11-07-2016, 07:00 AM | #1 |
203
Rep 699
When to replace front brake rotors?
After 42K miles and some 40 hours of track driving my OE front rotors are near the recommended replacement thickness of 28.4 mm. Apart from that there has been no drop off in performance, no obvious cracks between the holes etc.
So I was wondering when do people who track their car replace the rotors? Do you go by the thickness, or wait for cracks, or wait for brake performance to be affected? I don't mind the expense, you have to pay to play, but I don't want to replace them unless it makes technical sense. So would be great to hear what others are doing with their own cars and rotors. Pointers welcome, thanks. Last edited by Candide13; 11-07-2016 at 08:07 AM.. |
11-07-2016, 07:21 AM | #3 |
239
Rep 479
I would go by minimum thickness... I have been told before to replace it once you get vibration when you brake but honestly you don't want it to get that bad especially on a track day. You'll end up cutting you your session short.
11-07-2016, 01:56 PM | #4 |
Retired Curmudgeon
2985
Rep 4,047
It depends. Minimum thickness is a required replace, in my opinion.
Cracks that catch a finger nail mean the rotor is done. Cracks between two holes means the rotor is done. Cracks that go to the edge of the rotor means the rotor is done. When in doubt, perform a float test. Toss the item into the nearest body of water. If it floats, you can use it.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
macdude357467.00 chamba002238.50 |
11-07-2016, 02:02 PM | #5 | |
203
Rep 699
11-07-2016, 02:04 PM | #6 | |
467
Rep 818
11-07-2016, 02:05 PM | #7 | |
Retired Curmudgeon
2985
Rep 4,047
Stock are fine for street/track, but they wear your pads pretty quickly.
11-07-2016, 02:06 PM | #8 |
Retired Curmudgeon
2985
Rep 4,047
Float test is legit. It hasn't failed me yet.
11-07-2016, 02:15 PM | #9 | |
467
Rep 818
I've noticed that the PFC DD rotors have a warning to only use PFC pads (or at lease to make sure your non-PFC pads will fit because the hat is a bit smaller than stock). Not sure if this is a real concern or just a way to get you to buy their pads. |
11-07-2016, 02:24 PM | #10 | |
Retired Curmudgeon
2985
Rep 4,047
That being said, the DD rotors are super sweet. You won't regret having them...unless you turn around and buy a BBK the next week.
11-09-2016, 04:24 PM | #11 |
130
Rep 198
Drives: 2011 e90 ZCP
What do you guys use to measure the rotor thickness? I have a set of digital calipers but I don't get an accurate reading because the pads wear a flange into the edge of the rotor that's thicker than the pad wear area.
11-09-2016, 04:58 PM | #12 | |
Retired Curmudgeon
2985
Rep 4,047
Or you can use a regular vernier caliper like this: Vernier caliper will be less accurate due to it measuring the peaks of the ridges instead of the valleys.
NoCarrier130.00 |
