04-24-2015, 02:04 PM | #1 |
Rep 25
JB4 Install Tips/Tricks
Though the JB4 install seems very basic, it does require some patience. Please post any suggestion you have to help aid others in the install. I have yet to install the fuel mass plug, looking for any advice on that little guy
My tips, Start with a cold engine. The Battery is in the trunk, pull the side panel on the right side of trunk(passanger side). Use a 10mm to loosen the negative battery cable. I used a microfiber towel to keep the cable from contacting anything. Use one of the picks pictured below to help you unlock the factory plugs. When I removed the hose from the intercooler, I had a pretty good flow of coolant come out of the intercooler. I would recommend you have something handy to plug the hole when you remove the hose. It appears the intercooler used regular coolant (can someone confirm this)? |
04-24-2015, 02:44 PM | #2 |
Joint Chiefs of Staff
4918
Rep 115,980
04-24-2015, 03:01 PM | #3 | |
Gone Fishin’
7318
Rep 12,125
04-24-2015, 03:53 PM | #4 |
34
Rep 110
i also had to pull reservoir tube. just removing the two screws that hold it in place didn't give me enough room to access map connector. that connector was a bitch. tmap and can connectors were a breeze. and i appeared to get lucky like some other folks and my fuel mass connector is facing up. so i removed the reservoir screws and moved it out of the way a little and was able to plug into fuel mass w/o any issue.
04-24-2015, 06:35 PM | #5 |
311
Rep 645
I also had to remove the hose and clamp it to prevent leaking coolant. There was still no way to get to the plugs by just popping the reservoir screws off.
Garage: 2015 991.1 GT3 | 2016 AMG GTS Sold | 2015 C7 Z06 Sold | 2015 M4 SO/6MT Sold
Instagram: M.Tonee |
04-24-2015, 08:34 PM | #6 |
224
Rep 516
same here removed the hose and plugged it with a vacuum line cap. the fuel sensor was a total bitxh as well as the ewg connectors. one ewg was easy.. the other one was a total pain.
04-24-2015, 10:25 PM | #7 |
439
Rep 1,732
Same I removed the hose as well because there was no way I can access the tmap.
By the way how did you guys remove the hose? I had a hell of a time. Any tips? Also does someone have a detailed (with pics) description on how to plug in stage 2 for a 6MT? I am only on stage 1 (the 2 connectors) now but would like to upgrade soon. The instructions isn't very clear beyond stage 1. |
04-24-2015, 10:34 PM | #8 |
Gone Fishin’
7318
Rep 12,125
i have seriously large hands and I can do it without removing the hose. Loosen the reservoir and pull off the weather stripping on the back side. Ive done it 10+ times and never removed the hose.
You can also use this tool. You can unclip the original and hold the new one on the brim to plug it in. Since I got this its super easy. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 |
04-25-2015, 12:01 AM | #9 |
34
Rep 110
Hmm. Perhaps those pliers would have helped. I found the map connector to be pretty awkward to reach/get the correct angle on. Got it eventually but was a PITA.
Going to tackle EWG connectors tomorrow. Looks like forward one won't be too bad. Rear might be tougher. Rear access is always more challenging |
04-25-2015, 01:19 AM | #10 |
193
Rep 725
Attempted to remove coolant tank for install and coolant gushed all over the place. I said f this crap. I'm not gonna go through this crap every time I want to install jb4. I'm selling jb4 and waiting for ob2 flash
2008 335i- FBO
2015 M4-exterior mods, JB4 E 85 2008 Zo6- intake 2015 Honda Accord 2020 Range Rover Sport HST |
04-25-2015, 05:59 AM | #11 | |
262
Rep 658
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
04-25-2015, 09:38 AM | #12 |
Gone Fishin’
7318
Rep 12,125
Yeh or you could just install it per the instructions which dont say to remove the tank but loosen it and be done in 20 mins.
04-25-2015, 10:54 AM | #13 |
193
Rep 725
I went to buy new bolts at the dealer for the tank you have to remove, the guy asked me so have you been modifying you car. I told him I was having them painted to match the car lol. I do look like I would be modifying cars
2008 335i- FBO
04-25-2015, 12:49 PM | #15 | |
224
Rep 516
04-25-2015, 01:52 PM | #16 |
193
Rep 725
True
2008 335i- FBO
04-25-2015, 04:40 PM | #17 |
Gone Fishin’
7318
Rep 12,125
04-25-2015, 06:57 PM | #19 |
Gone Fishin’
7318
Rep 12,125
09-15-2015, 11:55 AM | #20 |
262
Rep 658
If there are Doctors here I used a long fine right angle to get to the Tmap. First install was over an hour. Just reinstalled in 10 minutes without touching the reservoir at all.
09-15-2015, 01:08 PM | #21 |
286
Rep 579
Just did this install last sunday. It was pretty straight forward other than getting behind the reservoir. PITA! I unbolted the reservoir, and then used one had to reach back and a flat head screwdriver to push down on the tab of the connector to release it.
2015 ///M4 - Alpine White - My ED
Executive Package / Lighting Package / Black 19's / Adaptive Suspension / Harmon Kardon / DCT |
09-15-2015, 02:51 PM | #22 | |
708
Rep 1,405
The trick is the tools above and the long pliers like this ones... its so much easier... |
