11-11-2016, 10:26 AM | #8 | |
Stop the hate, get a V8
3850
Rep 8,625
Larger rotors do not mean better stopping. Friction and surface area are not related. Between two rotors, all else being equal, the larger diameter rotor will stop better because it has more MASS to dissipate the heat, not because the friction surface is larger. The concept of friction and surface area being unrelated is tough for people to grasp. Here's an easy way to prove it: take a non-square box and put a bunch of stuff in it. Try pushing the box across the floor and feel how much effort it takes. Now, rotate the box to a different side (either smaller or larger) and push it again. It will take the same amount! This is because the friction is exactly the same. The reason the BBKs can be smaller but work better is because they are far more efficient at bleeding off the heat than an OEM rotor. They're able to do this because the cooling veins are more efficient, more plentiful, spaced better, etc. Also, it's a true two-piece rotor.
Past: 2011.5 M3 sedan ZCP |
11-11-2016, 09:15 PM | #9 | ||
3221
Rep 6,218
I just today that st40 are now $1700.
11-11-2016, 09:29 PM | #10 |
1478
Rep 2,672
For that price I might have to pick up a rear set!
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
11-12-2016, 07:07 AM | #11 |
28
Rep 300
I've been looking at Turner's site.
I'm going have to call them and ask, but the pricing is seems very variable. Just changing the color changes the price by almost 500 dollars???? |
11-12-2016, 07:43 AM | #12 | |
11586
Rep 12,726
op, scroll past the product on this site to view a pretty thorough info blog on brakes. it sort of explains how they can get away with using a smaller rotor. (not stoptech, but the concept is the same) https://www.essexparts.com/essex-des...p5060355mm-e92
Instagram; @roastbeefmike
11-12-2016, 07:14 PM | #13 | |
3221
Rep 6,218
11-12-2016, 11:23 PM | #14 | ||
1478
Rep 2,672
11-13-2016, 06:34 AM | #16 |
28
Rep 300
Anyone know why there is such a huge variation in prices?
Bimmerworld has the identical kit of $2,900....That's $1,200 more than what Turner charges. Am I missing something here? |
11-13-2016, 11:44 AM | #17 |
2760
Rep 5,483
St40 front rotor is 35mm thick vs 30 stock. It's a larger rotor overall. A 355x32mm rotor is also the OEM front rotor used on the Viper for a number of years which is capable of achieving about 20mph more on a given straight than these cars.
11-13-2016, 03:13 PM | #18 |
28
Rep 300
for some reason I thought that stock m3 rotors were 355 mm
11-15-2016, 03:46 PM | #20 | |
3850
Rep 8,625
Silver, black, and red are all the same price. You are probably looking at a different kit (such as the larger ST60 or a Trophy). I went for black because it never looks dirty and is stealthy. My only gripe is that the white StopTech logo has turned beige from the heat, haha.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 11-15-2016 at 03:55 PM.. |
11-15-2016, 03:50 PM | #21 | |
3850
Rep 8,625
Larger pads mean they can take more heat and will wear slower.
11-15-2016, 05:12 PM | #22 | |
28
Rep 300
