06-06-2016, 12:08 AM | #1 |
49
Rep 396
6mt not shifting
Hi guys n gals, I have a question about my f80. So I have had my car for 2 months, it's a 15' with 18k miles now(purchased with 15,500 miles).
- I typically drive in sport/sport/sport If I redline(or get closer to redline) 1st n shift into 2nd, my tranny just goes dead. Like wont shift into any gear(quite embarrassing, seems like your missing shifts), it's happened a handful of times. I remember reading somewhere on here bout something like this, but can't find it, anyone know the issue or fix? Greatly appreciate the help, thanx
15' AW/BLK F80 M3, 6spd
BM3, VRSF DPs, BMS Intakes, KW HAS |
06-06-2016, 12:15 AM | #2 | |
Roofless & Ruthless
1356
Rep 1,480
Drives: 2015 AY 6MT F83
I don't really understand, you mean you can't get it in second? Never had that problem..
06-06-2016, 11:19 AM | #4 |
779
Rep 961
Drives: G87 M2, G20 330d, Brabus Smart
Sounds like you're trying to yank the shift lever. Ease up and be more deliberate. There's a notch you can catch if you are too violent.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
06-06-2016, 11:04 PM | #5 |
49
Rep 396
But why would it prevent me from going in to third?
06-07-2016, 08:33 AM | #6 |
2634
Rep 2,809
06-07-2016, 08:40 AM | #7 |
1862
Rep 3,661
Your post makes no sense. Is it grinding?
If you don't push the clutch all the way in, it should grind at the least. Not sure what you are trying to describe here.
2016 F80 M3 AW/SO (Manual) - Picked up at the Welt 08/28/15 My Amazing European Delivery Story |
06-07-2016, 09:25 AM | #8 |
779
Rep 961
It shouldn't. I was referencing the 1-2 shift issue some people have had.
You're not giving us a whole lot to go on here. Sounds like a trip to the dealership may be the best course of action for you.
@DBV_
06-07-2016, 10:50 AM | #9 | |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
06-07-2016, 11:00 AM | #10 |
310
Rep 408
If the better wording is "my car goes dead" then I'd wager DSC cutting power after engaging second gear and applying full throttle (I'm assuming full throttle because of the OP's comment about redlining first gear).
06-07-2016, 08:04 PM | #11 |
49
Rep 396
Basically it locks into gear and acts like it's in neutral. It's not my first manual car, I've owned over 35 cars in 13 years, all kinds and at least 10 have been manual with two with stage two clutches. I give it has and all it does is rev and that's it.
06-07-2016, 08:11 PM | #12 |
545
Rep 1,132
You can't shift as fast in these cars, give it half a second before you fully bring it down into 2nd. For me at least it works. I know on my E46 m3 you can shift instant, on my f80 you have to go slower.
06-07-2016, 08:21 PM | #13 | |
49
Rep 396
Anyone know if a short shift kit will help?
06-07-2016, 08:51 PM | #14 |
545
Rep 1,132
First couple shifts after changing over from the e46 m3 to the f80 m3 when i tried to "rip" first to second it would grind. Maybe its just my car, 17k miles, but you have to be a bit slower. I have even gone so quick I go from first to redline and try to shift down to 2nd only to find 2nd didn't engage and when I press the gas it free-revs. All other gears you can shift as fast as you want. I know have the timing down right to get it most of the time, without loosing momentum, there is so much torque in first taking a second to shift 2nd won't loose speed.
06-07-2016, 10:33 PM | #15 | |
49
Rep 396
Thanx
