06-18-2016, 10:13 AM | #1 |
46
Rep 192
Benefits of using paddleshifts at the track?
Hey guys.... First time at the track with my M. I noticed via videos that most of you guys are using the paddles to shift as opposed to just letting the car take control. Obviously the car is pretty smart so I wanted to know what some of the benefits were and any suggestions on using the paddles.
Thanks guys |
06-18-2016, 05:20 PM | #3 |
11586
Rep 12,726
i haven't used auto at the track. i think its a bigger benefit to know in your head which gear you are in. it could be the difference between a smooth roll into the throttle, or a violent jerk because you're in high rpm's.
Instagram; @roastbeefmike
06-18-2016, 09:28 PM | #4 |
46
Rep 192
The problem I had at the track today (partially because I was still learning the track) is that often I would have to look down to remember what gear I was in and sometimes I would forget to downshift and I would still be in 5th by the time I tracked out.
Also I found myself wondering/worrying if I should be in 3rd or 4th gear. This took my focus away a bit from braking, driving the line etc. I just gotta get used to it!!! |
06-18-2016, 09:49 PM | #5 |
11586
Rep 12,726
It takes a little bit. Learn it all at once and you won't have to learn it later. if you're new to tracking, this is normal. i'm still a novice, but i've been to four tracks now. tracking at a course you have never been to is a new experience. you'll always feel a little lost in the first few sessions- you'll be trying to figure out shift points and trying to figure out the corners.
06-18-2016, 10:21 PM | #6 |
3221
Rep 6,218
If you shifted manually from the get go you would know because all you're doing with shifting is trying to be in optimal power band.
06-18-2016, 10:22 PM | #7 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
Honestly I don't think I looked down and saw my speed all day at Sonoma. I mostly checked oil temp here and there. I mostly rely on ear to know when to upshift and downshift now. I can also sort of see the shift lights in my peripheral vision. Would rather be focused on the road and what's going on around me in the open passing groups now.
06-19-2016, 02:15 PM | #8 | |
594
Rep 4,488
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
06-19-2016, 08:06 PM | #9 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I paddleshift. I just pull the downshift paddle until I was off the. brake. I never really kept track of what gear I was in.
And what's the point. At redline, upshift. In a turn, downshift until it won't downshift no mo'.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
06-19-2016, 08:47 PM | #10 |
46
Rep 192
After a full day and half of working with the shifting.... Gotta say the car was a ton smoother. Accelerating the car was much smoother and didn't come as a burst of speed.
Only thing was there was a couple times I would come out of the apex after a straight and realize I was still in 5th, but overall it was a huge help! |
06-19-2016, 10:35 PM | #11 | |
594
Rep 4,488
06-19-2016, 10:38 PM | #12 |
11817
Rep 23,187
06-19-2016, 10:46 PM | #13 | |
Stop the hate, get a V8
3850
Rep 8,625
Spend your time focusing on learning good technique the first few times. Take advantage of any in-car instruction they have available. Once you feel comfortable with the racing line and how the car behaves, start adding more speed, then start playing around with shifting. My advice would be to leave it in automatic mode for now. You can still gun it down the straights.
Past: 2011.5 M3 sedan ZCP |
06-20-2016, 06:18 AM | #14 | |
1571
Rep 8,076
06-20-2016, 12:28 PM | #16 |
3850
Rep 8,625
Depends on the DriveLogic mode. In higher-numbered modes, yes, it will hold gears much longer.
06-24-2016, 05:25 PM | #17 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
At a BMW CCA track event at SMMR the instructor made me drive in auto mode. It was bizarre. Even with the GTS DCT software in S5, RPMs would drop too low for my taste, and I usually drive one gear higher than most because of my power level. Auto mode at the track sux on the M3 DCT.
Now with my Porsche PDK I drive in Sport Plus auto mode and it's perfect at the track. RPMs do not drop below 4,000 ever. In the meat of the powerband all the time.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
06-25-2016, 08:47 PM | #19 |
115
Rep 1,470
When my students have a PDK and use sport plus, I swear I am going to get whiplash. A 991 GT3 shifts so hard that it snaps my head back. I am the opposite of longboarder's instructor. I want you at least using the paddles yourself if you want to move up. Otherwise you are not doing much, especially with the nannies on.
I run mine in S4, DSC off, but with paddles.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
06-25-2016, 09:20 PM | #20 | |
594
Rep 4,488
06-25-2016, 09:59 PM | #22 |
11817
Rep 23,187
