      07-17-2016, 09:51 AM   #1
Ryan13
73
Drives: Z4MC, Z4MR, M3, E36, M2, 535
Track brakes hot...reduce power
Out at Summit Point this weekend tweaking the setup on my 128. It's not gruesomely hot, but warm enough we are tracking in shorts (no flip-flops).
Towards the end of each session, I'm getting a reduction in power, comes and goes on different parts of the track. DTC completely off. I'm thinking it is something in the coding where the brakes are hitting a temperature threshold and reducing engine power. No flickering dash lights noticed. Calipers are standard, pads are upgraded to coolstops, LSD in rear. I'm not lifting that I know of, so not sure how much e-diff is working.
Any other thoughts on potential other cause? Can the temp setting be coded out? I'm getting ready to put 335 calipers/rotors front and rear as soon as I use these up, but not sure if that helps.
      07-17-2016, 11:17 AM   #2
AlexR6
AlexR6's Avatar
Italy
20
Drives: BMW E82 125i
When I overheat my brakes due to elsd intervention I do not get any power reduction and I get the brake yellow dash light on.
I would say your problem is engine oil temp... especially if you do not have the oil cooler!
      07-17-2016, 02:59 PM   #3
kprocivic
kprocivic's Avatar
813
Drives: ecoboost s to the t
http://www.e90post.com/forums/showthread.php?t=1117725
      10-13-2016, 10:19 AM   #4
dcaron9999
dcaron9999's Avatar
157
Drives: 2011 135i M package
This nanny can be coded off by INPA. The parameter is called:
" Engine Power Reduction to Prevent Brake Disc Overheating (FLR) "
http://www.onelapx1.com/blog/how-to-...w-actually-fun
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
Appreciate 2
bNks334426.50
AndyW673.50
1addicts
