09-05-2016, 01:32 PM | #1 |
75
Rep 142
Jb4 Vbox testing - Ethanol mix Map 2, Map 7
I picked up a JB4 to do some further testing on...ran some tests with Map 1,2 and 7.
This is a JB4 car (M4 DCT) with BMC drop in filters, no other mods. I'm running about 3 gallons of Ignite 114(E90) and the remainder pump 93. I'll be adding more Vbox runs to this thread and should have the following for all maps once completed. 60-100mph 100-200kph 60-130mph Some of the boost data from each map. Map 1 was hitting 21psi Map 2 was hitting about 21psi - 21.5psi map 1 and 2 felt pretty much the same, 2 pulled a little harder in the higher gears but nothing huge. Map 7 was hitting 24psi-24.5psi This map ran great with no miss fires and was very smooth. - clearly its hauls ass. Map 7 60-100 in 3.52 seconds, this could have been faster but I didnt go WOT till about 55mph. Map 1 best 60-100 in 3.85 - most runs were typically in the 3.9-4.0 range with with 0 to -1% slope Map 2 100kph-200kph in 7.49 seconds, 60-100 wasn't recorded for whatever reason but using the data on the graph below its about 3.9 Last edited by turbomcgee; 09-05-2016 at 02:56 PM.. |
09-05-2016, 02:48 PM | #2 |
263
Rep 415
Nice thread, I'm looking forward to your results. I'm a vbox man as well and it's nice to see some more times for these cars. Most guys are just interested in dyno runs which for me doesn't really mean much.
For reference I know a guy who ran 6.9s 100-200kph jb4 only on 93 octane. He now runs 6.6s with a flash/jb4 combo still on 93. His car will go deeper into the 6's once he sorts out his traction issues. |
09-05-2016, 02:53 PM | #3 | |
75
Rep 142
map 7 should get me in the 6's based on the 60-100 time. |
09-05-2016, 03:11 PM | #4 |
263
Rep 415
It was on map 2. Not sure on boost but it should all be relative for the conditions etc since these cars target a certain load on the oem flash.
Yeah definitely, that 60-100mph has you in the 6's over 100-200kph. |
09-05-2016, 10:35 PM | #5 | |
75
Rep 142
Map 2 for me is not a linear +6 psi too, its the more reliable map for sure but my OEM boost targets were lower than I had expected. Last edited by turbomcgee; 09-05-2016 at 10:43 PM.. |
09-07-2016, 11:20 AM | #6 |
BimmerPost Supporting Vendor
24276
Rep 190,975
Good thread, do you have datalogs for the different runs?
09-07-2016, 12:03 PM | #7 |
75
Rep 142
09-07-2016, 12:34 PM | #8 | |
24276
Rep 190,975
BT connect kit is a must in my opinion
09-07-2016, 12:35 PM | #9 |
Gone Fishin’
7318
Rep 12,125
09-07-2016, 12:38 PM | #10 |
24276
Rep 190,975
He stands 100% behind his product
09-07-2016, 01:22 PM | #11 |
75
Rep 142
09-07-2016, 01:25 PM | #12 |
24276
Rep 190,975
Thats a very good idea
