08-14-2016, 02:08 AM | #2 |
Bored at work....
890
Rep 5,391
What's the weight of the 666's?
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
08-14-2016, 02:12 AM | #3 |
18
Rep 64
25lbs front, 26.5lbs rear, according to IND
schnell325889.50 mshab356275.50 |
08-14-2016, 02:17 AM | #4 |
Bored at work....
890
Rep 5,391
08-14-2016, 03:26 PM | #5 |
3461
Rep 3,995
The GTS wheels are not the same as the CP wheels. GTS has 19in front, 20in rear.
Maybe they're lighter too?
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic |
08-14-2016, 09:08 PM | #7 |
3461
Rep 3,995
IND weighed the standard CP 666M wheels which are 20" front and rear.
08-16-2016, 05:03 AM | #8 | |
18
Rep 64
"As standard, forged 19” M light-alloy wheels are used at the front and 20” M light-alloy wheels at the rear in 666M styling." I guess this is why they offer the carbon wheels as a way to reduce weight |
08-16-2016, 09:28 AM | #9 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
A few data points on dimensions and weights:
When you consider that the front GTS wheel is 0.5 wider than the 437M, the 1.1lb weight penalty is not that bad. Maybe they made the 666M very sturdy. But I still find the 666M wheels quite heavy compared to the 437M though. I had much higher expectation when BMW advertised the 666M to be "weight optimized" .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 11-28-2016 at 06:56 AM.. Reason: Edited to add 681M data |
08-17-2016, 02:05 AM | #10 |
18
Rep 64
Totally agree. Don't know why BMW didn't opt for the sort of lightweight wheels Porsche fit on their GT3/GT3 RS.
BBS FI-R weigh in at 16.5lbs front, 18.5lbs rear with M4 GTS spec. Weight-saving for all 4 wheels is 34.8lbs (15.8kg)!!! http://f80.bimmerpost.com/forums/sho....php?t=1155359 |
mshab356275.50 |
08-17-2016, 09:11 AM | #11 |
BimmerPost Supporting Vendor
2868
Rep 11,374
GTS should have came from the factory with BBS FI-R's
08-17-2016, 12:06 PM | #12 |
545
Rep 1,132
You guys are forgetting about the carbon wheels
Fake News 2017335.50 |
08-17-2016, 12:16 PM | #14 |
General
21117
Rep 20,741
Even the 681M Carbon composite wheels are quire heavy compared the BBS FI-R:
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
08-17-2016, 12:23 PM | #15 |
General
21117
Rep 20,741
The weight you quoted seem to be for CP 666M (they are very close to the ETK quoted weights). It is important to note that beyond the fact that the front GTS wheel is a 19", the GTS front and rear wheels are also 0.5" wider than the CP, which increases their weight.
08-25-2016, 01:35 AM | #16 | |
Go ///M or go home
276
Rep 1,280
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT |
08-25-2016, 10:59 AM | #17 |
The limit of adhesion is my home.
1702
Rep 3,778
Didn't the GTS do the 2nd fastest time around the Nurburgring on these wheels?
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
08-25-2016, 11:05 AM | #18 | |
General
21117
Rep 20,741
The point is that the weight of the 666M wheels is not a big contributor to the M4 GTS' good performance.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-25-2016 at 12:19 PM.. |
08-25-2016, 11:40 AM | #19 |
109
Rep 364
Drives: my GF crazy!
Tbh, i just switched my 666m to the 437m wheels and i don't know for some reason my car felt slower. i don't know if it was the tires or whatever reason, maybe psychological, but i felt like my car doesn't feel the same. lol. maybe i'm just getting used to the 19s.
08-25-2016, 12:03 PM | #20 | |
Advocatus Douchebagus. Sex Marxist.
2415
Rep 3,415
Drives: Lucy.
Drivin' Lucy
CanAutM321116.50 WestBankM4248.00 |
08-27-2016, 04:08 AM | #21 |
37
Rep 101
Drives: 2011 BMW 1M; 2016 M4 GTS
I think they wanted a really stiff and sturdy wheel seeing probable track use?
Porsche 991 gt3 wheels are also 24-28 lb front-rear... |
TractionControlDelete4588.50 |
11-14-2016, 12:25 AM | #22 | |
58
Rep 223
The 666m's probably felt faster to you because it took you longer to slow down..
