BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      06-18-2016, 03:51 PM   #1
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
Warp 10 Motorsports 2011 E92 M3 Build Log
Hello all,
I have been on the forums since I bought my car in 2011. Car started life as a Black on Fox Red Comp package car. As soon as I bought the car I started tracking it. To break the car in before the first track day a week after delivery my father and I took the new M3 and his new 2011 Boxster Spyder, loved that car! As the track hobby started I was hooked and hooked bad. Mods starting coming in weekly, sometimes daily?.The car has been through a number of wheel changes (OEM Comp Wheel, TE37?s, now 3 Sets of Apex ARC-8?s), several suspension changes (GC Coilover Conversion, KW Clubsports, and now MCS 2 Ways), Exhaust changes ( OEM Xpipe with Corsa, AA Catted Xpipe with Corsa, AA Catless Xipep with Corsa, and finally AA Catless with BImmerworld Race Exhaust), and the list goes on?.. Listed below will be the a detailed list of all modifications to the car and as it sits now. Also listed will be planned future modifications. The goal in this Build Log is for people to learn from my mistakes and successes. As the list below goes through I will list any issues or nuggets of wisdom I can think of? Please ask question and comments. So here we go??
P.S. Will add pics as I can find them..
ENGINE:
Stock Internals
Rod Bearings Replaced at 28K (for the love of your car if you are tracking please go ahead and replace these?.cheap insurance)
Running Motul 300v 15w50 (This weight was recommended by Bimmerworld and I have been really impressed with the Motul Product line)
Pipercross Air Filter
Alexshop Oil Cooler
CSF Radiator and Power Steering Cooler (also Bimmerworld Power Steering Reservoir), soon to be replaced with Electric Power Steering
Bimmerworld Motor Mounts
Markert Motor Works Dyno Tune
Notes: Engine has not burned oil between oil changes. I have changed the oil every 4 events or so?.
TRANSMISSION:
Stock Internals and Cooler
Temp Sensor
Replaced oil and mounts at 28k (not really need but preventative)
Evolve GTS Tune
Notes: Added trans temp sensor and have not seen temps that concern me and have yet to have a trans temp warning. Car has never used Launch Control.
SUSPENSION:
MCS 2 Way Non Remote OEM Rear Spring Location (If you are going to a True Rear Coil MCS and Bimmerworld Highly Recommend bracing the rear shock towers)
Hypercoil Springs 800F/1000R
Ground Control Race Camber/Caster Plates
Bimmerworld Suspension Pieces Front and Rear
Notes: Had KW Clubsports for a little while and really liked them but the MCS are a whole nother level. If I was to do it again MCS all day. Bimmerworld Pieces are great and really allow you to take advantage of any coilover setup because of the added adjustments you get.
BRAKES:
Stoptech ST60 Fronts only
OEM Rears
PFC 11/01 All Around
Titanium Plates for Front
SS Lines
Cantrel Motorsports Brake Ducts
SRF Fluid
Notes: I have yet to find a need to go to the Stoptech Rears. Maybe in the Future to help speed up brake pad changes but unlikely at this point. SRF Fluid is great for me as it cuts down on the need to flush the system more than once a year. Bleed every oil change. Pads are changed at a 3 to 1 ration. So for every 3 Front sets go through 1 Rear set.
EXHAUST:
Active Autowerks Catless X Pipe (slightly modified see notes)
Bimmerworld Racing Muffler (Stupid Light and grea sound)
Notes: AA X pipe comes with V Band Clamps that hang below the car reducing ground clearance. Had a exhaust shop cut those out and weld in SS piece. Solved the clearance issue.
WHEELS AND TIRES:
18x10 et 25 Apex ARC 8 (3 sets (2 dry and 1 wet)
275/35r 18 DH Pirelli or 280/650/18 Yoko A005 or 285/650/18 Cont
10 MM Spacers
AERO:
GT4 Replica front splitter with ducting
Bmw performance rear spoiler
APR GT250
Bimmerworld Carbon Whiskers
INTERIOR:
Fully Stripped except dash and headliner
Alexshop Half cage
Scrothe 6 point belts
Sparco Ergo seats
Aim MXG dash and logger
Aim Smarty Cam
OMP steering wheel
Works bell paddles
CoolShirt System ( a must)
Notes: pulled most of the interior myself. Fairly easy save the $ and do it yourself if you are decent with a wrench. Coolshirt is worth every penny if you are in a war climate. I have learned more from the Data collected by them Aim system than I have driving out right. Also makes it fairly easy to send to driving coaches who will assess the data most of the time at no charge, at least in my experience.
DRIVE LINE:
M Factory Carbon Drive Shaft
Stock Diff
Diff Cooler
Motul 75w140
Euro MDM
Notes: Diff overheats with MDM or EDC off. The overflow is a nice solution and you know when your overheating when you smell the diff fluid which smells terrible. When I ran NT01 this was not much of a problem but definitely is with the slicks.
PLANNED UPGRADES / MODS
Paddels and Steering wheel:
I have the final touches coming on a completely removable steering wheel with paddles and button plate. This will allow the steering wheel to be removed as one unit with the paddels and button plate. http://www.m3post.com/forums/showthread.php?t=1328041
Full Cage is coming with in a year or so.
