06-06-2015, 08:26 PM | #1 |
38
Rep 27
M-Performance Exhaust System
Alright boys, just received a BIG goodie bag last night...
So, I always wanted more performance, and little-bit more aggressive sound to come out of this car (F80). I decided to purchase an M-Performance exhaust with Titanium tips. Coming from the BMW Team, I'm sure they have spend some the R&D. And I recently installed Akrapovic's Down-Pipe, I believe this should be a compliment addition to the system. (I heard that Akra also collaborated to design the M-Performance exhaust as well?) With closer inspections, I am pleased with the craftsmanship; definitely feels lighter and nice weldings all around. To the owners who has them installed into their ///M's ... please post your good (bad, if any) comments... Here are some pics... Take a closer look of the last 2 pics, do you guys know why they have weld in the center? Cheers, Endra Last edited by EM25; 06-27-2015 at 08:13 PM.. Reason: youtube |
06-06-2015, 10:39 PM | #2 |
22
Rep 35
the thing is $. it sounds great. first thing in the morning fire her up... put it in sport plus immediately and jab the throttle. enjoy!
SS/black | Black 19s | 4 doors | 3 peddles | Zero driver assist crap | Lights and beats | Every M perf carbon piece I could have installed at the port | M perf exhaust | Electronic M wheel | JB4 | KW V3s
06-07-2015, 04:29 AM | #3 |
75
Rep 174
Have MPE and absolutely love it. IMO cold start is a bit harsh sounding but once the car warms up it is incredible. Like the weight reduction and fact it's OEM. I don't have a DP. Enjoy it.
MY21 X3M DGM/SO
MY22 M235i MB/MR |
06-07-2015, 07:24 AM | #4 | |
4595
Rep 2,208
Drives: G81 M3 Touring (Frozen Black)
06-07-2015, 06:04 PM | #5 |
624
Rep 426
MPE makes the car perfect. I get compliment all the time. Even the haters who said "yea but the new M cars sound like crap and blah blah blah". The look on their face is priceless after they hear the sound.
06-08-2015, 12:40 AM | #7 |
227
Rep 597
I have the MPE and Akra DPs.
MPE only - startup is a bit loud. when cold it is harsh at about 2k rpm for a minute or so. It also has a little tinny sound. After a couple minutes. sounds great and in Sport+ it gets nice and loud. In normal mode you can barely hear it driving normally under low RPM and with the windows up, sounds stock and no drone. MPE+Akra - at 7krpm its really loud. Let me put it this way. A guy in a convertible SLK (about 200hp), turned left at a light to a 4 lane road. I was behind him and once on the 4 lane I punched it. they were... 100ft in front of me. he seemed to be fully accelerating. Once I punched it, the passenger looked back because he could hear me coming with his roof down and the wind noise etc.) maybe a second later I past them like they were going backwards. and it sounded glorious. It is pretty crazy for the neighborhood (when under load) so I put it in easy mode when getting close to home. Did some dynos. see post #59 http://f80.bimmerpost.com/forums/sho...7#post18049017 note I never dyno'd it on 92 octane nor without the exhaust. I doubt the exhaust adds much of anything, or at least bang for the buck, it is pretty spendy. Last edited by schnazzy; 06-08-2015 at 12:49 AM.. |
06-10-2015, 04:55 AM | #9 |
316
Rep 374
06-10-2015, 09:17 AM | #10 |
General
21121
Rep 20,741
Drives: 2021 911 turbo
Congrats on your purchase . I have an MPE and absolutely love it . The sound keeps improving as the exhaust breaks-in. It has a nice deep growl with the valves closed and just howls when they open up .
My understanding is that the MPE was entirely designed internally at BMW without assistance from Akra. There were some early rumors that the F8X MPE was made by Akra as on the M5/6 but those were quickly dispelled.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
06-10-2015, 10:20 AM | #11 |
227
Rep 597
06-10-2015, 11:04 AM | #12 | |
1385
Rep 3,834
AWE is not as raspy compared to MPE. Some people like the rasp sound. (others with MPE can chime in here) Those who have MPE swears it and those who have AWE swears by it. So none of them are unhappy that I'm aware of. This means you can't go wrong for either in regard to sound. With sounds aside, MPE should weigh 20lbs less than AWE (estimated as AWE weigh close to stock, they use thick gauge steel to reduce rasp). MPE tips look nicer compared to AWE. So the choice boils down to money. About $1k more for an exhaust that is 20lbs lighter and with better looking tips.
Daily: G12 750 MSPORT Weekend Car: E90 M3
06-10-2015, 01:57 PM | #13 | |
624
Rep 426
You can't go wrong here |
06-10-2015, 07:36 PM | #14 |
Dont listen to me
799
Rep 564
Not sure if you have installed the exhaust yet but pay close attention when installing the exhaust tips. Each tip is held in by an Allen bolt that clamps the tip to the main muffler section. The Allen bolt has a slight cut in in the side that is designed to deform (strip) the hex portion of the Allen bolt when it is tightened enough.
Before installing each tip, gently screw each Allen bolt into the tip and then back out to make sure the threads are clean and the Allen bolt turns cleanly through the threads in the tip. One of my tips had a slightly cross threaded hole which created enough resistance to break (strip) the Allen bolt when tightening it. This meant the tip was not properly clamped to the muffler and could easily be pulled off, and definitely would have fallen off when driving. With that said, that Allen bolt could not be used anymore because the Allen wrench would spin inside the deformed Allen bolt. I had to extract the broken/stripped Allen bolt and then source a new bolt with the proper thread pitch/diameter so I could properly tighten the tip to the muffler. Make sure you give each tip a good tug to make sure it is properly tightened onto the muffler. |
06-10-2015, 09:59 PM | #16 | |
38
Rep 27
rgds, EM |
06-10-2015, 10:47 PM | #18 |
1385
Rep 3,834
I'm very interested to hearing your feedback on MPE + DPs. Also, keep in mind they do have a break-in period. They start out soft, then gets louder after 2k miles. So don't be upset if they're not loud enough out of the box.
06-11-2015, 03:57 AM | #21 | |
38
Rep 27
I will take a better video over the weekend. my current setup: - Macth Schnell EVC - Akrapovic Down-Pipes - M Perfomance exhaust During the recording, the car is still on Efficient Mode with Open Valves. Last edited by EM25; 06-14-2015 at 01:59 AM.. Reason: embedding youtube |
06-11-2015, 07:01 AM | #22 | |
240
Rep 481
