05-01-2016, 02:06 PM | #1 |
19
Rep 45
275 square / spacer question
05-01-2016, 02:45 PM | #2 |
303
Rep 1,140
Drives: Something something racecar
Not buying 17s anymore?
05-01-2016, 03:05 PM | #4 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
For the street I ran 12mm spacers and take them off on the track. What issues are you concerned with?
05-01-2016, 03:14 PM | #5 |
19
Rep 45
Lots of tracking coming up. 5 events in the next 7 weeks, as a matter of fact. I want that low, hunkered down staggered look, but don't want to rub, of course. Maybe I should just play it safe and get 5's instead of 12's?
05-01-2016, 04:35 PM | #6 |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
You could ping the guys at Apex - they'd be able to answer any questions on fitment
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
05-02-2016, 02:40 PM | #7 |
3221
Rep 6,218
does that second car even have spacers?
18x10et25 - i have a 5mm spacer on mine.
05-02-2016, 05:32 PM | #9 |
115
Rep 1,470
Brent - do you listen to anything I tell you or are just a fan of reinventing the wheel. LOL.
You need 5 up front minimum to not have tires hit coilover nuts. This is somewhat coilover/tire/camber dependent, but 5mm is safe. I run 12mm up front. If you want it as low as I am in the rear, you cannot stick a 12mm back there. I run 5mm. This is for 275 tires. This does not count for 275 Hoosiers. 245/40 Hoosiers are as wide as 275/35 Nittos.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
05-02-2016, 05:41 PM | #10 | |
3221
Rep 6,218
05-02-2016, 06:40 PM | #11 |
115
Rep 1,470
Yes. I run shorter studs in rear.
05-02-2016, 10:13 PM | #12 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
If you run the a square wheel setup, your front track width will be wider than the rear which will increase understeer.
I always run a 12mm spacer in the rear to get back to the OEM track width stagger from front to rear.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
05-02-2016, 11:06 PM | #14 | |
1571
Rep 8,076
With spacers in the rear...the car will be more lively. Why even worry about how it looks on the track?
05-03-2016, 12:03 AM | #15 |
239
Rep 479
I run 275 squared, with no spacers and the handling feels more neutral to me than understeer. I would like to run spacers in the rear to be more flush, but its no big deal.
05-04-2016, 01:39 AM | #16 |
BimmerPost Supporting Vendor
1427
Rep 2,650
Rear spacer size will be determined by your personal preference of what looks good/flush, they are not a necessity. Ride height, tire brand/size and camber specifications all play a roll in what fits and what does not. With that said, 12mm spacers are typically perfect in this situation, they are hubcentric and you can run the car at a pretty low ride height without rubbing.
Up front, spacers are not required to clear the suspension unless you are running KW's or Ohlins. - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
05-04-2016, 06:54 AM | #17 |
115
Rep 1,470
MCS also require spacers up front.
05-04-2016, 09:45 AM | #18 | |
334
Rep 1,991
Wheels : APEX ARC - 8 18x10 squared, ET 25 Tires : Bridgestone S-04, 275/35 front, 285/35 rear * 12mm rear spacer On daily driving, there is no rub, unless I've hit a dip. |
05-04-2016, 10:39 AM | #19 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
