02-05-2016, 09:46 PM | #1 |
44
Rep 80
anti trap code d window stuck 1/4 help !
09 135i
Anti trap code came on after i came out from the gas station today as the window went down the normal 1/4" but never closed. The window will not go down at all and is basicaly stuck. My passenger window is fine. It is cold here in iowa which id if that helps but I have tried everything I can think of. I can hear it click down by my foot but nothing Someone help asap please! |
02-05-2016, 10:25 PM | #2 |
25
Rep 79
I fixed this by holding the unlock button with the car locked causing the windows to roll all the way down. once they are down I got in, started the car and the windows worked as normal after that.
hope it helps. |
02-05-2016, 10:34 PM | #3 | |
44
Rep 80
I will go try this! How long do i hold down the unlock button? |
02-05-2016, 10:41 PM | #4 | |
25
Rep 79
It takes like 7 seconds just hold the unlock button to open the windows all the way. |
02-05-2016, 11:42 PM | #5 |
44
Rep 80
Sooo....not good...i did that and it made my passenger window go all the way down and opened my sunroof 1/2 way!
My passenger window goes all way back up...sunroof will not close and drivers window is still stuck |
02-06-2016, 12:29 AM | #6 | |
25
Rep 79
To reset the sunroof press the tilt up button, wait for sunroof to rise, continue to hold the button and the sunroof will go through the entire open and close sequence resetting it. |
02-06-2016, 12:39 AM | #7 |
25
Rep 79
You can always disconnect the battery and let it sit for a while sometimes this will reset the modules and clear some fault codes allowing them to return to normal operation.
02-06-2016, 12:48 AM | #8 | |
44
Rep 80
I have also tried the sunroof deal a few times both with car running and also with just the start button on. I disco the battery...reconnected it and no luck...and now also have an active steering code...its 1 thing after another. I am regretting this purchase quickly |
02-06-2016, 12:55 AM | #9 | |
25
Rep 79
02-06-2016, 01:13 AM | #10 |
44
Rep 80
02-06-2016, 01:33 AM | #11 |
25
Rep 79
If you can hear the motor run when you try and use the window it may be a regulator issue. The sunroof is bothering me it could be an electrical issue but I would think that would effect both windows. Hopefully someone else can chime in with some more input.
02-06-2016, 06:04 AM | #12 |
Bergspyder
1482
Rep 1,216
Should be a cover to remove on the overhead and allen key in the tools to close the sunroof.
Can't help you fix it though.
02-06-2016, 08:26 AM | #13 | |
44
Rep 80
Luckily it worked for the sunroof and for now its closed! The anti-trap roof still displays...will that go away or should i disco the battery and it will remove that code? As for the window...its still stuck. I can hear the click down by my left foot inside the OBD door. I am going to check fuses for the drivers window as well in the meantime.. Other ideas? |
02-06-2016, 03:53 PM | #14 | |
25
Rep 79
Im glad you got the sunroof closed but at this point if you are not comfortable inspecting the door yourself I would take it to your local independent shop or dealer and see what they think. |
