03-30-2015, 07:00 AM | #1 |
2464
Rep 3,803
BMS OBDII CAN Module
Just received the module for the exhaust, active sound, halo brightness, gotta say, for the money it's spot on.
Although installation was confusing and difficult, took in access of 23 seconds to install, I'd recomend it to anyone that wants more control over these items. |
03-30-2015, 07:42 AM | #3 |
2464
Rep 3,803
Unsure. The only issue, which I've emailed them about is the lack of reference sheet. Awaiting reply.
The videos on their site, are nice enough but a but more written info is necessary, in my opinion. I'd like to have a single sheet, detailing what is done at each tach number, and the corresponding blinker action, for storage in the glovebox. |
03-31-2015, 09:00 AM | #6 |
General
12971
Rep 18,716
The BMS JB4 do actively clear CEL if you have a catless in the car.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
03-31-2015, 11:00 AM | #8 | |
247
Rep 616
Because clearing the fault code for emissions would only stay off until the factory computer runs its emission test for catalytic convertor. So if you had a CEL on for a engine sensor for example, the tool would reset that fault lamp and you would never know that you have more fault codes unless you took the time to actually scan your engine computer randomly ? |
03-31-2015, 01:08 PM | #9 | |
General
12971
Rep 18,716
Correct.
I had another check engine light issue on my F10 before and I got confused why since I have JB4 in the car. Then I check the code, it was for faulty thermostat. You may want to ask BMS for the exact way it works, but above is based on my experience.
04-02-2015, 12:03 AM | #10 | ||
BimmerPost Supporting Vendor
24199
Rep 190,807
You will still get an engine light if you had other issues with your car.
04-02-2015, 07:30 AM | #12 | |
329
Rep 483
Per Terry (BMS): "There is a code delete function but keep in mind removing emissions equipment is not legal unless you're talking about a competition race car used only in competitive events. Deleting the codes will NOT set readiness or anything like that." The JB4 (which is a tune, not a standalone module like the OBDII port CAN Flap module) used to have a DP fix add-on, but I don't think Terry sells it anymore after the CARB fiasco. However, it should auto-clear codes. Last edited by Dethsupp0rt; 04-02-2015 at 07:37 AM.. |
