BMW X5 and X6 Forum 2014-Current
Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > Vendors Classifieds
      04-24-2016, 08:30 PM   #1
Niki@BimmerTech
Niki@BimmerTech's Avatar
Drives: X1 2013
-=World's Best Premium Audio System For BMWs=-
At BimmerTech, we always believed every BMW deserves a great sound system.
We thought it was high time to develop an amplifier designed to give you great sound quality and adapted specifically to BMWs and teamed up with industry leader Audiotec Fischer to make it happen. Finally in May we introduced you to the first Premium Audio System designed especially for BMWs.
We started with Audiotec Fischer's popular Match PP82DSP unit, but we didn't stop there. Features and capabilities have been optimized and the pre-set program gives you great sound right out of the box. The best part is installation, which couldn't get any easier. The amplifier, which installs in your trunk, is plug and play for all 1-series (E82 and E88), 2-series (F22 and F23), 3-series (F3x and E9x), 4-series, M3/M4 (F8x), 5-series (F10, F11 and F07), 6-series (F06, F12 and F13), 7-series (F01 and F02), X1 (E84), X3 (F25), X5 (E70 and F15) and X6 (E71) BMWs with factory SA676 hi-fi systems. Stay tuned because we'll also be adding more models to this list for plug and play installation. For other models with the same factory hi-fi system you'll need only a simple custom mount or bracket. I've added the details below so you can see exactly what's involved.
For 1-, 2- , 3-, 4-, 5-, 6- , 7- series, X1 and M3/M4:
You'll need about an hour from start to finish. Start by removing the interior trim on the left-hand side of your trunk to access the factory amplifier. Next, remove the factory amplifier – you only need to take out one screw and unplug the amplifier from the factory harness. Use our bracket to place the new amplifier in the factory mount, which has the same mounting mechanism as the factory amplifier, and plug the harness into the factory harness. Replace the trim and you're good to go.
For X3, X5 and X6:
Installation will take about 15min. Get access to the factory amplifier by removing the cover on the left-hand side of your trunk. Then remove the factory amplifier – just take out one screw and unplug the amplifier from the factory harness. Place the new amplifier in the factory mount/handle using our bracket which has the same mounting mechanism as the factory amplifier and plug the harness into the factory harness. Fix the cover back into place and that's all there is to it.
For other models with the same factory SA676 Hi-Fi system:
The custom mount or bracket is user friendly. You might need velcro tape or something similar to fix the amplifier in place, but you won't need to purchase any additional expensive parts or find a specialist to mount it for you.
For cars with basic stereo systems:
You can still take advantage of our new product but you'll need special custom harness, we will have to recode your radio head unit to HiFi and in some cases you will also need a factory amplifier bracket. We'll also recommend upgrading your speakers to make the most of the system.
Don't worry if your car doesn't fit into any of these categories – it might still be supported.
Feel free to contact us with your VIN number and we'll point you in the right direction.
For more information click here
Since then we've received so many positive reviews we wanted to share some with you. We know you'll love the sound of that!
JnoSol, Kansas City
"Just got mine installed today, after setting up my own EQ settings, and I can hear the great improvement of the sound coming out from all speakers.
I really love the solid bass and crispy sound.
Good job BimmerTech! "
      05-10-2016, 05:10 PM   #2
Jlnike
33
Drives: 08 e90 m3 07 e90 328xi
any sales for the forum?
