04-08-2016, 07:21 PM | #1 |
40
Rep 273
BBS FI-R with spacers or save trouble and go for BBS FI?
IND claims BBS FI-R will fit on e92 with 10mm rear spacers.
Are there any issues with going for that instead of BBS FI? Will the spacers make wheels look pushed out or it'll just align it as if it was BBS FI without spacers? If actually pushed out more, is there a concern for rub, even if the car is non-competition pkg and not lowered? http://ind-distribution.com/ind/bran...9-bbs-fi-wheel http://ind-distribution.com/ind/bran...fi-r-wheel-set From what I've read, it should be fine. I prefer the look of FI-R a little more (sharper curves), the lower weight is a cherry on top. I'd like to avoid issues with vibrations, rubbing though. Cheers!
2013 M3 Coupe | Space Gray | Black Grills & Gills & Reflectors & Exhaust tips | Lux | CF Splitters & Diffuser | BBS | Musicar | F1 | Xpel | Ceramic Pro
04-08-2016, 08:36 PM | #2 |
514
Rep 3,482
iND doesn't list the offset of the FI-R. Any idea what they are?
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
04-08-2016, 08:42 PM | #3 |
40
Rep 273
Nope, only a rep said: "The 19" FI-R will work with a 10mm spacer in the rear."
04-08-2016, 08:52 PM | #4 |
40
Rep 273
Looks to be 22 and 35 from BBS site
http://bbs.com/pdfs/produkte/FI-R_2016.pdf
04-08-2016, 09:03 PM | #5 |
514
Rep 3,482
19x10.5+35 :| wow. That's awful lol.
BMWCCA:518970 |
04-09-2016, 12:37 AM | #7 |
40
Rep 273
Yeah, sounds like not worth it. Thanks for input!
04-09-2016, 12:57 AM | #8 |
892
Rep 9,032
I thought the R would cost more due to the added machining.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
04-09-2016, 08:21 AM | #9 |
514
Rep 3,482
That once in a blue moon moment where less really does cost you less
BMWCCA:518970 |
11-20-2017, 12:34 AM | #12 |
892
Rep 9,032
FI rear offset isn't great. It rubs if lowered on a 295/30-19 supersport.
Courtesy of Capo1 RKP FI 18" 9.5 ET18/10.5 ET22 FI 18" 9.5 ET20/10.5 ET25 19" 9.5 ET28/10.5 ET23 20" 9.5 ET26/10.5 ET28 FI-R 19" 9.5 ET22/10.5 ET35 20" 9.5 ET22/10.5 ET35 RI-D 19" 9 ET22/10 ET25 20" 9 ET32/10 ET34 .
11-21-2017, 03:41 PM | #13 |
Save the manuals!
6019
Rep 6,750
The rear offset is atrocious on the FI-R, which is a shame because in my opinion they are much more aggressive and better looking than the FI
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
yoslow56.00 |
11-21-2017, 11:32 PM | #14 |
892
Rep 9,032
The 19" FI doesn't have idea offsets.
The fronts could be at least 5mm more aggressive and the rears are 5mm too aggressive and rub with 295/30-19 if you're lowered.
11-27-2017, 02:09 PM | #15 |
///M Powered for Life
11499
Rep 10,332
if money were no object I would happily run the BBS FI-R, although running a 2k wheel with a spacer just sounds wrong
vibrations are another issue as gordon mentions below
FMLYSDN1181.50 |
11-27-2017, 02:31 PM | #16 |
1423
Rep 3,002
there is no way in hell I would run a set of FI-Rs with spacers. just get a proper set of fitting FI and be done with it. adding spacers would just defeat the purpose, and you will notice a slight vibration.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
SYT_Shadow11498.50 |
11-29-2017, 11:43 AM | #18 |
1423
Rep 3,002
No where to track the car in Hong Kong anyways
11-30-2017, 04:42 PM | #19 |
2741
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
FI offset too aggressive in the rear for 295's. FIR with spacers would be my choice. Correctly installed spacers will not cause vibration. FIR offsets are designed for F8x platform which requires a less aggressive rear offset. An even better option is the 18" RIA. Cheaper, better offsets, and looks just as good as FI IMO. FIR is next level with the spoke cutouts but you pay $$$
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 11-30-2017 at 11:09 PM.. |
06-20-2018, 01:21 AM | #20 |
271
Rep 553
06-20-2018, 07:15 AM | #21 | |
Gone Fishin’
7318
Rep 12,125
Im running 255/35 and 275/35 right now. I dont care about being omg flush tho. Im on Swift springs. |
06-20-2018, 07:39 AM | #22 |
Gone Fishin’
7318
Rep 12,125
