11-01-2016, 09:31 AM | #1 |
93
Rep 356
Considered posting this under the suspension section but wanted input from those who track. I recently did 2 days of track at Thermal club with Drake Kemper instructing (awesome experience by the way and a great guy). On the second day I began to get some significant judder in my wheel with high speed braking. I have Hawk DTC 70 pads but otherwise all else is stock other than brake fluid (motul 600). The mechanics at Thermal put my car on the lift and assessed that my front control arm bushings needed replacement. Not warped rotors or other considerations. I just rolled over 30K miles with around 7 track days (yes, I need more). Was wondering if this bushing issue was a fairly common problem for our cars and if others would recommend non-stock bushings. Still under warranty and I don't really track.
11-01-2016, 09:57 AM | #2 |
1478
Rep 2,672
Lot's of us have replaced our front lower control arm bushings with the advertised benefit of better brake and steering feel. I went with the Rogue non-monoball set and I am not sure I felt much difference on the street or the track. If yours are starting to fail, you may as well go for an aftermarket set. If I did it again I would go with one of the sealed monoball designs. More NVH may be introduced with monoballs but most are not bothered by it if you are just replacing this one part.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
11-01-2016, 11:49 AM | #4 |
746
Rep 1,848
Sounds to me more like uneven brake pad deposit. I'd hit the rotors with Garden hose overnight then re bed the pads the next morning.
11-01-2016, 11:56 AM | #5 |
1478
Rep 2,672
This also, you'd likely feel a vibration in your steering wheel on the street under hard braking if it is pad deposits. Might want to fully rule that out first.
11-01-2016, 11:57 AM | #6 |
93
Rep 356
Thanks for the info. I have had deposits from the stock pads and hence the switch to the Hawk DTCs to prevent this. But that is a consideration as I am on the same rotors between the two. Did not previously have this problem with the hawks though.
11-01-2016, 09:44 PM | #7 |
11586
Rep 12,726
you're on oem rotors with the hawk dct's?
is the shudder just when braking, or is is almost a constant steering wheel shimmy?
Instagram; @roastbeefmike
11-02-2016, 11:55 AM | #8 | |
93
Rep 356
