11-21-2016, 03:32 PM | #1 |
115
Rep 1,470
StopTech Friction ring Hardware spinning
I'd post this in the brake section, but this is probably much more of a BBK track thing. My hardware is rotating as much as 45 degrees. It is biting into the hats. It would be as though the ring is stopping but the hub and hat are still going?? Both 380mm fronts are doing this. Has anyone seen this? This is my 3rd set of rings. I noticed when I used the race hardware on my 2nd set. That is the Trophy hardware with flat washer instead of Belleville washer. With my 3rd set I went back to Belleville washers. Functionally, the brakes work fine, but I know this should not happen.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
11-21-2016, 03:39 PM | #2 |
1478
Rep 2,672
I'm still on my first set of rings but curious to hear the answer. I'm also curious, is the torque spec any different between the Trophy and non-Trophy kits?
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
11-21-2016, 03:44 PM | #4 |
1478
Rep 2,672
Looking at pictures of other Stoptech rotor hats, those flat sided nuts look like they sit flush against the ledge beneath them. Yours almost look like they have a gap under them, perhaps the wrong size nut??
11-21-2016, 03:48 PM | #5 |
115
Rep 1,470
Torque spec is the same. It is about 70 in-lb.
If I hammer them back straight, they are essentially flush. Hat is soft aluminum. Hardware is steel. Put enough torque on it on track and it just bites in I think. I have the regular brakes - not Trophy. They share frictions rings and hats though. Same hardware except the washers that sit on the side with the socket head cap screw. I tried the Trophy washers and saw no benefit. It seriously looks like caliper stops ring but hat tries to keep going with tires. Very hard brake zones at cota??
11-21-2016, 04:01 PM | #6 |
1478
Rep 2,672
11-21-2016, 04:18 PM | #7 |
115
Rep 1,470
Nothing there I don't know or didn't do. They give a little green tube of loc tite for the hardware. After torquing, you place a drop or two in the center of the nut in my pictures. It wicks down the threads. The bolts are not backing out of the nuts. I've installed the original kit and front Friction rings two times after that. I'll buy new hats with my 4th set of rings just because of this, but normally that should not be necessary with the condition of my hats (aside from the gouges at the nuts).
11-21-2016, 04:32 PM | #8 | |
1478
Rep 2,672
11-21-2016, 04:48 PM | #9 |
403
Rep 1,171
Just looking at the pics and mentally rotating the nuts back to the right position, leads me to think there's too much of a gap between the nut and the hat lip...maybe it's the pic but mine have almost zero gap with the hat lip. Like maybe only one piece of paper width of gap
11-22-2016, 10:53 AM | #10 |
115
Rep 1,470
Erik Steinkamp at StopTech is investigating. I think it all ties back to the hardware kit designed to prevent knockback. I saw no difference on track using that hardware kit even on track sections known for knockback, so I went back to the street hardware kit.
11-22-2016, 12:48 PM | #11 |
DSC Off!
304
Rep 718
Scott,
I have the Trophy kit, and when I replaced the rotors, they only had one hardware option that included the Belleville washers. I took a quick photo of mine and they look more flush with the flat edge, but they're also starting to ever so slightly dig into the hat like yours.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
11-22-2016, 03:51 PM | #12 |
115
Rep 1,470
If you want flat washers which is what they call race hardware which is supposed to help prevent knockback but allows them to make more noise, the part numbers for E92 M3 380x35mm are:
Driver - 31.846.1101.87 Passenger - 31.846.1102.87 With belleville washers and less noise, the part numbers are: Driver - 31.846.1101.99 Passenger - 31.846.1102.99 Same price either way. They always have either in stock. The only difference in the two part numbers is which washers you get. The rest is the same. The rotors really rattle around with race hardware.
11-27-2016, 06:10 PM | #13 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
If I had to make a guess...the bolt holes in the rotor hat are slightly elongated when new to allow thermal expansion. Over time, I would imagine that heat cycling may elongate the holes more than designed. That's the only way I would imagine those flanged nuts would have the room to turn.
I've never gotten past a second friction disc but I do know the rotor hats are consumable items. Not sure how many disc changes a rotor hat is good for.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
