08-03-2016, 12:40 PM | #1 |
DSC Off!
304
Rep 718
Help with Aim Smartycam setup?
I recently purchased the Smartycam to go with the SoloDL. I successfully uploaded the screen configuration to the Smartycam, but the throttle, brake and custom temp gauges for both oil and water are not working. The RPMs, speed, lap times, map, etc. are all working fine.
What do I need to do to get the throttle, brake and custom temp gauges for both oil and water to function properly when recording? Thanks!
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
08-03-2016, 01:10 PM | #3 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
you need to go into the solo dl config and set up the smarty cam functions. Top right of config screen in Race Studio 2
Be sure to enable all function for all parameters in case you dont see what you need.
dbyrd304.00 |
08-03-2016, 04:41 PM | #4 |
DSC Off!
304
Rep 718
Beautiful, man! I'm glad I finally asked. I can't imagine what else I'm missing.
08-03-2016, 04:56 PM | #5 | |
DSC Off!
304
Rep 718
Much thanks, man!
08-03-2016, 11:27 PM | #6 | ||
776
Rep 1,718
glad to help
01-21-2017, 11:20 AM | #7 |
DSC Off!
304
Rep 718
Everything is working but the throttle overlay. I've followed the instructions above. Any suggestions?
01-21-2017, 01:56 PM | #8 |
776
Rep 1,718
Check to make sure you have the right throttle reading. I think you need peddle position
01-21-2017, 02:03 PM | #9 |
DSC Off!
304
Rep 718
Yep - did that and still doesn't work. It's set up as pedal position.
01-21-2017, 02:04 PM | #10 |
776
Rep 1,718
Are you using a CAN connection or OBD II
01-21-2017, 06:35 PM | #11 |
DSC Off!
304
Rep 718
I went back in and you were right. I haven't tested it yet but that should do the trick.
Thanks again!
