06-08-2016, 09:53 AM | #1 |
300
Rep 247
COTA Track Day: Update with incar video
While I can spin a wheel, I have never participated in a track day. Although I have done some hooning on the side and consider myself to be a good driver, it looks like it is mandated that you use an instructor if you cannot prove track experience.
Anyone here taking part in this event? Worth it? http://www.motorsportreg.com/events/...7#.V1gvU-T_pvm I have been to F1 and MotoGP and I can confirm that COTA is a pretty sweet track so will more than likely pull the trigger. Any advice or info would be great. Thank you. Last edited by Zulu Saffa; 06-21-2016 at 11:21 AM.. |
06-08-2016, 09:58 AM | #2 | |
40
Rep 164
06-08-2016, 10:13 AM | #3 |
Stop the hate, get a V8
3850
Rep 8,625
Not sure what your car's setup is, but I have heard from folks on here that COTA is brutal on tires and brakes. Definitely take advantage of the instruction.
Past: 2011.5 M3 sedan ZCP |
06-08-2016, 10:26 AM | #4 |
300
Rep 247
Other than the exhaust, car is stock. Installed PSS about 3 months ago, so figured they would get pretty tore up considering the heat here. Thanks.
06-08-2016, 11:17 AM | #5 |
3850
Rep 8,625
The PSS will get greasy as the sessions go on, but they're still really predictable. I would take full advantage of the instructor and focus on technique rather than driving at 10/10ths. The PSS will be more than adequate for you.
06-08-2016, 11:32 AM | #6 |
300
Rep 247
06-08-2016, 12:08 PM | #7 |
257
Rep 1,660
COTA isn't bad on tires, especially if you are new to DEs. First year I ran I was completely stock. Last two years I've upgraded brake fluid, Hankook RS3s and a slightly more aggressive brake pad.
It's a great track, and I love going each year. You should def do it!!
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
06-08-2016, 12:32 PM | #8 |
Skittles, OT OG
2337
Rep 649
Do it. After one weekend at the track, you'll look back at this post and laugh at the fact that you thought you were a good driver. Listen to your instructor. He will give you lots of feedback to sharpen your skills. And don't beat up on yourself too bad when you have to point a Miata by because you're holding him up in the corners. It happens. We've all been there.
06-08-2016, 12:55 PM | #9 |
594
Rep 4,488
Yes, several people here will be going to the Trifecta; I think there's a thread in this section, perhaps a few pages down by now, discussing it. You'd definitely want an instructor even if it were optional for novices, which it isn't for the safety of everyone involved. I'd recommend watching cockpit videos from CotA HPDEs (plenty on YouTube) just to memorize the look and sequence of the corners beforehand. They look very different as compared to just looking at a track map or observing from the grandstands, and that familiarity will drastically accelerate your learning and enjoyment at the event if you're not spending half a day or more thinking, "Wait, which corner is coming up? / Oh crap, I thought I was setting up for that other one!" Don't focus so much on the line you're seeing the car drive, since that may or may not make sense for you, your car, your instructor's guidance, etc; just try to get to a point where you can play the track back in your head.
Other than that, get your tech inspection done, definitely upgrade your brake fluid and also ideally your pads if you're willing to, purchase track insurance if you feel the need, leave your ego at home, and listen to your instructor, and you'll have a great time! Not sure what specifically you're talking about when you say you can spin a wheel and that you've hooned around, but if you're referring to drifting, powersliding, J-turns, and stunt stuff like that, none of that really comes into play driving on a track except pretty indirectly (e.g. having a sense of weight transfer dynamics), so I would recommend approaching this on the assumption that you have no relevant prior experience. You'll probably learn faster. Also, try to catch a ride with an instructor toward the end of the event. I'd offer to give you one myself if I were going to be at that event. It's brutal on brakes, but not tires, especially for a novice. TWS by comparison is brutal on tires but not brakes.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 06-08-2016 at 01:14 PM.. |
06-08-2016, 01:11 PM | #10 |
Ultimate Driver for the Ultimate Driving Machine
146
Rep 1,146
COTA is a lot of fun, great pavement. went to BMWCCA event before and it was very well organized. especially with the hot weather, breaks and tires wear quick. I wanted to do 2 days but dont have the budget for it. I would suggest using aftermarket brakepads. You will hit close to 150mph on the back straight.
I used PSS, it worked out perfectly. [u2b]https://www.youtube.com/watch?v=Fqci6KWm3sk[/u2b] https://www.youtube.com/watch?v=Fqci6KWm3sk
BMW M3 E92 - Silverstone II BPM Sport Stage II Tune + Test Pipes, GTS DCT Tune |
06-08-2016, 01:14 PM | #11 | |
594
Rep 4,488
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
06-08-2016, 01:17 PM | #12 | |
146
Rep 1,146
Also, if there is an M3 in front of you, dont follow exactly what he is doing because the cars are the same, you have no idea what tires, suspensions and other mods he might be riding on. I followed an M3 with such mods before, i was lucky to not pay for my inexperience
06-08-2016, 01:35 PM | #13 |
300
Rep 247
Greatly appreciate all the feedback and advice. Ego will certainly be checked. Done a few track days on 2 wheels on a 1000cc and, like a few of you point out, have been passed by far lesser machines. Takes no skill to go fast in a straight line.
Lastly, and probably the biggest hurdle, is to get my domestic managers approval. Looks like Friday will be the day. Hope to see some of you there. Cheers... |
06-08-2016, 02:46 PM | #14 |
303
Rep 1,140
Drives: Something something racecar
You can also do Saturday and Sunday for $800.
06-08-2016, 08:00 PM | #15 |
3850
Rep 8,625
Jesus Christ, $500 for one day or $800 for two. Even Road America costs less than that. Then again, they've gotta pay for that facility somehow...
06-08-2016, 09:23 PM | #16 |
594
Rep 4,488
CotA costs $50K/day to rent. The CCA price is actually one of the lowest because they're a non-profit. Typical prices are $1000-1100 for 2 days.
06-08-2016, 11:06 PM | #18 | |
303
Rep 1,140
Also, skip to post 72 in this thread. Another insurance company, which I'm guessing is new to HPDE insurance, responded to my post and offered their coverage. I was going to post a thread here asking about them but didn't get a chance to. http://www.m3post.com/forums/showthr...1270591&page=2 |
06-09-2016, 05:12 AM | #19 |
11586
Rep 12,726
Lockton is easy and they offer a discount for being a Bmw CCA member. If you do enough track days, it becomes significant.
Instagram; @roastbeefmike
06-09-2016, 02:44 PM | #20 |
239
Rep 479
Yes you do need an instructor, if its your first time at COTA. I had to get one my first time there. The instructors are very useful and will show you the driving line and other pointers. That track is very fast, the back straights you would hit 140mph plus, and its very hard on the brakes. Every 15 mins of of my 20 min sessions I would get brake fade most noticeable on turn 12. I recommend to check your brake pads and fluids. Its going to be hot so make sure your cooling is good. I was hitting 250 oil temps at COTA which is fine... but anything higher I would get worried.
06-09-2016, 08:27 PM | #21 | |
146
Rep 1,146
Oh and when on track, turn off your AC.
