06-15-2015, 08:04 AM | #1 |
70
Rep 287
Released: E9X M3 (and 1M) Bilstein B16 Damptronic (EDC) Coilover Suspension
Part Number: 49-237108
Series: B16 (DampTronic) Position: Front and Rear Descriptor: Front Lowered Height: 10-35mm, up to 1070kg Axle Load Descriptor: Rear Lowered Height: 10-35mm, up to 1270kg Axle Load Descriptor: With Electronic Damping Control (EDC) Quantity Per Vehicle: 1 Finish: Dampers: Zinc Front Yellow Rear/Springs: Blue The Bilstein B16 DampTronic kit is designed to integrate directly with factory elctronic damping control systems for: Porsche, BMW and Mercedes. These coilover systems feature monotube shock absorbers that have been fine-tuned to produce the finest performance possible from the car's electronically controlled suspension module. The threaded body additionally allows for adjustable lowered vehicle ride height of 30mm to 50mm. Bilstein's patented Triple-C-Technology coating ensures long-lasting resistance to corrosion.
Drives: 2010 E70 X5M Carbonschwarz Loved and lost: 07 E92 M3 Silverstone II / 96 E36 M3 Evo Estoril Blue / 07 E84 Z4 M Coupe Interlagos Blue Last edited by saxonb; 06-15-2015 at 08:20 AM.. |
06-15-2015, 08:06 AM | #2 |
70
Rep 287
"Coming soon" in US store: http://cart.bilsteinus.com/product/49-237108/309734/RWD
Drives: 2010 E70 X5M Carbonschwarz Loved and lost: 07 E92 M3 Silverstone II / 96 E36 M3 Evo Estoril Blue / 07 E84 Z4 M Coupe Interlagos Blue |
06-15-2015, 08:13 AM | #3 |
70
Rep 287
Was actually announced back in 2013: http://www.bilstein.de/en-uk/news-ev...ving-dynamics/
06-16-2015, 09:11 PM | #5 |
32
Rep 225
Drives: 2011 Space Grey E90 M3 DCT ZCP
did a quick google search for the part number and found these:
http://www.tomson.com.pl/product-eng...MW-M3-E92.html http://www.bilstein-shop.com/bilstei...r-p-53804.html looks to be between 3200-3500 euro which works out to about USD$3600-3900
Marc
2011 Space Grey Metallic E90 M3 DCT ZCP |
Doc Oc1423.00 |
06-17-2015, 09:09 AM | #6 |
131
Rep 596
This would be really awesome with the EDC functionality. I'm gonna check with turner today if they can get this and price.
Update: Spoke with turner there are several kits in the US available for purchase. Price is $3600. |
06-17-2015, 09:39 AM | #7 | |
254
Rep 633
Lutfy |
06-22-2015, 08:49 PM | #8 |
1123
Rep 1,083
From Bilstein DE Website, the TUV Cert and Installation Instructions
http://www.dvsegmbh.info/PDF/einbau/...M4-Y611A00.PDF
06-22-2015, 08:55 PM | #9 |
500
Rep 2,400
Wow, this is a nice option to have. Interested to see how aggressively it can be set up and if as good as many D/A systems on the market in terms of fine-tuning.
06-23-2015, 10:24 PM | #10 | |
388
Rep 876
Because I want to retain EDC, I never considered coilovers until this came out. Thought I've seen Turner run 10% off Bilstein sales a few times a year in the past. |
06-25-2015, 03:43 PM | #11 | |
254
Rep 633
Unless you are getting JRZ or Motion Control (even if single adjustable), these shocks are not valved/designed for higher rates and valved to suit the current springs. Lutfy |
06-26-2015, 11:06 PM | #12 | |
500
Rep 2,400
Got it...looks like I'll be keeping my TC Kline D/As! thx
06-27-2015, 01:09 AM | #13 | ||
131
Rep 596
06-30-2015, 09:15 AM | #14 |
254
Rep 633
After testing a few different rates on the same B16 kit on a 911S only to realize what comes with the stock ones are matched/valved for it. Yes. Confirmed with TPC Racing as well...
