09-29-2016, 04:19 AM | #1 |
sportscars only
3274
Rep 3,206
Easy way to remove kidney grills? (or centre grid for M bumper?)
I'm trying to mount my licence plate holder (that will attach to the centre grid of my M bumper).
I'm guess that it may be easier to remove the kidney grills to access the back of the centre grid...instead of directly removing the centre grid? Is there an easy way to remove the grills w/o going through the air intake? If you guys have a better idea, please let me know. |
09-29-2016, 08:23 AM | #2 |
246
Rep 2,387
There's many thread here about removing the kidney grills. Do you really want to block all that air flow with your license plate?
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
09-29-2016, 11:59 AM | #3 | |
sportscars only
3274
Rep 3,206
Doesn't block at all, just the mounting frame that is 2cm in width and is hollowed out so not even that. |
10-05-2016, 08:23 AM | #4 |
118
Rep 1,668
the grills are simple to remove. Grab firmly the grill on boths sides with your hands and pull evenly. They pop right off. repeat for other side.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
10-05-2016, 10:12 AM | #5 | |
246
Rep 2,387
10-06-2016, 04:21 AM | #7 |
Rep 157
OK, so then only for the records:
You could simply pull out the kidneys at one fell swoop (or two). Use one hand to keep the center of the bumper (between the kidneys) in place and the other hand to take out the kidney by reaching through the kidney's bars with your fingers jerkily pulling it out. Wear protective gloves or you will cut your fingers. Be careful that it's warm enough (e.g. with a blow-dryer) so it's not so likely that the locking tabs break as cold temperatures make the plastic brittle. I regularly replace the stock kidneys with the gloss black "perfomance" kindeys this way and I never had any problems so far, nor did I break even one of the locking tabs. Best regards Mick Ed.: Ah well, as @rking117 said. |
