04-08-2015, 07:26 PM | #1 |
Joint Chiefs of Staff
4918
Rep 115,980
JB4 Firmware v3.12 and 3rd gear boost limiting
New v3.12 JB4_S55 firmware was posted today, along with a new tuning interface, that now includes 3rd gear boost limiting. I'm not sure how many of you spin in to 3rd on OEM turbos but with PURE S2 turbos it's a huge issue. So far using the boost limiting they've been able to get their 60-130 times down to 6.9s on a 2.5%, 7.3s on less than 1% slope, but expect to improve those times soon. This is full weight on OEM 19" rims with 265/35/19 R888s out back.
Note that while the interface says "boost limit by gear" it's actually currently programmed as "boost reduction by road speed", where 1st is under 30mph, 2nd is under 50mph, and 3rd is under 85mph. They expect to use road speed and engine speed to add a gear calculated value in a future version so we can have true boost by gear. But speaking from experience setting 1st gear to say 6.0 and 2nd to say 4.0 makes a huge improvement in off the line traction. |
06-27-2015, 04:05 AM | #6 | |
227
Rep 597
I think the default is 0.0 for the 3 options. So you say put 6.0 in "Max Boost 1st"? Then 4 in for 2nd? What about 3rd? Also, what does 6 mean? 6psi above stock? |
06-27-2015, 09:21 AM | #7 | ||
224
Rep 516
the new obd connector firmware is 1-3 max boost. ie, you would put 15 in first for the max boost you want to run in 1st gear. gear dependent now instead of 1st being 30mph and under I also had mine set to 6 and 4 on firmware 3.13 but still spun. 8 and 5 probably better |
06-27-2015, 03:41 PM | #8 | |
4918
Rep 115,980
Mike |
06-27-2015, 08:39 PM | #10 |
227
Rep 597
and thus my confusion. I believe the default in 3.13 is 0 which is off and therefore I have the most boost and no reduction. I have traction issues but I don't want to reduce/set the boost in a way that hurts overall performance.
06-27-2015, 11:53 PM | #13 | |
224
Rep 516
06-28-2015, 12:34 AM | #15 |
227
Rep 597
http://www.n54tech.com/forums/showth...t=30236&page=4
I am using firmware 1.3 (odb2 upgrade). For it, the number is max boost. I don't know if the other (3.13) firmware for non-odb2 configuration is the same. Terry states 1st should be set to 15 and 2nd to 18. http://www.n54tech.com/forums/showth...t=30236&page=3 (post #65) |
06-28-2015, 07:14 AM | #16 |
4918
Rep 115,980
