04-30-2016, 09:03 AM | #1 |
46
Rep 192
First time taking M3 to track... Need help!
Hey guys, I have replaced my Audi A5 with a 2013 e92 M3. I went to my very first HPDE with my A5 and I loved it. I have already signed up for my second one.... VIR is only half an hour away from my house.
After 2 track sessions I was able to push my Audi pretty hard on the track (hard in my opinion might not be hard in someone else's opinion). I had nearly new brake pads on my A5 and worn them down completely by the end of the weekend. I also had Michelin PSS with only 5,000 miles on them before the event and worn them out pretty good. They looked like someone took a torch onto them. The sidewalls also took some abuse (I was at 35 psi cold) and the temp that weekend was in the low 60's. Keep in mind I was pushing around a 4,300 pound car (awd) doing tons of 125-40 stops as we had 10 track sessions that weekend. With that being said I am a bit worried/nervous as to what to expect from my M3 at my next HPDE event. Granted the M3 is a much much more track oriented and a much more capable vehicle.... but at the same time that is what worries me. Instead of going 125-40.... I now will be doing 140+ to 40 stops as a stock M3 can easily get up to 140 on both straightways at VIR. Suspension (I will be on springs) and weight will be better than my A5 thus entering in corners much faster. I am worried about how the factory brakes will hold up as well as the tires. Any suggestions? I don't want to look like a tool with after market brakes and racing compound tires in D class lol. I never want to be "that" guy. Any help would be tremendously appreciated. |
04-30-2016, 09:10 AM | #2 |
11817
Rep 23,187
If you are new to the sport take your time. No need to force the car too hard. If worried about edge wear need camber plates, different technique and different set of wheels/tires. Same goes for brakes, can try fluid and pad change and should be fine. New drivers are harder on brakes because over slow for entry. Take what the car gives you at any level and upgrade as you go.
04-30-2016, 09:37 AM | #3 |
General
63358
Rep 24,668
Watch out with your username on the track !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
04-30-2016, 10:18 AM | #4 |
476
Rep 1,711
04-30-2016, 10:26 AM | #5 |
General
63358
Rep 24,668
Yeah , something like crash0 sounds better than crash32
04-30-2016, 10:27 AM | #6 |
303
Rep 1,140
Drives: Something something racecar
I would recommend using high temp fluid like Motul RBF600. First event, that was the only change I made to brakes. Maybe bring an extra set of pads and/or get track pads.
04-30-2016, 10:29 AM | #7 |
46
Rep 192
Lol, it's my nickname for when I used to work at the golf course when I was in highschool lol. Completely unrelated vehicles!
At the bare minimum should I do a fresh brake fluid flush with some type of race pads? Should I attempt my first session with the factory pads or would that be a big no no? |
04-30-2016, 10:33 AM | #8 |
476
Rep 1,711
I would recommend castrol SRF brake fluid, PFC-08 pads and camber plates to save your tires and improve handling.
Once you get faster, you can spend more money for good coiloves, BBK, aero, some weight reduction... |
04-30-2016, 10:45 AM | #10 |
46
Rep 192
Also would the camber plates help save my tires that much? It's just a bit depressing to see $1,000 plus tires go down the drain in one weekend! 80% of the wear was at the outter part of my tires which is why I was asking how much the plates would benefit me.
Maybe it would be worth it for me to purchase aftermarket wheels/tires for the HPDE events. |
04-30-2016, 10:46 AM | #11 |
476
Rep 1,711
these pads are ok on the street. I leave them on between track days and only change them when they are done.
Could be a little noisy when they are cold, but not too bad. In my case anyway. |
04-30-2016, 11:14 AM | #12 |
11817
Rep 23,187
Camber plates will change obviously front camber so outer edge isn't getting overly worked. Would add that and proper alignment before you buy more tires, upgraded tires will wear the edges just the same.
