10-27-2016, 11:24 AM | #1 |
88
Rep 118
Laguna Seca Sound
So I am planning on doing Laguna near the end of Nov with NCRC. I haven't been back there in like 8 years. And the last time I went I believe the limit was 92db. The NCRC event is 90db.
Tried searching but did not find anything concrete. My car currently has test pipes with megan exhaust. I am assuming that will definitely not pass. But i have both the stock mid and rear. Will a combination or stock exhaust with TP or megan with stock mids pass 90db? Or will I need to have full stock in order to pass. Thanks!
09 E90 M3 SSII/FR Ext 6MT
10-27-2016, 02:14 PM | #2 |
11586
Rep 12,726
When I was deciding whether or not to go with my titanium axle back (oem mid pipe), I looked for something definitive and came up with nothing. A good suggestion was to have someone stand approximately 50 feet away and do some wide ole throttle passes at the top of 2nd. You'll be at the top of 3rd going uphill while you're passing the booth, so maybe try to replicate that as well.
I'm 375 miles from Laguna, so in order to be sure I don't ruin an infrequent trip up there, I swap on my stock exhaust. It's also said that most cars with an intake and exhaust won't pass sound.
Instagram; @roastbeefmike
10-27-2016, 02:50 PM | #3 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
It depends. My Akrapovic Evolution exhaust (full) passes, but at WOT passing the garages at Laguna, roastbeef says it's one of the quieter exhausts out there.
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
10-27-2016, 02:52 PM | #4 | |
11586
Rep 12,726
I have been told my oem system is louder. All I run at Laguna is my afe carbon intake.
10-27-2016, 03:09 PM | #6 |
11586
Rep 12,726
Lifting would ruin it for me. Even though I'm a novice, i enjoy trying to set my personal best time.
10-27-2016, 03:20 PM | #7 |
88
Rep 118
Thank you for all the response. Ultimately it comes down to I'm getting fat and lazy . So I would rather do the swap twice, off for the track and back on again. Hence why I asked to see if anyone has experience with either combo. I leaning towards putting back my exhaust and leaving the TPs on. But I haven't heard how loud that will be at WOT and I don't want to go back under to change it out.
I thought about the bent pipes to redirect the noise, but I don't run Laguna often enough to warranty that in my mind. I could lift off, but I swear I remember reading somewhere on this forum that they look for that too. Correct me if I am wrong. Cheers!
10-27-2016, 04:00 PM | #8 |
11586
Rep 12,726
I have read that too, but I think it's a scare tactic. I've observed very loud cars running all day long.
10-27-2016, 04:23 PM | #9 | |
846
Rep 1,679
You may be misconstruing what it actually means to lift. I ran a 1:41 flat on crap tires lifting. It's really just a momentary thing and if you do it right it shouldn't much affect your lap time (MAYBE a tenth?). |
10-27-2016, 08:45 PM | #10 |
11586
Rep 12,726
really? maybe i am misinterpreting what people are actually doing. do you have a vid if you lifting? i always thought people shifted early and did like a half throttle thing up the hill...
10-28-2016, 01:07 AM | #11 | |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
The video below is from a 90db day. You can see my foot is 100% on the gas pedal as I exit Turn 5. I did shift to 4th just a bit before redline, and what you can see me do there is edge to the middle of the track as I go by the sound booth. Normally, I would stay on the far right after the turn. Even with all that fiddling around, the lap is still good for a 1:36.1. |
roastbeef11586.00 frostie32187.50 |
10-28-2016, 02:37 AM | #12 |
24
Rep 57
Drives: 2017 C7 Z06 Z07 7MT
The weather will affect sound as well. I'm also eyeballing a Nov/Dec Laguna track day. Here's hoping for clear skies...
10-28-2016, 01:21 PM | #13 | |
88
Rep 118
Thank you! Sounds like TPs and OEM exhaust should be okay then. And worse case just do a little lifting.
10-28-2016, 03:40 PM | #14 |
24
Rep 57
If you're close, you can ask for a sound check, but it may be better not to draw attention to yourself...
11-10-2016, 02:37 PM | #15 |
IG: @dj_dub
1803
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
I'm doing Laguna at the end of this month and plan to lift/shift early between turns 5 and 6 passing the sound booth. I have straight pipes to an Akra rear section. I doubt it'll pass 90db going WOT up that hill. I'll let you know if it works!
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
11-10-2016, 03:23 PM | #16 |
11586
Rep 12,726
I've never heard a loud akra. Got any sound clips?
11-10-2016, 03:48 PM | #17 |
IG: @dj_dub
1803
Rep 1,452
Correct...Akra's on our cars are generally pretty quiet, that's why I decided to straight pipe before the rear section to open the sound up.
Do you have IG? If you do, you'll see a vid of my car from ACS recently...I just uploaded it for you. First post on my feed. IG: dj_dub
11-10-2016, 04:34 PM | #19 |
IG: @dj_dub
1803
Rep 1,452
11-28-2016, 12:26 AM | #20 |
IG: @dj_dub
1803
Rep 1,452
Here's a pic of me passing the sound booth today between turns 5 & 6...never got meatballed today going WOT in 4th going up the hill with my exhaust setup (Akra w/RPi X-Pipe). I'm pretty sure if I was in 3rd, it would be a different story.
GBMA3980 by dj_dub, on Flickr
12-20-2023, 09:36 PM | #22 |
166
Rep 485
Think I would be clear with stock primary cats but secondary cats & resonators remove with OEM muffler? Eyeing multiple 90db days next year and would love to not have to throw additional cats back on.
