04-13-2015, 12:34 PM | #1 |
Team M
604
Rep 1,036
JB4 need help...please help..
whats up guys.. so I got my jb4 and downpipes installed on Saturday... sounds insane..fast as hell. my question is I have heard about JB4 just resetting and deactivating... aside from the obvious which is the loss of power if it deactivates.. is there any way we would know if it does deactivate?? also is there anyway other then plugging your car into a laptop to know what current map you are running on?
Thanks a lot Tommy
2022 G80 M3 Brooklyn Grey 6Speed=ON ORDER
2021 G80 M3 Tanzanite Blue=Sold 2015 f82 alpine white bmw M4=traded in 2010 e92 alpine white bmw m3=traded in 2003 e46 alpine white bmw m3=traded in/2003 e46 Laguna seca blue bmw m3=stolen |
04-13-2015, 01:02 PM | #2 |
Team M
604
Rep 1,036
hmm nobody ?
04-13-2015, 01:05 PM | #3 |
Joint Chiefs of Staff
4918
Rep 115,980
The JB4_S55 map switch directions and latest firmware/settings are posted on BMS's forums but here is the latests firmware summaries and map switching video..
JB4_S55 Map Guide as of v3.6 Firmware: Map 0: Disable JB4 / Full Pass Through Mode Map 1: Stage1 map adding approximately 40whp and 40wtq across the power band on pump gas. Suitable for all stages and fuel mixtures. Map 2: Slightly more aggressive version of map 1 intended for vehicles with exhaust modifications and 93+ octane fuel. Can also be used with E85 and racing fuel mixtures. Requires Stage2. Map 3: Slightly less aggressive version of map 1 intended for vehicles running on lower grade fuels such as 91 octane. Requires Stage2. Map 4: OEM performance but with JB4 active for datalogging only. Map 5: //M low torque (evaluation) map. Map 6: Custom tuning map. Map 7: Race gas map. Requires 100 octane unleaded fuel and for the fuel mass connector to be installed. Can be used with or without the EWG connectors but will make more power with the EWG connectors installed. This map can also be used with up to 35% E85 but in some vehicles & conditions this may cause a high fuel pressure drop and resulting stuttering. If this occurs drop down to map 2. Map 8: Methanol Injection map. Requires BMS FSB controller or methanol kit for progressive mapping and safety systems. For pump gas a meth additive of 30 is suggested while for race gas/E85 + meth up to a 75 additive can be used. The higher the meth additive the more aggressive the boost curve. A meth additive of 60 would be roughly equivalent to map 7. Note: For race use only to enable the automatic clearing of passive codes (real codes will continue to show a light in dash) set FutureUseD = 90. Firmware v3.13 1) Revised map switch indicator per latest video below. Firmware v3.12 1) Increased data sampling rate. 2) Adjusted AFR to show a blended bank1/bank2 value. I will separate them again down the road as we have more logging changes in the works. 3) Added user adjustable "3rd gear" boost limiter. Requires new interface. Note that 1st gear reduces boost by that amount below 30mph, 2nd gear reduces boost by that amount below 50mph, an 3rd gear reduces boost by that amount below 85mph. If dyno testing you should set these values to 0 otherwise they will lower boost for parts of your dyno runs. We will be implementing a gear logging system (computed using road speed and RPM) in a future release. Firmware v3.11 1) Changed map switch indicator per new video. This new method works the same with both automatic and manual vehicles. 2) Added additional maps for use with PURE S2 turbos. If installing these turbos email us for directions on how to enable the maps. |
04-13-2015, 01:11 PM | #4 |
Team M
604
Rep 1,036
[QUOTE=Mike@N54Tuning.com;17735406]The JB4_S55 map switch directions and latest firmware/settings are posted on BMS's forums but here is the latests firmware summaries and map switching video..
Mike thanks for the input.. but this does not answer my questions.. I need to know how I confirm my jb4 is active and did not reset I hear they reset a lot of times... also I want to know how I know which map I am currently running thanks
04-13-2015, 01:14 PM | #5 |
60
Rep 204
From my understanding, jb4 is always active unless it is removed or switched to map 0. I do not believe it de-activates on its on never heard that before.
best |
04-13-2015, 01:17 PM | #6 | |
4918
Rep 115,980
[QUOTE=tommydiezelm4;17735462]
Mike |
04-13-2015, 01:17 PM | #7 | |
Team M
604
Rep 1,036
04-13-2015, 02:12 PM | #8 |
224
Rep 516
if you have the cable you can download the software, connect to your car and it will show you what map you are on. it's the data logging cable
on a side note, mine has never deactivated. first time hearing this as well |
04-13-2015, 10:02 PM | #9 |
87
Rep 286
I'm guessing he's talking about the safety default mode?
On the JB4 when it goes lean under load, overboosts, or has excessive knock it defaults to MAP 4 which feels like the JB4 is turning off. Protecting your motor. Yes until there is in dash display like on the N54 cars you'd have to connect the laptop to see it. If you think it happened you have to turn the car off and turn back on to clear it. Though you should log it to find out what happened and fix it before you damage something. Hate to beat a dead horse... Ok maybe not. You should ask BMS about this on their forum, or search for it over there. Tons of good information on this system. |
04-14-2015, 07:55 AM | #10 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
There is a phone app for the Android and I believe the IPhone, I used the Android one on my N55 on the last car and it is a lot easier to plug in and check whenever your driveing then a laptop, also can change maps, datalog etc. just an idea.
15 M4 / 14 M235i-Sold / 09 E92 M3-Sold / 07 E92 335i-Sold
04-14-2015, 08:38 AM | #11 | |
289
Rep 1,575
04-14-2015, 09:16 AM | #12 |
Team M
604
Rep 1,036
thanks for all the replies guys... so the car was set to map 0 for some odd reason... Thanks to a few guys from the board we got it back up on map 2 late last night... SMOKE EM IF U GOT EM!! and smithf32
always good to have enthusiasts from the board willing to help!! thanks guys I was able to sleep last night...
04-14-2015, 09:28 AM | #14 |
Team M
604
Rep 1,036
whats good kidd name rings a bell where do I know you from?
04-14-2015, 09:33 AM | #15 | |
87
Rep 286
04-14-2015, 09:35 AM | #16 |
779
Rep 254
Drives: 2022 X3 M40i
Sometimes while driving I press and hold the volume down button on the steering wheel to rapidly turn down the volume on the stereo. Obviously I don't then press the volume up button directly after turning the volume down which then defaults the JB4 to Map 0....I think this is a flaw with the way the map switching works...would have been better to use one of the other buttons to activate map switching...often I feel I'm down on power only to realize I've accidentally reverted to Map 0 because I turned the volume down.
04-14-2015, 10:24 AM | #17 | |
55
Rep 328
04-14-2015, 10:29 AM | #18 |
Team M
604
Rep 1,036
what hat would you be referring to?
04-14-2015, 10:56 AM | #19 | |
216
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
Haha. No doubt man. Glad to hear you're enjoying the car again. Oddly being on map 0 sounds a little fishy to me but hey at least it's all good now. Yea coupe of them snazzy hats would be good too!
LIVE FAST..DRIVE FASTER!! |
04-16-2015, 05:51 PM | #20 |
BimmerPost Supporting Vendor
733
Rep 10,105
Get used to changing the volume on the radio not on the steering wheel. That's the #1 reason they go to Map 0. Happens very often. Unfortunately there's no way to disable the steering wheel controls AND cat delete as they use the same option on the software.
04-16-2015, 05:54 PM | #21 | |
Team M
604
Rep 1,036
