08-03-2016, 08:32 AM | #1 |
225
Rep 376
Stripped hub thread. Seeking advice
So I initially installed a set of ECS studs with lug nuts. While torquing down my rear wheels after using this setup for a month or so one of the studs pulled out. As I was torquing that lug it didn't tighten up and I noticed that the stud was pulling out. When I put in a standard lug bolt it torqued up to 90 lbs with no issue.
This concerned me so I pulled the whole set of studs assuming there may be an issue with quality/strength. I put the standard bolts back on and ordered a new set of studs from Motorsports Hardware. Lo and behold the same thing happened with this set. The standard lug bolt still torques up fine but the stud pulled out without it letting me get up to torque. Obvious solution is to replace the hub. My question is what are your opinions on an alternate solutions such as Helicoil or Time-Sert or any other options.
Past: 1979 RX-7, 1980 Civic, 1989 B2200 lowrider, 1990 Golf GT, 1995 Civic Si Turbo, 2000 Civic SiR, 2000 328i, 2003 540i M-Sport, 2008 Rabbit, 2014 Pilot, 2002 A4 1.8T, 2009 A4 2.0T Quattro, 2017 CR-V Touring 2020 CR-V Touring
Current: 2012 135i, 2015 228i x-Drive, 2023 CR-V Touring Hybrid |
08-04-2016, 08:31 AM | #3 |
Loves me some MHD!
1858
Rep 1,719
noob question- how much difference is there on the thread depth between the stock lug bolt and the aftermarket lug studs?
My thought is that the OEM bolts are going in deeper than the lug studs, so getting some good thread to bite on. Extra question- Do you run spacers?
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
08-04-2016, 09:29 AM | #4 | |
225
Rep 376
Yes I am running spacers on the rear only right now.
08-04-2016, 09:31 AM | #5 |
225
Rep 376
So I did order a Helicoil kit and will give that a try. If it doesn't hold I guess I will just replace the hub.
