07-19-2016, 11:57 PM | #1 |
605
Rep 438
Exit oversteer reco for KW Clubsports
Hey all,
Coming up on my 7th track day this year, and as the weather has warmed up, I've started to be plagued with mid corner exit oversteer despite running the stickiest tires I've ever owned... Clubsport track settings: FD - 3 from full FR - 5 from full RD - 4 from full RR - 7 from full Tires: Front: 265/30/19 Toyo Proxes R888 Rear: 295/30/19 Toyo Proxes R888 Always run Euro MDM on the track. This setup has been beyond amazing until the weather warmed up significantly last week. Zero under/over steer all spring and early summer. My rubber is nearly new, and was properly heat cycled. My only conclusion is that it has to be my coilover settings and / or tire pressures (which I monitor closely). Ideas? Thanks in advance!
07-20-2016, 09:05 AM | #2 | |
94
Rep 268
What are your spring rates? divorced rear or true coilover? What does the F/R ride height look like? You could try lowering the rear bump damping |
07-20-2016, 10:34 AM | #3 |
2760
Rep 5,483
why the F do you have the damping settings different from left to right?
If it's loose on-throttle, add rear rebound, subtract front rebound
07-20-2016, 10:46 AM | #4 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
I'm trying to decipher OP's settings, I think "D" is for compression or bounce, and "R" is for rebound? Are ClubSport rebound and compression adjustable?
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
07-20-2016, 11:21 AM | #5 |
BimmerPost Supporting Vendor
731
Rep 3,735
Yes, they are 2 way adjustable. I am hoping that his settings mean rebound and compression, and not different settings for left/right.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
07-20-2016, 11:29 AM | #6 |
2760
Rep 5,483
Ok that would make a bit more sense
D? Dumper? Damper? Dang that was a hard whack damping? I don't know what D stands for here. B for bump, C for Compression, R for rebound, D for dunno? If the CS is any good, one click ought to make a decent difference. If it were me I'd add some rear rebound and see what happens, leave the rest alone, repeat until better unless it's getting worse
07-20-2016, 12:26 PM | #7 |
379
Rep 875
Spring rates, tire pressures, alignment settings? Is the car corner balanced? There's no pertinent info here.
I would start by reducing both the rear bump/rebound a little and go from there. Leave the fronts alone for now if that is working for you. Generally I like my rebound setting a little higher than my bump, but that differs from car to car & track to track. Last edited by cenix; 07-20-2016 at 12:36 PM.. |
07-20-2016, 12:49 PM | #8 |
605
Rep 438
Ha, sorry. D = bump. R = rebound.
To answer a few questions: - No the car is not corner balanced, aligned each time I replace rubber. - KW Clubsports are a true 2 way adjustable coilover - Ride height is pretty perfect imo. Coilover was installed by my local German tuner shop. |
07-20-2016, 02:34 PM | #9 |
3221
Rep 6,218
hmm - these are the settings I run (from full still)
Front: Bump 6 Rebound 6 Rear: Bump 6 Rebound 8 I'm going to stiffen all around in general next time to see the effects then adjust front rear from there. Spring rates are 110/140nmm
07-20-2016, 03:51 PM | #10 | |
115
Rep 1,470
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
07-20-2016, 03:53 PM | #11 | |
115
Rep 1,470
07-20-2016, 07:43 PM | #12 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
Why mess with damper settings when you're still driving with MDM on? Recommend learning how to control the car without relying on MDM.
Then maybe start playing with some damper settings.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
07-20-2016, 08:11 PM | #13 | |
424
Rep 1,325
07-20-2016, 08:50 PM | #14 | ||
1571
Rep 8,076
07-20-2016, 10:24 PM | #15 | |
321
Rep 406
What I'm trying to say is that every speed level and driving style requires a different setting. Your driving style changes the more you track your car. Search the forum for the 'oversteer and understeer' flow chart (it explains what to adjust based on symptoms), that's a good start to develop a feeling on what to do. Good luck
ST-60 / MCS 3-way / Solid subframe / Full cage by JPMarketingllc.com / 315-30 square / GT-250 / JPmarketingllc.com Aero Stage2
07-20-2016, 10:46 PM | #16 | |
2760
Rep 5,483
Secondary consideration I will say it again : beware the R888 with a bunch of cycles. They fall off a cliff at a certain point in their life and suck from then on, especially f you do not shave them first. Tread depth doesn't matter. They could be cycled out. A change in balance to oversteer tends to indicate less grip all else being equal
07-21-2016, 12:29 AM | #18 |
just another M3
514
Rep 1,150
subscribed
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
07-21-2016, 09:38 AM | #19 |
662
Rep 1,424
Keep in mind the op said 7 track days this year not 7 days total. In addition it looks like he is in Germany..........if driving the Nurburgring he could be excused for driving with euro MDM. With that said the car would need to be driven to the limit with traction control completely off to get the best picture.
07-21-2016, 01:56 PM | #20 | |
Retired Curmudgeon
2985
Rep 4,047
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
07-21-2016, 02:07 PM | #21 |
2760
Rep 5,483
They're not all bad if you shave them first. But yeah. They have one thing going for them - lots of big sizes, not too pricey. But I would honestly rather have an undersized RE71R than a right-sized R888. 200tw tires have advanced a lot since the R888 came out 10 years ago
07-21-2016, 03:25 PM | #22 | ||
115
Rep 1,470
