06-15-2016, 02:52 PM | #1 |
Stop the hate, get a V8
3850
Rep 8,625
Unable to measure pad thickness; would you leave these on?
My current living arrangements don't really permit me to be removing the wheels and measuring pad thickness, the best way to determine pad wear. I have another track day at GingerMan coming up in about 2 weeks.
The two photos below show about 1,000 miles of street driving and two track days (one of which was 95 degrees). I am thinking these pads are fine for at least one or two more track days. Agreed? Apologies for potato photo quality, but it's tough to photograph these with a flashlight in one hand in a dimly-lit garage.
Past: 2011.5 M3 sedan ZCP |
06-15-2016, 03:37 PM | #2 |
594
Rep 4,488
Absolutely! Those pads have a huge amount of material left. If that's an endurance compound, you probably have another 6 track days left in them, give or take. Most race pads can be run basically down to the backing plate, though Pagids are a notable exception in that from what I've read, after half the material is gone, the performance drops significantly.
But next time, maybe make it easier on yourself and others by briefly parking somewhere outdoors during the day for the photo op.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 06-15-2016 at 03:43 PM.. |
06-15-2016, 03:37 PM | #3 | |
467
Rep 818
That will give you a good idea how much pad is left without taking the wheel off. |
06-15-2016, 03:42 PM | #4 | |
3850
Rep 8,625
Good tip, but sometimes you get weird shadows. I also didn't want to lose my spot in the garage. They're not an "endurance" compound, FWIW. Because of that, I plan to pull them once they get below 25%.
06-15-2016, 03:44 PM | #5 |
594
Rep 4,488
Ah yes, forgot you were running StopTech Street Performance pads. In that case I'd say you have at least 2 days left on those, maybe 4 depending on the track and your driving. So I'd say buy your next set of pads now and take them with you to the track boxed up in case you need to quickly swap them in (easy with that BBK), but definitely don't write those off this early.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
06-15-2016, 03:57 PM | #6 |
Track Whore
542
Rep 1,640
They look pretty thick still, dude. Not sure of how aggressive you are with your braking but those most certainly have a track day or two left in them.
06-15-2016, 04:07 PM | #7 | |
3850
Rep 8,625
That was my plan -- don't want to get into a situation where the pads disintegrate and I have to either sit out the rest of the day, or try to drive home by only using rear brakes.
06-15-2016, 04:30 PM | #8 |
711
Rep 3,251
Easier and more accurate way to check pad thickness is to take the wheels off and look at the pads from the caliper opening from the outside (where you drop the pads into the caliper when switching pads). That way you can see the inner pad as well. Depending on the airflow to the caliper, your inner pad might wear faster than the outer ones.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
06-16-2016, 09:39 AM | #9 |
Rep 32
Agreed - there seems to be plenty of pad left for now. I have always gone to new pads once the pad material and the backing plate are about the same thickness. Yes, theoretically you can run them down farther, but without being able to see the inside pad and the reduced heat dissipation, I am not willing to take that risk. I had a buddy that ran his down to the backing plate (the inside wore faster than the outside, so he couldn't see it) and stuffed his Porsche 993 TT into the wall.
I don't skimp on brakes or tires as they are what keeps the car on the race surface and the shiny side up. -Skip
Current: 2009 e92 M3 6T Black/Black
Past Mistresses: 1991 Porsche 964 C2 1997 Porsche 993 C4S 1997 328is, 2001 330xi |
06-16-2016, 11:27 AM | #10 | |
2760
Rep 5,483
06-16-2016, 12:04 PM | #11 | |
594
Rep 4,488
06-16-2016, 12:29 PM | #12 |
3850
Rep 8,625
What would cause the inside pad to wear so much faster?
06-16-2016, 12:52 PM | #13 |
467
Rep 818
06-16-2016, 01:34 PM | #14 | |
594
Rep 4,488
06-16-2016, 01:48 PM | #15 | |
3850
Rep 8,625
Thanks. I was under the impression that the ST40 calipers are designed to channel air towards the pads? It's referenced in the installation guide. Is it just not very effective?
06-16-2016, 01:59 PM | #16 | ||
594
Rep 4,488
06-16-2016, 02:28 PM | #17 |
846
Rep 1,679
Just bring a new set to the track so you are never in that situation. Worst case you miss a session while waiting for everything to cool down.
06-16-2016, 03:28 PM | #18 |
711
Rep 3,251
Don't buy into the marketing. No caliper can re-direct airflow without proper brake duct or scoop, which this car doesn't have.
