11-23-2016, 08:22 AM | #1 |
28
Rep 300
Track Pads for Stoptech st60/st40
What pads are you guys running with your ST60/ST40 setups?
I've been running PFC08's in my stock brakes, and have been very happy with it's performance. However, PFC 08's don't seem to be an option for the ST60 calipers. Anyone with suggestions on pads for similar durability and performance for the ST60/ST40 setup? |
11-23-2016, 08:42 AM | #2 |
1478
Rep 2,672
I have an ST-40 front kit and just ordered some Pagid RS-14 Blacks. I have been running PFC08's recently but want more bite. If you want something closer to the PFC08's you might try Pagid RS-19's or RS-29's (all of these pads come in both ST-40 and ST-60 sizes). I've tried these in the past and actually prefer them to the 08's, unlike the PFC's they will require bedding though.
You might also check with dbyrd as he's been through some pads with this setup.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
11-23-2016, 09:01 AM | #4 |
1478
Rep 2,672
Clark at Apex Performance, if you ask for 'the discount" he will usually give you 10% off. Fair warning, ST-60 pads are pricey! Also, sometimes pads are backordered so be sure and tell him if you need them by a certain date.
11-23-2016, 09:06 AM | #5 | |
28
Rep 300
brake bias an issue with that setip? |
11-23-2016, 09:16 AM | #6 |
1478
Rep 2,672
If I had to buy again I would have gotten ST-60 fronts, depends on where you are at in terms of experience though. Probably want something you can grow into a bit but obviously don't want to waste money either. No bias issues, Stoptech tunes each kit for each car.
11-23-2016, 09:53 AM | #8 |
115
Rep 1,470
RS29. Definitely call Clark at Apex. Rears will last a long time.
Pagid black is very aggressive with a lot of bite like PFC01. Will wear rotors faster as well.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
///Mobbin1478.00 |
11-23-2016, 09:55 AM | #9 | ||
115
Rep 1,470
11-23-2016, 02:31 PM | #10 |
DSC Off!
304
Rep 718
Lots o' threads re: this topic out there - here are a few:
http://www.m3post.com/forums/showthr...T60+brake+pads http://www.m3post.com/forums/showthr...+stoptech+pads I'm using the Cobalt Friction XR1s, and I really like them, but they have a very high initial bite that took some getting used to. They take a much lighter touch, and it took me a day or so not to get into the ABS at every brake zone. I'm considering the XR2s that should have a little less bite. The Pagid RS-29s are a great endurance pad that has lasted longer than other pads. These are the only ones that I've had trouble bedding-in after using street pads. Others will say that this is a deal-breaker, but you should be able to bed them without incident if you follow the Pagid instructions. I also run them on the street for a day or two before an event and before bedding. I still plan on trying the PFC pads as I preferred the 08 as well - probably the 11 or 13. The cost has kept me from doing so - $550ish. I'll probably try them in the future.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
///Mobbin1478.00 |
11-23-2016, 04:08 PM | #11 |
115
Rep 1,470
The bedding is a pain but I leave them on full time. The Cobalt Friction DByrd mentions are good. We use the XR3 at all 4 corners on the Spec Miata but it has no ABS.
11-23-2016, 04:31 PM | #12 |
73
Rep 527
Drives: 2011 E82 135i, 2015 F15 X5 35D
I'm running SR34 in the front of my St60 kit and SR33 in the rear on the st40 kit and haven't had any issues or anything bad to say after 7 events.
11-23-2016, 08:19 PM | #13 |
236
Rep 957
I've been running Endless n35s and pretty happy with them, but because they are so good I pushed pretty hard and boiled my fluid, ended up getting some titanium shims.
11-24-2016, 01:14 AM | #14 | |
Rep 258
If you are boiling fluid, you don't need shims and just use better fluid like Brembo, Endless or Castrol SRF. PFC08's have been replaced by PFC11's which are quite good but some mention they are a bit harsh on rotors. Endless ME20's are very good for both street and track duty. Also, Ferodo and Race Technologies make good pads as well. |
11-24-2016, 07:07 AM | #15 |
115
Rep 1,470
You guys all know that there are only like 3 companies that make these brake pads, right. Everything else is just the individual branding put on them. Just like car batteries.
11-24-2016, 08:32 AM | #16 |
28
Rep 300
Thanks for all the feedback....really appreciate it.
I know there are threads out there on this already, but now I'm wondering if my wheels will clear the ST60 caliper. I have a set of APEX ARC8 18x9.5 ET22 wheels that is supposed to clear the ST60 calipers, but then when I used their template to double check....I find that the spokes will clear, but wheel isn't wide enough. Any first hand experience/comments. My wheels are bought second hand...so they are kind of old. |
11-24-2016, 10:36 AM | #17 | |
28
Rep 300
I guess I'll be going ST-40 on all for corners. |
11-24-2016, 12:36 PM | #18 | ||
1478
Rep 2,672
I would get a quote from Joe at Trinity, he has the best Stoptech prices I've seen anywhere (and is a forum advertiser too). I would also consider the Trophy kit, the anodized finish looks good and it stays nice. I got a little brake fluid on my painted ST-40's and it shows. Functionally they are quite similar though. On my last car I had the Trophy ST-60's and loved them.
11-24-2016, 03:51 PM | #19 |
662
Rep 1,424
I would suggest "if" going with stoptech the ST-60 front only. I don't think the st-40 front makes any since. With that said I am not impressed with stop tech. The braking performance isn't much better than OEM other than larger pad life. Plus there is more pad knock back than I would like. My AP Racing (euro version) performs much better. Food for thought.......
11-24-2016, 05:37 PM | #20 | |
28
Rep 300
I'm getting fade about 10 minutes into a session with stock calipers and PFC08's. Are you saying that the ST40's won't be any better? |
11-24-2016, 06:40 PM | #21 | ||
1478
Rep 2,672
Then that same setup at COTA was fine but I was managing my brakes slightly. Benefit of going for larger rotors and maybe even both the front/rear ST-40 combo will be that you can manage your brakes less. Another option, some of these pricier BBK's come with 372mm front rotors instead of 380mm and they may fit under your wheels more easily. Price for both front/rear kit will eclipse Stoptech though. Tough call I know, happy to answer any questions!
11-24-2016, 09:45 PM | #22 | ||
662
Rep 1,424
I would recommend the AP Racing Essex kits..... |