I have info on what the shocks should be re-valved for (sent to Bilsteins to their Motorsports Dept in CA "IF" running higher sprung rates) if anyone wants that data, here goes (I run Bilstein's regular EDC shocks valved from the factory): When Bilstein quote 300/200, they really mean 3000 Newtons of rebound force at 520 mm/sec and 2000 Newtons of bump force. They are dropping the last zero on the force magnitude. This number is just the force at a very high damper velocity and doesn't necessarily have a lot of meaning without knowing the shape of the curve. They have two standard shapes (linear and digressive). Unlike the standard EDC yellow shocks, these B16 do not need to have their shaft shortened (will not bottom out but with standard yellows you need to since its not "sport". Only difference between regular yellow and sport is shortened shaft, not the valving). Full On Race Specs: Front Rear 3000/3000 2000/2000 Normal sportish dampers: 2200/620 1855/530 For Swift R springs with combined street and track: 2500/1200 2000/1000 At least the later recommendations where all digressive curve shapes; using the EDC inboard button will give you very marginal increase over each button you'd press for compression only (since you are revalved such stiffly in the first place). Rebound stays static. At which point it would be silly to have the EDC functionality in the first place (for which you are paying a premium). Hence best to use the current spring rates. For the money, you are better using JRZ or such IF you want tunability to run stiffer rates at any future point. Lutfy Last edited by lutfy; 06-30-2015 at 01:16 PM.. |
09-12-2015, 10:14 PM | #15 |
314
Rep 2,448
Question:
Is anyone here running these yet as I've seen many ppl PM EAS for price quote? http://www.m3post.com/forums/showthread.php?t=1153206 If so, please put up a review! Lufty, Are you suggesting that it's better to use the springs that come with these coils over the Swift spec R? Are these Bilstein ones Linear and do the come with camber plates? Would you consider these for the streets over the Ohlins?
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
09-13-2015, 04:06 AM | #16 | |
470
Rep 988
Haven't had a chance to do a review, but to summarize... They are fantastic!!! 1) in comfort mode my wife thought I raised the car and installed the stock suspension but my car is slightly lower 2) the middle dynamic mode seems to be best for enthusiastic drives around the canyons 3) in the stiffest mode the car feels pretty stiff. Will likely use this setting on glass smooth tracks |
09-13-2015, 05:07 AM | #17 |
26
Rep 254
I'd suggest you put them on a shock dyno and see what they are capable of, I've heard the pss9's have an absolutely incredible consistency across all adjustment points! BY THE WAY this is coming from someone who has custom penskes on his race car. Almost positive if I got any coilover for my m3 DD it would be bilstiens.
09-14-2015, 09:30 AM | #18 | |
254
Rep 633
Ohlins are great too. Bilsteins have the EDC functionality, comfy for street/track and spring rates for both Ohlins and Bilsteins are fairly low/soft. One can be adjusted from the cockpit other from the outside. Coin toss really. Lutfy |
09-14-2015, 11:09 AM | #19 | |
314
Rep 2,448
The EDC only works for compression only. Can we adjust the rebound manually on the coil itself?
09-14-2015, 01:13 PM | #20 | |
254
Rep 633
Lutfy |
10-09-2015, 11:51 AM | #22 |
470
Rep 988
A few months late on my initial review so here it is.
My comparison is going to relate to E90 M3 with the B16 Damptronic vs my friends stock F80 M3 with stock EDC suspension. Prior to this I had my stock EDC dampers paired with the Swift springs so I don't remember what my stock felt like. comfort: the B16 damptronic feels softer/ more comfortable and at the same time more planted than the stock F80 M3 EDC in comfort mode Medium: again more comfortable than medium on the F80 M3 yet having better dampening Stiff: just as stiff as the F80 M3, same comfort, better dampening Overall it is a huge improvement over the stock F80 M3 so I am assuming it is just that much better than the stock e90 M3 edc. Depending on the surface you are driving on, you can tailor the settings to give you a ton of grip and stability no matter what the conditions at a push of a button. On my 2000 mile roadtrip through twisty pacific west mountain roads and bumpy downtown streets around Portland and San Francisco I did not bottom out the suspension. Around San Francisco's rough streets I was dodging in and out of traffic and traveling faster than normal traffic around the inclines and declines without any bottoming out or hitting the bump stops. In fact although the car sits a little lower than my original setup with swift springs and EDC oem dampers, my wife thought I put the car completely back to stock. Haven't had a chance to take it on the race track yet... hopefully in the next couple of months... I expect it will do great. It's not the ultimate track coilover, but it's excellent if you are looking for something for both street and track. Also out here in Socal, not all the tracks have glass smooth surfaces so in which case a high spring rate can actually be detrimental. Last edited by PandaM3; 10-09-2015 at 12:17 PM.. |