04-30-2016, 11:24 AM | #13 | ||
303
Rep 1,140
I don't know how much camber you have up front, but -0.6° on my 328 caused my two day old tires to start chunking. Would highly recommend camber plates. |
04-30-2016, 12:06 PM | #14 |
Rep 32
Welcome to the cost of the track. Everything is give or take and like others have said take it slow. I have not tracked the M3 yet, but wouldn't go nuts on stuff until you have taken it to ther track. You should do a brake flush, good condition pads, and no matter what your tires are going to wear out fast - this is what happens at the track. The weight savings will help a lot, but smoother driving (which comes from seat time) will also help too. Smooth transition to brakes, get your braking done early in the brake zone (it is common for new students to be soft on the brakes early and then hard at the end - this is harder on the brakes then hard early and coming off smoothly at the end), then roll into the turn quickly and smoothly, transition to squeezing the 'go' pedal and unwind the steering wheel using all of the track.
As a point of reference, I come from 15 years of track DE, Club Racing, and Instructing in another marquee, but am going to start my stock M3 with track pads, Castrol SRF, and street tires. From there we will see where to go. Biggest thing for your second trip to the track is fluid, fresh brake pads, safe tires and work on having fun and learning to drive smoothly. Smooth is much faster than when there are a lot of overly aggressive inputs that feel fast. Go and have a fun and safe time. Skip Last edited by swftiii; 04-30-2016 at 12:13 PM.. |
04-30-2016, 12:21 PM | #15 |
Stop the hate, get a V8
3850
Rep 8,625
Just get new brake fluid in there (and tires and brake pads, depending on how bad they are) and use the first few track days to learn how the car behaves. It's quite good in stock form.
Past: 2011.5 M3 sedan ZCP |
04-30-2016, 12:43 PM | #16 | |
476
Rep 1,711
I would say that this is a must mod for this car. Your tires go down the drain sooner or later, but they will wear evenly if your alignment is done correctly. |
04-30-2016, 02:54 PM | #17 | |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
I am using Castrol SRF with my AP racing BBK. It's pretty much put in and forget - done 24 or so track days with the SRF and have not had to bleed the brakes once. It's worth the extra $$$ for that alone. I didn't get camber plates until I had wasted two sets of tires because I corded the outer edge while the inner half and middle were still good. $500 investment for not wasting $1000 on tires. |
04-30-2016, 07:50 PM | #18 |
467
Rep 818
Regarding tire pressures, you probably want to start out with lower cold pressures (maybe around 32) and check the pressures after each session and bleed off anything over 38 or so (these are just rough guidelines but if you were 35 cold, you probably hit well over 40 hot which isn't good).
04-30-2016, 11:25 PM | #19 | ||
594
Rep 4,488
But get better fluid. If you'll be doing more than 4 track days per year, pony up for Castrol SRF so you don't have to deal with bleeds in between annual flushes. If you'll be doing less, then Motul or Endless is perfectly fine, but more than that with those fluids and you'll need to bleed them every 3-4 track days to avoid a soft pedal. Quote:
If you feel like a lot more reading, I actually wrote a two-part article for my local BMW CCA chapter's newsletter recounting my experience getting into HPDEs with this car, covering what people considering HPDEs might want to know and how my mods progressed and why. I've attached them to this post below. And lastly on a general note, the E9x M3 has been around since late 2007, so it's reasonable to assume the question of what to do on one's first track day in an M3 or first track day ever has already been asked many times. If you're not familiar with the "site:" modifier on Google, it allows you to limit a search to a particular domain if you know what you want to find is there, so for example try Googling "First track day site:m3post.com". Article links: Attachment 999723 Attachment 999724
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 04-30-2016 at 11:55 PM.. |
04-30-2016, 11:29 PM | #20 | |
594
Rep 4,488
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 04-30-2016 at 11:57 PM.. |
05-01-2016, 08:07 AM | #21 |
594
Rep 4,488
OP you should also look into insurance. Read the exclusions on comprehensive coverage in your regular policy to see what it says, and if you see something you don't like (which is becoming increasingly common), then look into places like OnTrackInsurance and Lockton HPDE Insurance -- unless of course you're prepared to write off your M3. But do not plan on perpetrating fraud as a contingency!! In addition to the whole personal integrity issue, there was a recently reported case of a guy who crashed a new M4 on track and tried to claim it as a highway incident. Insurance is now going after him for the $65K payout and criminal fraud charges.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
05-03-2016, 01:49 PM | #22 | |
30
Rep 742
2011 Jerez Black/Fox Red E90 M3 DCT, ZCP, ZCV, ZCW, ZP2, BMW Apps
2015 Golf R |
