TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      11-18-2015, 08:39 AM   #1
weems
Drives: 2011 E70 Sport
Water Sloshing/Trapped?
When I first got my X5 I heard a sloshing sound in the driver door/rear driver side door area when I come to a stop and start off. Its a pretty loud slosh and sounds like a good amount of water. I removed the rear seats and peeled the carpet back to find massive amounts of water in the carpet/foam. After a few days of tracing all sources of leaks we found the entire carpet front to back was wet, and the AC condenser was leaking. We had the dealership fix the condenser (out of warranty), and the sound was gone (they kept the car 5 days).
Fast forward to yesterday, we had a decent amount of rain and the sound is now back, however it doesn't look like there is any water entry into the car so I guess the two issues were unrelated. Any idea on where to start to try and find this trapped water?
      11-18-2015, 10:50 AM   #2
smyles
1023
Drives: '21 X5
Check the trunk side compartments, behind the covers. If wet/water found, then the sunroof drains are likely clogged.
      11-18-2015, 12:39 PM   #3
weems
Dry as a bone.
      11-18-2015, 02:44 PM   #4
weems
I can't tell exactly where it is coming from, I am going to try to get someone in the back and see if they can tell, but there is definitely water trapped somewhere.
      11-18-2015, 04:31 PM   #5
xpl0sive
28
Drives: bmw
i had an issue with the carpet getting wet in my 2008. ended up being a torn door rubber. check all the rubbers around the doors for tears
      11-18-2015, 07:24 PM   #6
weems
It's not in the car, its under/in the frame it seems like.
      11-19-2015, 09:42 AM   #7
weems
Does anybody know if there are any drain plugs in the frame I can look for? The sound is definitely isolated in the lower body somewhere.
