08-19-2016, 12:38 PM | #1 |
196
Rep 386
Question about low vs. high profile tires on the track
Pretty simple question---- for the track would I be better off with my stock wheels and tires or my 19s with lower profile tires?
Thanks, Chris |
08-19-2016, 12:54 PM | #2 |
125
Rep 713
Depends on a lot of factors like track and tire...I will say this though...if they are both street tires....just chew up the cheaper ones (assuming stock)
08-19-2016, 02:39 PM | #3 |
594
Rep 4,488
All else being equal, larger diameter tires give you an increase in longitudinal contact patch size, which helps with acceleration and braking (though changes in unsprung weight between two proposed setups will also affect this), and a thinner sidewall will flex less. From a practical standpoint, a 35 vs 40 aspect change isn't a major difference (40 is hardly high profile), 18s are cheaper to run, and unless you're already very fast on track, more dollars spent on track days will have a bigger impact on making you faster and give you more fun than more dollars spent on a "better" tire setup. But as was said above, if you plan to do more than about 4 track days per year, step up from PSS to something like AD08R. Their stiffer sidewalls mean they'll last much LONGER than PSS on a dual purpose car despite the lower treadwear rating because they won't prematurely cord or chunk on the outsides. I got 5 track days out of PSS before that happened, and I got 12 track days out of my AD08Rs before the tread meant replacement time. I do NOT recommend that a novice or even intermediate driver go to something like NT01, Cup 2, or even RE-71R since that seems to be similar to Cup 2 even though it's classified as Extreme Summer, and many DE organizers won't allow less experienced drivers to run such tires anyway.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
08-19-2016, 02:50 PM | #4 |
11586
Rep 12,726
what are you running stock? the oem 18's?
the 18's will be better for track use. i actually like a little more rubber for the track, its less harsh on everything (wheels, suspension, etc..) when you bounce off a rumble strip or go off.
Instagram; @roastbeefmike
08-19-2016, 05:10 PM | #5 |
467
Rep 818
I thought that most track guys run 35's even with their 18" tires (275/35/18) so there would be no difference in sidewall height between those and the 19" 35's, right?
08-19-2016, 05:28 PM | #6 | |
594
Rep 4,488
macdude357467.00 |
08-19-2016, 05:51 PM | #7 |
11586
Rep 12,726
yea, the sidewall number represents different depths since it is relative to a percentage of the tire width. just eyeballing it, i can tell you my 275/35/18's had a thicker sidewall than my 275/35/19's.
08-19-2016, 06:44 PM | #8 | |
594
Rep 4,488
08-19-2016, 07:18 PM | #10 | |
196
Rep 386
I have OEM 18s and I have DINAN 19s 275/30 front and 295/30 rear. I was kind of thinking the same thing about running the OEMs, but the tire size of the DINAN wheels make it stick like a monster. |
08-19-2016, 07:24 PM | #11 | |
594
Rep 4,488
08-19-2016, 08:16 PM | #12 | |
196
Rep 386
08-20-2016, 10:24 AM | #13 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
Tire sidewall plays a role in the effective spring rate of the suspension. And all of this other stuff.
But let me make it easy for you... Smaller diameter wheels = cheaper tires = more time on track. /thread
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
SYT_Shadow11488.50 r53s65e9018.50 |
08-22-2016, 01:58 PM | #14 | |
Stop the hate, get a V8
3850
Rep 8,625
I have never come across a group that didn't allow somebody to run a specific tire. Depending on the club, an R-compound tire might automatically move you into an "anything goes" group where you'll be up against trailered-in race cars. Then again, I don't run with groups like SCCA or NASA. I do agree that ultra-grippy tires like the ones you mentioned are a bad idea for beginners as they really tend to hide mistakes and allow you to develop bad habits. I run AD08R and agree that it's about as aggressive as I'd ever go for dual-purpose; the ride quality on the street is a lot harsher than the PSS, but even after 6 track days they look great whereas the PSS looked like shit after 1 or 2.
Past: 2011.5 M3 sedan ZCP |
08-22-2016, 02:07 PM | #15 | |
594
Rep 4,488
I don't remember a dramatic difference between PSS and AD08R in terms of road ride. I was running a stock non-ZCP EDC suspension except for camber plates. The only place I noted a difference was over things like freeway expansion joints and other road irregularities, although I suppose the local road quality would influence ride impressions quite a bit. Wrote a long comparison here: http://www.m3post.com/forums/showthread.php?t=1044773.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 08-22-2016 at 02:13 PM.. |
08-22-2016, 03:18 PM | #16 | |
3850
Rep 8,625
It was precisely those things: expansion joints and large seems/irregularities. The ride quality has definitely gone down and can be very jarring. If I had to do it again, I don't know if I would've bought the AD08R, to be completely serious.
08-22-2016, 03:30 PM | #17 | ||
594
Rep 4,488
08-22-2016, 06:44 PM | #18 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
In theory, the golden sweet spot on tire size is:
Run the SMALLEST wheel diameter that will clear the brakes, and NARROWEST tire that won't overheat given your car's power and weight (and your particular driving style) with the aspect ratio that comes closes to matching the overall OEM tire diameter. So if 17" rims fit over the brakes without interference and/or need of spacers, and 265mm wide tires don't get past the sweet spot in tire temp on your brand of tire choice? No reason to run any bigger since 1) 17" track tires are cheaper and 2) 17" and 265mm wide track tires are lighter than 18" and 275mm. Then again, if you're given 295/30/19s to run for FREE? Run the damn 295/30/19s. If they fit. If they don't fit, go wide body kit and make them fit.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
08-23-2016, 09:25 PM | #20 | |
190
Rep 969
Sold 2011.5 E92 M3 ZCP.
