is what's going on. Cage is going in over the winter and I wanted a removable steering wheel for the car. Problem is DCT. Well this seems to have solved that issue. What is at work here is the Works Bell Paddle kit which I have talked about in another thread (http://www.m3post.com/forums/showthread.php?t=1222905). This kit unfortunately isn't plug in play as the connectors are not the right size. However these are a simple switch just like the OEM so all you do is snip and rewire. Yes this does hack up your button but you only need the side where MDM is. I went a head and bought another set of buttons for pretty cheap as Insurance. On the MDM note. The way I have it done so that it comes automatically on is to bridge the connector on the back, this indicates to the ECU/CAN the the M button is active thus MDM. Next in the line is the Krontec QR with 22 pin connector. Now you don't need the 22 pin connector but I thought I was going to be wiring a lot of buttons through it. They do offer an 8 pin connector which is plenty, you need at least 4 for the paddles, leaves you 2 for a horn and 2 empty. The Button plate is the Raptor Race, they have a Pro version but this suited my needs, made by Summit Technologies out of the U.K. Super easy to work with and came in 2 days. This basically is 8 Buttons that are built into a circuit board. This then talks to a central box that all you desired functions wire into. Here is more of an explanation (http://summit-technologies.myshopify...mmable-version). The lower 4 buttons will control my AIM MXG unit, the 2 right ones will be for my cool shirt system and the diff cooler. The other 2 will be used later for something, still thinking. What is nice about this system is you can make the button momentary or on/off and no running wires or curly cord. So this is still being installed but I will do an update once it is all in and working and a video. Please don't hesitate to ask me about the set up I have done a lot of research.
11-27-2016, 04:10 AM | #2 |
3221
Rep 6,218
@xchosun1x check this setup
11-27-2016, 10:27 AM | #3 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Wow, this is awesome. Thanks for sharing!
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
11-28-2016, 11:59 AM | #5 |
776
Rep 1,718
Yeah the krontec is definitely the best QR on the market. Your can get it without electrical connection or 8 or 24 pins.
Connection is super solid with no play.
11-28-2016, 04:29 PM | #6 |
776
Rep 1,718
Some installed pics. Finishing up wiring.
11-28-2016, 04:30 PM | #7 |
776
Rep 1,718
Installed pics
11-28-2016, 06:02 PM | #8 |
84
Rep 105
I've installed a few without the electrical connection, nice pieces.
-Greg S
2016 NASA TT3 NASA Eastern States Champion |
11-28-2016, 06:50 PM | #9 |
3221
Rep 6,218
your setup looks hard AF! real nice. loving the buttons as well. Are those replacing all your oem buttons (or select ones)?
11-28-2016, 06:51 PM | #10 | |
776
Rep 1,718
They can run anything. That's the beauty.
11-28-2016, 08:19 PM | #11 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
What about the M button?
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
okusa845.50 |
11-28-2016, 08:20 PM | #12 |
776
Rep 1,718
M Button we solved by connecting the contacts on the back of board. This way the M button comes on by default. Really no other way around it that I have found.
11-28-2016, 08:24 PM | #13 |
11586
Rep 12,726
although it is really clean and looks great, what is your goal with this steering wheel? it just seems like a lot of time and money, but maybe because i don't understand the benefit.
better driving positioning? significantly less weight? easier to get in/out? better "feel?"
Instagram; @roastbeefmike
11-28-2016, 08:26 PM | #14 | |
2147
Rep 2,527
11-28-2016, 08:28 PM | #15 | |
776
Rep 1,718
Cage is going in over the winter and I wanted a removable steering wheel for the car. Problem is DCT. Well this seems to have solved that issue. Yes feel is also improved. Also the functions on the steering wheel become a comfort thing. Not having the search for switches when driving having it all very convenient.
roastbeef11586.00 |
11-28-2016, 10:42 PM | #16 |
115
Rep 1,470
Roastbeef - try getting out of a caged car with a fixed seat, full NASCAR door bars and the steering wheel in place. Oh, and do it in 10-15sec when the car is on fire. Removable steering is a must.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
roastbeef11586.00 |
11-29-2016, 07:41 AM | #17 | |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
I have a fixed halo seat and the stock steering wheel, but BECAUSE I have Nascar-style door bars on my cage which give MUCH more room to the driver instead of the more standard straight "X" bars that go past the driver's seat which is much tighter, I don't have ANY problem getting out of the car quickly. I had to prove it at Global Time Attack a couple weeks ago. They didn't think I could get out of the car in time either. Starting with being strapped in, I was out of the car in less than 5 seconds. (They were surprised.) It's all because of the Nascar style door bars. They give you tons of room to be able to get in and out. (Here's a pic before I had my halo seat. There's plenty of room. I'm 5' 10", 170 lbs.) |
roastbeef11586.00 |
11-29-2016, 11:20 AM | #18 |
84
Rep 105
You're just old .
-Greg S
11-29-2016, 11:50 PM | #19 | ||
3221
Rep 6,218
Volume up/down Voice control/phone (never use these I can save for cool suit later) Track up/down Mdm (seems like mdm isn't as easy as the other controls?) Audio output (Seems silly but badass factor is up there!) Pretty much just need the up down buttons on both sides and the mdm button. For the mdm button is there something different vs the other buttons that you had to keep a loop to constantly tell the car that it's on? Or was that the solution you were looking for? I'll check your other thread in CSS you wrote it up there.
11-30-2016, 07:21 AM | #20 | |||
776
Rep 1,718
M Button has no on/off function is it wired to always be on. I can change traction control from MDM to off with the buttons from the center console.
12-01-2016, 03:55 AM | #21 | ||||
3221
Rep 6,218
12-01-2016, 04:33 AM | #22 | |||||
776
Rep 1,718
M3 Number 863221.00 |
