06-06-2016, 09:28 AM | #1 |
15
Rep 89
SOLD
I have (4) 18x10 et33 Apex EC-7 wheels with Nitto NT-01 tires in 275/35 for sale. The wheels have factory BMW TPMS sensors. These will fit an F80/82/83. They may fit an E90/E92/E93 but you'd have to check yourself to be sure. These clear the factory steel brakes, I am not sure if they clear the ceramic brake option (pretty sure they don't). There are a couple of small nicks on the wheels, but they are round and not curbed. They were used for track only, and have 500 miles at most on them. The tires have about 1-2 days left before needing replacement, as the Nittos will wear down to the cords. The benefit of running this particular wheel size is that you can run a square setup, which allows you to rotate front to back and mitigate tire wear. The rears are a perfect fit, and the fronts require a 5mm spacer to clear the strut. I am including the required 5mm spacers as well as extended wheel studs (both are from Bimmerworld) and lug nuts. $1200 obo takes them all, picked up from Old Lyme CT or Rocky Hill CT. I can potentially meet you elsewhere for $1/mi additional. Old Lyme is 2 hrs from NYC, 2.5 hours from Albany, 2 hours from Boston and 1 hour from PVD. On top of the wheel/tire package, I also have a set of brake pads to accompany these. They are Carbotech XP12s (1609) for the front and XP10s (1656) for the rear. The fronts have 2 days of use, the rears have 5 days of use. The fronts will go another 3-4 days, the rears are well under half worn so you should get at least 5+ more days out of them. They are a perfect match for these tires, and performed extremely well. Lots of initial bite, no fade and great modulation. New, the fronts are $329 and the rears are $279. I'll let them go for $300. I'll also include a second set of fronts that have a little meat left on them (good for driving to/from the track or for transport/backups). Take the entire setup for a combo price of $1300, saving you $200! I'd ship the pads separately but I will not ship the wheels. Selling because my race car is back on track so I don't need to take my M3 to the track any longer. Last edited by Ryan239; 07-19-2016 at 09:52 AM.. |
