05-17-2016, 07:05 AM | #1 |
46
Rep 192
Confused about front and rear brake pads
Hey guys after my post and doing research I have decided to purchase PFC08 pads for my M3 along with Castrol srf fluid for it's first track day.
I am a bit confused as when I googled these pads for my car I had to go to the third page of results to find rear pads. 95% of the stuff that they sell are front pads. After doing some research I have found that some people just focus on the front braking system. Should I get pfc08 pads for the front and rear or just the front? Sorry for the dumb question, but I wanted clarification before placing the order. Also, seems like the price that I am finding for the front pads are around $230. What is the best place to order them from price wise? Thanks guys! |
05-17-2016, 08:17 AM | #2 | |
Stop the hate, get a V8
3850
Rep 8,625
The front brakes are doing much more work than the fronts. I don't know how the proportioning valve is set for the M3, but it's typically 70% front / 30% rear. At low speed and around town, your rear brakes might not even be stopping you at all. I assume you are going to swap the PFC08 pads for track days and run a mild street pad? If so, just put the same compound street pad on the rear. It should be sufficient for the track. Many of us take that route. There's nothing wrong with running PFC08 in the rear, but if you are swapping pads at the track it will just take longer for a very marginal improvement. I certainly wouldn't want a more aggressive pad in the rear than the front. (in other words, don't just run PFC08 in the rear all the time but swap fronts out for track use) I always order from Zeckhausen. Decent prices and outstanding customer service. They know their stuff so don't hesitate to ask for help. Track pads are going to be pricey but you'll get what you pay for.
Past: 2011.5 M3 sedan ZCP |
05-17-2016, 08:56 AM | #3 |
46
Rep 192
Thanks a ton for your input. Is it ok if I order new OEM pads for the rear instead of mild street pads (whatever that might be)? Just to clarify... I should be good ordering the pfc08 for the front pads and oem for the rears? Sorry, but when you said mild street pads I was not sure if the oem pads fell under this category.
05-17-2016, 10:46 AM | #4 | |
DSC Off!
304
Rep 718
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
05-17-2016, 11:02 AM | #5 |
1478
Rep 2,672
^+1
And actually Stoptech Street Performance pads are now sold as "Stoptech Sport" pads, so you should get those. Stoptech Brake Pads
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
05-17-2016, 11:49 AM | #6 |
3850
Rep 8,625
The StopTech pads should be fine in the rear. They're dirt cheap and should last pretty much forever. A slight step up would be the Ferodo DS2500, but they're way more expensive.
05-17-2016, 01:26 PM | #8 |
DSC Off!
304
Rep 718
They are completely quiet with a little less bite. They will not leave pad deposits on your rotors like the OEM pads will. The DS2500 are great, too, but they may squeal and are more pricey.
05-17-2016, 01:29 PM | #9 |
1478
Rep 2,672
Perfectly quiet.
05-17-2016, 01:44 PM | #10 | |
80
Rep 168
05-17-2016, 03:18 PM | #11 | |
3850
Rep 8,625
Yes, they are the same noise level as OEM. The DS2500 didn't squeal on my last car, it had more of a grinding/crunching noise when really cold. Still tolerable and barely noticeable over standard road noise/stereo.
05-17-2016, 06:10 PM | #12 |
46
Rep 192
If the Stoptech street pads have less bite than the oem pads then why are you guys using them for the rears? Is it a cost issue?
Do they have a much longer life than the oem pads with the cost of wee bit less performance? |
05-17-2016, 06:38 PM | #13 | |
80
Rep 168
05-17-2016, 10:49 PM | #14 | |
3850
Rep 8,625
The argument would be that too much initial bite makes pedal modulation/brake feel poor. It might impress people because the car feels like it's stopping faster, but I would much rather have linear response.
05-18-2016, 03:25 PM | #16 |
Skittles, OT OG
2337
Rep 649
If you've never driven on PFC 08s before, please be aware that the cold bite is very weak. I would say the initial cold bite on my street pads is more aggressive than the 08s. When you get on track, be sure to get some heat into the brakes before trying to dive into the corners.
05-19-2016, 10:01 AM | #17 |
///M Powered for Life
11489
Rep 10,329
I've tried using different pads front and rear. I do not recommend it.
I was running PFC12 (equivalent of PFC08) front and PFC Z rated (similar to Stoptech street) in the rear. The bias was clearly off, which is inevitable. It's a compromise solution, but like others say, at the track many make compromises I ended up complaining about the braking performance of my car to the vendor and upon checking I realized I had mistakenly put the PFCZ pads in the rear instead of the PFC12s! Before I had a bbk I'd swap all 4 brakes to PFC08. It's a pain to do but it provides the best performance. If I had a month between track days I'd swap them, if not I'd just use them on the street. There is plenty of bite in those pads for street use but they are noisy when coming to a full stop. Last edited by SYT_Shadow; 05-19-2016 at 01:59 PM.. |
05-19-2016, 10:45 AM | #18 | |
M3/Raptor
48
Rep 302
05-19-2016, 12:51 PM | #19 |
594
Rep 4,488
I ran PFC 08 in front and StopTech in the rear on track for years without any issue, and I fully admit I did that rather than PFC 08 all around so that I'd only have to swap pads in my front BBK rather than also dealing with the rear where the whole caliper has to be removed. So OP if you're up for swapping all around, full PFC 08 would indeed be superior, but it's not completely necessary IMHO. But get rid of OEM or you'll mess up your rotors with OEM pad deposits. That issue which didn't go away for a month after a track weekend, so I took it to the dealer, who goodwilled replacement pads and rotors, but I knew they wouldn't keep doing that, which is what prompted me to get StopTech pads in the first place. I initially ran those all-around on track until I reached the advanced groups, which is when I got the 08s.
Good note about the 08s not being great cold. They're not terrifying, but they definitely lack some bite. The StopTechs on the other hand work just like OEM on the road in all respects and resist fade and risk of uneven pad deposits much better than OEM on track. They don't last quite as long, but they're inexpensive. Another option that may be available in E9x M3 sizes is PFC 11 all around. I'm consistently reading that they're almost completely silent on the road, work fairly well cold, don't dust more than typical street pads, are friendlier on rotors than 08s (which are fairly hard on rotors in exchange for long pad life, especially drilled rotors), last nearly as long, and bite a bit harder. Lots of Porsche track rats seem to run them all around full-time as a result.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
05-19-2016, 12:56 PM | #20 | |
Skittles, OT OG
2337
Rep 649
Brakes are never something you should cheap out on. Forget the entire performance benefit. The safety issue is what you should be concerned with. You need to make sure you can slow your car down safely. Any type of street pads does not belong on the track. |
05-19-2016, 01:57 PM | #21 | |
11489
Rep 10,329
05-19-2016, 02:50 PM | #22 | ||
594
Rep 4,488
