08-20-2016, 11:05 PM | #1 |
424
Rep 1,325
Stripped oil drain plug!
Sucks big time. I was chugging along just laughing at myself at how easy our oil changes are. Was on world record pace to finish and the unthinkable happened. Went to tighten and it just spun.
I am not confident in my ability to fix it so I will most likely be towing it to MRF on Monday morning. Is this an easy, cheap fix. I was hoping to go to acs in Sept and hope this doesn't put a large dent in the wallet. Is there any recommended upgrade while I'm getting this fixed? Maybe like a baffle etc?
08-21-2016, 12:27 AM | #2 |
303
Rep 1,140
Drives: Something something racecar
I use this on my E46. You may be able to use it on the E9X as well. I like having the hex head as a backup, and I now replace the plug every oil change to reduce chances of stripping.
https://www.ecstuning.com/b-genuine-...g/11131742994/ |
M3MPH1S592.00 |
08-21-2016, 01:25 AM | #3 | |
424
Rep 1,325
08-21-2016, 06:40 AM | #4 | |
746
Rep 1,848
08-21-2016, 09:05 AM | #5 |
11817
Rep 23,187
Is It leaking now? If you have finished oil change and it isn't wait until next oil change and take it in. I actually did 2 separate oil changes on e46 with a punch and hammer to get out oil and recap.
08-21-2016, 09:39 AM | #6 |
1478
Rep 2,672
Pretty sure you can re-tap it to a larger bolt size but not positive. Good luck and let us know how it goes.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
08-21-2016, 09:43 AM | #7 |
1478
Rep 2,672
Fwiw, this is my new drain plug of choice after stripping a few of the soft OEM BMW drain plugs, LINK. Remember to buy 2 at a time, I also like to keep spares around.
M3MPH1S592.00 |
08-21-2016, 10:26 AM | #9 | |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
I'm not a clever man, but by watching videos and by having enough guts to give it a try, I tapped the stripped plug drain myself and installed it no problem. Used blue oil resistant loctite on the insert too. It's cheap and easy. The expense comes if you don't have the required time sert kit to begin with ($100) |
