08-29-2016, 10:57 PM | #1 |
44
Rep 201
Rear Spring Adjusters - Any real track reviews?
I am looking at upgrading to a full MCS set up but am looking at rear spring adjusters options. I know Ground Control, Bimmerworld, Turner and others make some but I'd prefer recommendations from you guys that are adjusting them regularly.
Which brands do you like? Not like? |
09-05-2016, 06:27 PM | #2 |
85
Rep 187
I'm not sure if I understand what you mean, but I decided to go full coilover on my car. The setup was done by Tom Shirmer in Germany and he uses Nitron dampers and his own spring setup and adjustment. It is worth mentioning that I'm using full coilover without a cage or other reinforcement for the rear shock towers. All working perfectly. To be honest. The low speed comfort is compromised, but high speed comfort improved. And then there is all the benefits of improved cornering ability and agility. Basically a new car in many ways.
09-06-2016, 09:19 PM | #3 |
721
Rep 2,342
They're all pretty much the same.
MCS/BW/Turner all use similar spanner types. The GC one is different. But the effect is the same. IIRC GC uses different thread pitch so if you want to use different perches like hyperco threaded ones they won't work. You also may need adapters for the spring diameter you choose. |
09-06-2016, 09:33 PM | #4 |
44
Rep 201
Yes, I am looking at the non-rear coilover setup since I am not doing a cage yet and don't like rear coilovers without it. The GC ones seem to be a slip-in and the BW/Turner are a bolt-in. I just wanted to see what people had and how easy/reliable they were for people to adjust.
09-10-2016, 09:21 PM | #5 |
1258
Rep 2,492
All the same...I've used Ohlins, AST, KW on track and they all serve the same purpose with the same strength. The bimmerworld ones are actually manufactured by TC Kline, and they have been my least favorite. I would go with GC, they are the longest and go with a cool locking mechanism.
2010 E92 M3 DCT
09-12-2016, 04:27 PM | #6 |
108
Rep 697
I've had the ground control rear adjusters and was always wary about how it just wedges itself in the opening hole. Seems like it would put lot of pressure into a smaller concentrated area.
09-13-2016, 08:46 PM | #7 |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
The JRZ approach is cool. Instead of two small plates that lock together and can get stuck or can strip (which is what they used to have), now they use a bigger, thicker ring that locks in place by an allen screw that tightens the ring down. When you need to adjust, you just loosen the allen screw and the ring turns easily.
They're not cheap, but I like them. Here's what they look like: (I have a spare laying around.) |
09-14-2016, 05:39 AM | #8 | |
1258
Rep 2,492
2010 E92 M3 DCT
09-14-2016, 04:42 PM | #9 |
5355
Rep 2,806
I don't have helper springs in the rear to keep tension in the main spring when the car is lifted, so I can't answer your question from experience. The ring spins pretty easily when the hex screw is loosened. My guess is that it would not bind under a light load.
09-14-2016, 05:07 PM | #11 |
884
Rep 1,262
Drives: 2016 M4 GTS
This...
2016 M4 GTS Alpine White
2021 X5M Competition Marina Bay Blue Instagram: @JustAnothaM4 |
