01-12-2016, 02:49 PM | #1 |
Aficionado of All Things Vroom
171
Rep 1,213
FS: Laser Interceptor Dual
I've got a Laser Interceptor Dual Standard Edition for sale. The CPU has been updated to the latest software and voicepack. The sensors are Version 8.9. There are virtually no differences between the 8.9 heads and the current 9.0 heads as far as jamming capabilities are concerned. Also comes with external speaker and original unused mounting hardware. I simply opted to use double sided tape to mount the sensors, rather than drilling holes in my bumper or messing with the brackets. I do NOT have the power switch/cable. Buyer will need to purchase one from LI for $20. https://www.laser-interceptorusa.com...r-switch-cable Pics This system currently retails for $699 from LI USA. Asking $350 OBO.
Current: 2020 F97 X3M Competition
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi Last edited by ZTZ1010; 03-15-2016 at 02:37 PM.. |
01-26-2016, 03:20 PM | #3 |
171
Rep 1,213
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi Last edited by ZTZ1010; 01-26-2016 at 03:33 PM.. |
01-26-2016, 03:34 PM | #4 |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
How difficult is the installation? Can you add the other 2 sensors later?
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
01-26-2016, 03:36 PM | #5 | |
171
Rep 1,213
The install is very straight forward. The most time consuming part is running the cables from the engine compartment to the passenger compartment. I made the mistake of doing it alone, but it would be much easier with a second person. Realistically you pop a small hole in the rubber grommet on the right side of the engine bay and run them through. The hole opens up to the footwell, you pull the cable through, and plug it into the CPU. I mounted the CPU on the upper left side under the kick panel under the steering column. Then all you need to do is find power/ground. You can either tap the cig lighter power supply or run it over to the fuse box and do add a fuse.
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi |
01-26-2016, 03:38 PM | #6 | |
3101
Rep 3,470
02-01-2016, 02:15 PM | #7 |
171
Rep 1,213
bump
03-15-2016, 02:37 PM | #8 |
171
Rep 1,213
price drop
04-15-2016, 04:50 PM | #9 |
38
Rep 109
Drives: E92 Space Gray, Fox Red 6MT
Are these the vertical sensors that are able to be mounted in the grill?
2013.99 E92 | 6MT | ZCP | Macht Schnell Underdrive Pulleys | BPM Sport Stage II Tune | RPI Scoops | AFE Elite Stage 2 Pro5R Intake | ESS X-pipe HFC | UUC Corsa Exhaust | Hardwire V1 |
