07-13-2016, 04:03 PM | #1 |
DSC Off!
304
Rep 718
Where are you guys sourcing your replacement slotted rotors for the ST-60 kit?
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
07-13-2016, 10:57 PM | #2 |
115
Rep 1,470
Alex Noll at ABR
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
07-14-2016, 07:38 PM | #3 |
DSC Off!
304
Rep 718
Thanks, Scott - I got a great deal from Trinity Autosport with no Texas tax.
07-14-2016, 08:51 PM | #4 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
How many days did you get from your front rotors?
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
07-14-2016, 10:56 PM | #5 | |
DSC Off!
304
Rep 718
This is the first time to change just the rotors using the original hat - it looks pretty straightforward. Anything that I should know re: this?
07-15-2016, 08:28 AM | #6 | |
Stop the hate, get a V8
3850
Rep 8,625
Just follow the directions. It is very easy. For good pricing/customer service, try Dave @ Zeckhausen Racing.
Past: 2011.5 M3 sedan ZCP |
07-15-2016, 09:10 AM | #7 | |
321
Rep 406
What pads are you using? What's the dimension on the thinnest section on your rotors? I now have 13 events (2 days per event) and I still have 40% left on the rotors (no street use). I use Cobalt Friction's XR1 and noticed -though insane brake power- less abrasive rotor use.
ST-60 / MCS 3-way / Solid subframe / Full cage by JPMarketingllc.com / 315-30 square / GT-250 / JPmarketingllc.com Aero Stage2
07-15-2016, 10:10 AM | #8 |
115
Rep 1,470
As said, just follow the directions. Make sure Belleville washers are the right direction. Torque is only about 6 ft-lb. wash rotors with soap and water and scotch brite pad first. Don't get left and right backwards.
07-15-2016, 11:47 AM | #9 | ||
1571
Rep 8,076
What surlynkid said. I believe ST specs green loctite. It comes with the replacement hardware kit and is otherwise impossible to find (for me at least). So I just used red...rotor discs are still glued on!
07-15-2016, 11:50 AM | #10 | |
DSC Off!
304
Rep 718
I wore a small groove (2 mm wide) near the center of the rotor where the overall rotor is down to 33mm. My understanding is that when the rotor gets down to 33mm, they're done. The rest of the rotor is between 33.6mm and 34.0mm. I wish PFC still made the 08s for the ST-60 even though they run over $500. Several folks have recommended the Cobalt Friction XR1 so I think I'll start with that pad next.
07-15-2016, 02:17 PM | #12 | |
DSC Off!
304
Rep 718
Hook me up with those older pads!
07-15-2016, 03:19 PM | #13 |
115
Rep 1,470
No such thing as too much cooling except on out lap. ST includes a tiny tube of the green loc tite with the hardware kit. Follow the directions. You install it after torquing and just let it wick into the threads.
07-15-2016, 03:22 PM | #14 | |
1478
Rep 2,672
Point of all this, if you like RS-29, just try them again, maybe with rear BBK now the wear/performance will be even better.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
07-17-2016, 11:21 PM | #15 | |
721
Rep 2,342
I'd almost agree with you except I've seen the open wheel cars tape up part of their brake duct inlets to keep them from overcooling. The engineer at stoptech hinted at the same thing since this occurred at COTA. dbyrd , I'm waiting for the Car to get back from Austin this week and then I can get them to you. |
07-18-2016, 02:39 PM | #16 |
2760
Rep 5,483
Blocking brake ducts on open wheel cars is a drag thing more than anything. Throwing more air into turbulent spinning wheels does not make car go fast
07-22-2016, 12:58 PM | #17 |
142
Rep 284
Drives: '13 Melbourne Red E92
+1 for Zeckhausen. Great service and knowledge base when you need it.
07-23-2016, 10:04 AM | #18 |
1571
Rep 8,076
Forgot to answer the question...
Amazon for rings.
