05-30-2016, 02:09 PM | #1 |
46
Rep 192
All of you "do it yourselfer's" chime in please!!!
Hey guys, I thought that this was the best place to post since you track guys do 90% of the minor work yourselves. Now that I have gotten into track days which involves frequent work on the vehicles especially brakes; I need proper tools to ensure everything goes as smooth as possible.
I have a floor jack and just the very basic tools for around the house. I am going to order the Barvarian brake bleeding kit, a torque wrench, and needed tools to replace brakes. I just got the Impact lug nut set to protect the wheels when removing and mounting the wheels. What tools would you say that is a must and if there are certain brands or combo kits you recommend.... Let me know and much thanks!!! Last edited by crash32; 05-30-2016 at 02:17 PM.. |
05-30-2016, 02:21 PM | #2 |
Retired Curmudgeon
2985
Rep 4,047
Get the Motive brake bleeder kit.
Buy high-quality tools for things you repeatedly use or that cut metal (drill bits, etc.). Rarely used stuff can come from Harbor Freight/ebay (ball joint removers, etc.) as you'll likely only use them once or twice before getting a different toy to play with. Don't forget safety gear like jack stands, safety glasses, gloves, etc.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
05-30-2016, 02:38 PM | #4 |
1478
Rep 2,672
+1 on the Motive brake bleeder, I've had mine for 8+ years now and it's one of my most frequently used speciality tools.
I would also pick up a few BMW jack pad adaptors, example. Then I recently purchased a cheap backup torque wrench on Amazon but like my basic Craftsman torque wrench much better. Annoying they don't come with cases anymore (only reason I didn't buy another Craftsman). You'll need a breaker bar, any brand will do but again I have a Craftsman and like it. Then a brake spreader of some sort, the Lisle from Amazon is great and cheap. A more recent purchase is my Craftsman Heavy Duty cordless impact wrench with XCP battery and charger, it's quite nice but more of a luxury to have. Speeds up wheel/tire swaps and great for breaking high torque bolts loose, such as caliper bolts. And a good fan to keep you cool while working.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
05-30-2016, 04:20 PM | #6 | ||
303
Rep 1,140
Drives: Something something racecar
I have this tool box from HF. Very convenient, as it has a lot of hand tools I need to work on my car. I never use the SAE tools, so that's kind of a waste but no complaints for $120.
Also have a tool bag to store misc tools like wrenches. Quote:
I need to get me a fan. Working in the garage in Texas heat is no fun. |
05-30-2016, 04:22 PM | #7 |
46
Rep 192
In regards to the Lisle brake spreader ... I see 3 of them available on Amazon. One is the dual piston, other is the speedy brake spreader, and the last one is the quick spreader.... All of them have different model numbers. Which one should I get?
05-30-2016, 04:45 PM | #9 | |
22
Rep 145
Also, I typically buy gear wrench tools for the garage and then bring craftsman or HF to the track. I think HF is fine for things you use every so often. For stuff you use all the time buy quality name brands you've heard of. Going to be comparable until you get into high dollar stuff. |
05-30-2016, 04:52 PM | #10 | |
846
Rep 1,679
05-30-2016, 05:12 PM | #12 | |
379
Rep 875
http://www.longacreracing.com/produc...0+by+%C2%BD+lb |
05-30-2016, 05:49 PM | #13 |
594
Rep 4,488
I have a CDI torque wrench, which is apparently a Snap-On sub-brand. Mine goes from 20-150 lb-ft, no complaints after several years. Sunex also has some great impact sockets -- extra long, thin-wall, and plastic protection sleeve. Highly recommended. The 17mm version is the 284917, available on Amazon separately and as part of a 3-piece set that also includes 19 and 21mm sockets. The nice finish isn't very thick so it'll chip easily, but they work very well especially with wide rear wheels since you don't need a socket extension and you can use the socket to tighten/loosen most of the way by hand more quickly than when you have a tool attached.
I bought an analog dial pressure gauge with a bleed button from a trackside shop years ago. Can't remember the brand, but I can't imagine they're all that different. Other than that, I'd recommend a pair of jack pad adapters (ECS Tuning) to fit into the rectangular jack point on each side in case you ever double jack, a 1/2" drive breaker bar, a hook and pick set, a pry bar, a small mallet, and a 3/8" drive ratchet set. For that last, I got a Craftsman Max Axess set whose passthrough function has come in handy several times both on the car and around the house, and I bought an adapter to use regular square drive bits with it. Those tools plus my OTC Racing Jack and cigarette lighter air compressor on their own were enough for me to change my brake pads on my StopTech BBK and other basic track tasks. Never needed a pad spreader -- would have made things a bit easier but didn't want to drop the cash on one. I also never used a brake bleeder. Get Castrol SRF and you won't have to bleed between annual flushes anymore. If you're very serious, look at JackPoint Jackstands. Pricey but makes things much simpler.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
05-30-2016, 06:09 PM | #15 | |
594
Rep 4,488
05-30-2016, 06:11 PM | #16 | |
36
Rep 209
05-30-2016, 06:54 PM | #17 | |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
05-30-2016, 07:11 PM | #18 |
Track Whore
542
Rep 1,640
If you can spring for it, get a lift:
Torx set: |
05-30-2016, 07:14 PM | #19 | ||
11586
Rep 12,726
Instagram; @roastbeefmike
05-30-2016, 09:32 PM | #20 |
46
Rep 192
The house that is beig built now will have a lift. I have been doing research and will probably post a question about it later. The lift will be in the 3rd garage where 2 vehicles will be stored in one space.
I wanted to know if you could get a 4 post lift which would serve as storage, but then somehow have it function as a 2 post lift to get the wheels off the ground if ever needed. |
05-30-2016, 09:36 PM | #22 | |
11586
Rep 12,726
