05-05-2016, 12:12 PM | #1 |
303
Rep 1,140
Drives: Something something racecar
What did this guy do wrong?
My guess is that braking too late/close to transition contributed to it? Sorry, physics isn't my strongest subject, so I had to ask.
I take the same line and shed some speed at around the 0:14 mark, and I don't touch the brakes again until I have passed the transition. |
05-05-2016, 12:30 PM | #2 |
379
Rep 875
Looks like the guy inadvertently trailbraked, assisted by the slope and the bump immediately after helped out some more. By the way, was he racing into the pits or is that the course?
05-05-2016, 01:15 PM | #3 |
Stop the hate, get a V8
3850
Rep 8,625
Man, that looks tricky. You're coming in very fast on a banked surface and transitioning quickly to a level surface while turning. The pavement doesn't look like it's very smooth or well-maintained either.
I've never driven such a corner, but my guess is that right as the front of the car transitioned to that level surface, the suspension loading made the rear of the car get very light -- and when the wheel is turned and the rear lightens up, you get oversteer. He hit the brakes which only lightens the rear further. I could be wrong though. We also don't know how the car was setup, condition of the tires, etc. Having watched that video a few times now, and thinking back to what I learned at some tracks with "jumps", I probably would have not been on the gas or throttle through that entire section. Anyone else have thoughts?
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 05-05-2016 at 01:25 PM.. |
05-05-2016, 01:46 PM | #4 | |
594
Rep 4,488
You always, always, ALWAYS cross that transition at TWS in that direction on at least maintenance throttle to keep the rear end more planted and with the steering wheel pointed straight ahead or close to it, and the farther away from parallel to the direction of the transition your chosen line takes you across it, the more critical that is. That guy came in from the high side, which is common for M3s out there, but he should have braked in a straight line prior to turning in, not braked while turning in and hanging onto the brake across the transition. And on a side note, he also should have transitioned from throttle to brake more quickly.
Fun fact: TWS was originally built to run the opposite direction, but it was determined that when crossing that transition in the opposite direction in a high-horsepower car, they would be going fast enough (thanks to the T2 sweeper that precedes it in that direction) that the rear end could get loose and send cars up into the wall at the top of the oval. Amateur organizations still ran it that way on occasion for HPDE variety (two tracks in one location!), but at a recent clockwise event someone had a seizure behind the wheel and apparently damaged some critical part of the track right around that transition, so even they're not allowed to run clockwise anymore. When I was running clockwise I would try to get pretty parallel to the transition and limit my throttle while driving across it. Quote:
The track is an absolute blast though -- very fast, with long straights that reward high horsepower cars as well as fairly light braking zones and fast corners that reward momentum cars. Not especially challenging compared to a track like CotA, but still a huge thrill. Unless of course you go off, where the very rough and patchy ground can do a number on your car in many areas -- and when it's wet it's even worse.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 05-05-2016 at 02:23 PM.. |
05-05-2016, 02:09 PM | #6 | |
594
Rep 4,488
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
05-05-2016, 02:19 PM | #7 | |
General
63360
Rep 24,668
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
05-05-2016, 05:01 PM | #8 | |
303
Rep 1,140
The track is pretty rough. The transition is scary IMO, and I can't imagine coming off the banking at full throttle, which some people seem to do in videos I've watched. I just give a little bit of throttle. I've had the rear become squirrelly under braking well after the transition, but that's it.
Video of me on track Quote:
I'm still hoping track doesn't close after June. My favorite turn is T7. Really scary at first, but now it's really fun. |
05-05-2016, 05:52 PM | #10 | |
594
Rep 4,488
I tend to prefer the high side turn-in because you can get more of your rotation done for T2 earlier that way, you have a great vantage point to check your placement on track, and the cell tower makes for an excellent reference point with that line. On the other hand, I suppose staying low means the transition might not be as rough (maybe those Corvette owners got tired of scraping their aero undertrays?), you probably have to brake less or not at all until you're into the sweeper, and as long as you can still get the line right despite having a crappier vantage point from down low, I bet you're faster overall from prior to the transition until T2 exit by turning it into one giant corner rather than braking on the oval for a sharper turn-in, straight-lining the first half of the sweeper, and braking hard before going through the second half.
05-05-2016, 07:30 PM | #11 | |
3850
Rep 8,625
Regardless, that transition looks scary and the track's litany of patchwork doesn't exactly scream "safety".
Past: 2011.5 M3 sedan ZCP |
05-05-2016, 09:52 PM | #12 | ||
303
Rep 1,140
05-05-2016, 10:21 PM | #13 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
He was coasting down the hill. Probably doesn't trust the throttle...but throttle will save you.
Coming high off the bank is pretty much bottoming out your suspension. When I ride in cars that take that line, it jars my back. I think it's really hard on the car. I take the low line in both directions but there's a big bump both ways in the brake zone. Doesn't hurt my back and is easier to manage but it's something to be aware of. Most of all...you're not in the ditch or not taking out the corner worker station if you lift. TWS was in crappy shape the last time I drive it 2 years ago. Can't imagine it's much better. I've seen so many crashes at TWS.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
05-06-2016, 07:54 AM | #14 | |
746
Rep 1,848
I actually reset the track record for TT3, but Greg Smith came through a couple seconds later and beat me by 0.07 seconds. As others mentioned, I think the mid to high line is too unsettling to the car. You have to be on some form of throttle coming off the transition to keep ass end planted. Coasting works for some people. You can see the driver actually brakes in the transition. Worst possible place. |
05-06-2016, 09:29 AM | #15 |
3221
Rep 6,218
He got some lazy feet during the spin too. Shouldn't you be both feet in?
05-06-2016, 10:20 AM | #16 | |
303
Rep 1,140
I'm gonna try your approach to T1 in two weeks. Will probably ask an instructor with an M3 to come with me for guidance. At my first event I scared the shit out of my instructor by braking at transition, and he wouldn't let me go past 110 on the straight the whole weekend because of that. That's what I naturally do when I spin out during autocross. |
05-06-2016, 01:05 PM | #17 | |
594
Rep 4,488
05-06-2016, 02:21 PM | #18 | |
3221
Rep 6,218
05-06-2016, 02:30 PM | #20 |
Track Whore
542
Rep 1,640
No thanks on that transition!
Looks like you hit that at 80mph Kong Sheng Han, but far lower on the hill than the driver in that first video posted. It looks like the left side is far smoother than the right side of that transition? |
05-06-2016, 02:45 PM | #21 | |
594
Rep 4,488
Once you've lost control of a car beyond any reasonable chance of recovery, applying the brakes is generally the way to get your car stopped as quickly as possible (especially with ABS), plus it keeps it from rolling after it does stop. Putting the clutch down will prevent driveline damage caused by your wheels rolling backward while you've got a forward gear engaged, e.g. jumping your timing chain. In my second ever track weekend (first in my M3 and first in the rain), I tried DSC off after watching my instructor do it, and even though I thought I was driving well within the limits, it turned out MDM had been doing far too much work for me earlier. I spun it twice in one lap, and both times I didn't get the clutch in before the car started rolling backwards. Fortunately the speeds were low enough that both times, my car just stalled and threw an engine malfunction code that turned out to be nothing, but I probably got very lucky both times.
05-06-2016, 03:06 PM | #22 |
303
Rep 1,140
I was still warming up the motor. Skip ahead a little. I transition at 105-115 when warmed up.
