04-09-2016, 02:10 AM | #1 |
27
Rep 105
255/275 PSS fit with updated liners
I know this has been already mentioned several times, but just want to share my experience. I bought a set of new tires (255/35/19 and 275/35/19 PSS) and figured out that the fronts rub on full lock.
I ordered updated fender liners and everything is fine now. No rubbing at all, so if you hesitate, whether to do it or not, it is my experience that with the updated fender liners it works and doesn't rub. The only downside is that BMW refused to replace them free of charge, but they weren't expensive (100 EUR), though. |
04-09-2016, 05:54 AM | #2 | |
434
Rep 533
Luckily I already got them to replace the liners as my winter set up was rubbing on full lock. How big a difference is there with the new set up vs the old? |
04-09-2016, 08:34 AM | #3 |
27
Rep 105
Well, I came from the winter setting, so the difference is huge, but comparing to previous summer stock sizes (Michelin PS2s), I would say that there is noticably more grip on the rear, but got it just few days, need to brake them in.
04-09-2016, 01:53 PM | #4 | |
434
Rep 533
It's unfortunate they don't come in 285/30s, I'm contemplating S-04s as an option as well... Last edited by 1mm2; 04-09-2016 at 02:16 PM.. |
04-10-2016, 03:20 PM | #5 |
27
Rep 105
07-14-2016, 08:50 AM | #6 |
Rep 31
[QUOTE=MrBeranek;19732649]True, 285/35 only.[/QUOTE
HI do you have part number for front inner? we installed 265/30/19 in front and does rubbing now would like order new version inner, cheers |
07-14-2016, 06:10 PM | #7 |
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
From my work order, not sure which is left and which is right, but this is what my dealer installed:
51-71-8-051-591 51-71-8-051-592 (dealer did it under warranty for me, but I had rubbing with correct size tires, RE-11's are just wider than the stockers) |
07-15-2016, 08:59 PM | #8 |
Rep 31
Thank you
08-22-2016, 12:12 PM | #9 |
coupe la goon
373
Rep 1,644
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
Any experts/parts personnel available to confirm if the above referenced parts are in fact anew variant? I'm not finding a superseded part and am suspecting that people are merely getting replacements with new pieces.
09-04-2016, 02:14 PM | #10 |
Supreme Allied Commander
3868
Rep 54,426
Drives: F80 M3
Did it back in the days. Had to do one side only with the 255 fronts.
06-10-2017, 11:26 AM | #11 |
36
Rep 45
Drives: BMW 1M 2012.
Just bought a 6.000 miles 1M and would like to hear comments on 275 35 r 19 rear tires vs 265 35 r 19
06-11-2017, 04:58 PM | #12 |
85
Rep 562
Drives: 2011 1M VO
This has been discussed before complete with pictures. Is a new part(s), but they kept same number!
06-11-2017, 05:02 PM | #13 |
85
Rep 562
Drives: 2011 1M VO
I have 255/35/19 and 275/35/19 Conti ECS on stock wheels and can see no negatives; I get no rubbing with original fender liners, they look better, protect the wheel better, handle better in wet especially, and give slightly taller gearing which, with all the torque this bugger has with only bolt-ons, it can use!
06-16-2017, 09:19 PM | #14 |
36
Rep 45
Thanks
08-05-2017, 05:29 AM | #15 |
MSgt (ret)
566
Rep 2,116
Drives: VO 1M #739/740
I have Michelin PSS at 275/35/ZR19 on rear without any issues on stock suspension