Differential Cooler: Already have parts just have to fab lines and install. Bimmerworld has a kit. Installed
A/C Delete: A/C condenser blocks radiator and hurts cooling so it has to go. Compressor can be removed fairly easily on a 08 car but on anything after that you will have to get a PS pump that turn the other way. There is a thread on this that I will link to.
What I am doing is removing AC condenser and looping the lines that run into it. This removed the condenser and keep the compressor lubricated while a solution is made for the pulley and belt routing.
All above taken out when coverted to Electric Power Steering
That's it for now hope you all find this informative.
Adam
Appreciate 4
      06-18-2016, 05:13 PM   #2
roastbeef
roastbeef's Avatar
11586
Drives: E92 M3
thats cool and all, but i want to see what it looks like.
Instagram; @roastbeefmike
      06-18-2016, 05:22 PM   #3
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
https://goo.gl/photos/QQ1X16e6rFA8KKsJ7
I will update the album with more
      06-18-2016, 05:32 PM   #4
roastbeef
roastbeef's Avatar
11586
Drives: E92 M3
bearings had a few pits... i haven't seen wear like that before.
      06-18-2016, 06:20 PM   #5
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
what it was is the cleaning solution they used left water marks
      06-18-2016, 10:26 PM   #6
M3 Number 86
3221
Drives: black m3
I like it when your was black in your sig. Looked dope! Great build and waiting for your full steering wheel conversion.
      06-18-2016, 10:28 PM   #7
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
yeah but when someone pays to have it on the car....hard to complain?
      06-18-2016, 10:50 PM   #8
RickyBobby
RickyBobby's Avatar
108
Drives: M3
Did you replace the rod bearings with oem? Will you be replacing them every 28k?
      06-18-2016, 11:57 PM   #9
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
I went with VAC Coated bearing with OEM Bolts. Maybe at 50k, but most likely not.
      06-19-2016, 12:01 AM   #10
redpriest
redpriest's Avatar
2147
Drives: 2011 M3/Porsche 992 GT3RS
I know some people change the bearings yearly. I don't think you can just do them once and call it a day.
Surprised you haven't run into transmission cooling issues. How hot does it get on the track where you are? It happens to me all the time to the point where upgrading the cooler was a must have.
      06-19-2016, 12:14 AM   #11
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
Southeast: Road Atlanta, Atlanta Motorsports Park, VIR, and Barber
last weekend I saw 100 degree days and had water temps in the 235 which was causing reduced power. That's why I am removing the Condenser which should give direct air flow to the radiator.
      06-19-2016, 12:50 AM   #12
M3 Number 86
3221
Drives: black m3
Not at all! I just love that black on black. Looks mean as hell. But I'll take ad/sponsorship money too any day lol
      06-19-2016, 07:14 AM   #13
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
added a few more photos.
Car weight is 3452 with me in it so comes to 3222 weight with 1/2 Tank
      06-19-2016, 01:47 PM   #14
xchosun1x
Track Duty
xchosun1x's Avatar
266
Drives: Track build 08 E92 M3 DCT
Great build!!! Any interior pics?
      06-19-2016, 09:49 PM   #15
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
working on them. car is going in the shop this week so will get a bunch of shots. I will update the Google photos link with new ones as they come in
Adam
      06-20-2016, 12:31 AM   #16
redpriest
redpriest's Avatar
2147
How does the cool shirt chest mount in the trunk? Almost died today in 90 degree weather, and Buttonwillow this weekend at 100 degrees will be 10 times worse.
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB
Porsche 992 GT3, 991.2 GT3RS, 718 Spyder
instagram.com/titomanlio
      06-20-2016, 08:59 PM   #17
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
I updated the link with pics of the cool shirt mount. They have a tray that straps the cooler down. I used screws on into the plastic well that is in the trunk. My father has the wired bag cool shirt for his GT3 which is a great option if you don't want to hard mount it in your unstripped interior or you have multiple cars.
Road Atlanta was 100 or so the last time is was there and it felt like I was swimming when it was running. Helped keep focused and safer. Best advise is also to make the ice blocks as big as possible. I used quart sized tuppa wear to make ice blocks and then fill in the gaps with gas station ice. You don't need a lot of water, just enough to fill the lines and suit.
Adam
      06-21-2016, 12:04 PM   #18
Candide13
Candide13's Avatar
203
Drives: '11 E90 M3 ZCP 6MT AW/FR
Diff and DSC
Cool stuff, but why is the diff temperature sensitive to MDM or DSC off?
      06-21-2016, 12:48 PM   #19
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
It isn't the traction control on or off it is the fact that he diff is overworked with hard track use and slicks. the diff cooler is to extend the life of the unit.
      06-22-2016, 02:01 PM   #20
MVEED3
85
Drives: '16 GT4
Nice weapon! Can you elaborate on "Bimmerworld Suspension Pieces Front and Rear"?
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick
2016 Agate Grey GT4 PCCB LWB
2013 HP4 Competition
      06-22-2016, 02:04 PM   #21
warp10
warp10's Avatar
776
2011 M3  [10.00]
2011 28i X3  [0.00]
http://www.bimmerworld.com/BimmerWor...onversion.html
there is a rear set as well.
      06-22-2016, 03:49 PM   #22
MVEED3
85
Drives: '16 GT4
Looks the business but now I'm curious on clearances at the front. The factory tension strut is curved to accommodate steering. Is there any contact between the new tension struts and tie rod ends anywhere in the suspension or steering range?
m3post
