09-07-2015, 02:31 PM | #1 |
4482
Rep 7,120
Even OEM rear camber wear tire inside?
Hey guys,
notice a clear wear inside vs rest of the tire. Guess how it is suppose to be even on a original M3 camber setting to get handle in place, or should I go for an alignment? (24k miles, OEM 359/tire size, no spacers). Flame suit on for possibly not cornering hard enought... Cheers |
09-07-2015, 02:58 PM | #2 |
11818
Rep 23,187
Only street driving? Usually don't take advantage of even oem camber in that manner. Driving feel is better at expense of tire wear. Had to dial some out of rear on both my X5's so wouldn't ruin tires.
09-07-2015, 04:43 PM | #4 |
379
Rep 875
How uneven is it? If it seems excessive, it may be a toe issue which will wear out a portion of the tire prematurely vs. the rest of the tire depending on toe-in or toe-out. I think it's always good to get alignments as part of annual maintenance. When was your last alignment?
...or, just take turns harder! |
09-08-2015, 01:30 AM | #5 |
4482
Rep 7,120
Hi Cenix, don't think it ever had an alignment (bought it 12k miles). I'll have a chat with the dealer next time I pass them to see what they think, if anything...
Thx |
09-08-2015, 04:02 AM | #8 |
2511
Rep 4,381
Hey Nik...yeah its probably the most common cause of unusual tyre wear.
Normally a little negative camber causes the inside of the tread to wear more than the rest but the wear is evened out by a little toe-in which wears the outsides of the tyre. Too much of both and you can eat through rear tyres in 2 or 3 thousand miles and yet can still have a normal looking wear pattern in some cases. You can actually feel excess toe by rubbing your hand across the tread - depending on which way the tyres are toeing, the tread edges feel sharp against your hand. |
09-08-2015, 04:07 AM | #9 | |
4482
Rep 7,120
09-08-2015, 08:18 AM | #10 |
36
Rep 195
I have exactly the same thing on my rears with original toe/camber settings. I think the rear camber is around -1.5. Funny enough I have camber plates in the front at around -2.4 and I do not have any issue at the front. Go figure?!
This is on my street tires, so no tracking. |
