03-17-2015, 06:04 PM | #1 |
10
Rep 99
front left tire temp higher than the rest?
I've noticed that my front left tire consistently runs 10-20 degrees (f) higher than the others at operating temperature. Do you guys get the same results on your cars?
Trying to figure out if this is due to engine heat or a potential alignment issue (although the car drives fine and doesn't seem to pull). |
03-17-2015, 09:58 PM | #2 |
38
Rep 69
I was just about to ask the same question, although it looks like in Seattle we run a little cooler overall.
I don't think it's an alignment issue either. Probably just a cooling system effect. There are a ton of heat exchangers up front there and I think there's one on that side for the DCT? |
03-30-2015, 11:10 PM | #4 |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Should make all the air pressures the same and check again.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
03-30-2015, 11:52 PM | #5 |
328
Rep 1,450
I noticed the same thing and bet most of us will.
Can't help but think this is due to the high temp water cooler being in front of this tire. I would think this could explain the difference assuming you have proper alignment. |
03-31-2015, 02:52 AM | #6 |
Executive Producer
22
Rep 370
Drives: '15 F82 M4 (YAS/Silverstone)
Same here and was wondering also... All pressures identical here. I've also done a reset and checked pressures again twice. Sensors say FL hotter. Between 4-12 degrees usually.
J Ryan
RETIRED: '86 e30 325e, '89 e30 M3, '02 330ci, '05 330ci ZHP, '07 e92 335i, '07 e92 335i, '12 e89 Z4 35is, '5 f82 M4 CURRENT: Porsche 911s |
03-31-2015, 09:38 AM | #7 |
1707
Rep 2,053
I'm not well versed in the technological side of tire cause/effect things, but might have a lead on this one. In looking back at the weight threads for F8x's just yesterday, I noticed that when cars are on corner scales the FL tire is consistently the one bearing the heaviest load. I'm not meaning by 10-20 lbs, either. The metrics I recall were something like 100+ lbs on the FL corner compared with the FR, and both I seem to remember being about 40-50 lbs higher than rear tire loads.
Could be the cause of the higher temps.
Moved to the darkside: '23 718 GT4; 11-10-2022.
Le Mans Blue F80 - Munich 5-22-2015 / US 7-7-2015 / SOLD 9-17-2022 ED RecapArctic Grey G05 - Spartanburg 8-29-2019 X5 PCD Recap |
04-03-2015, 12:01 AM | #8 | |
1385
Rep 3,834
Daily: G12 750 MSPORT Weekend Car: E90 M3
06-12-2015, 08:39 PM | #9 |
831
Rep 2,352
Drives: 16' BMW i8
Garage List 2001 BMW M3 E46 CON ... [9.50]
2016 BMW i8 [10.00] 2003 JEEP GRAND CHE ... [0.00] 2000 540i SPORT E39 [10.00] 2007 TOYOTA TACOMA ... [0.00] |
Just noticed this in my M4 a few nights ago and it's starting to bug me...
05-04-2018, 06:28 AM | #11 |
10
Rep 16
Hi all,
I also noticed this a few weeks ago in my F80 ZCP (MY2017; LH). I thought it was a tire-related issue but it's not, since I changed my winter wheels to the summer wheels and the issue was not solved. Temperature difference is approximately 3-4°C celsius. On the other hand, there is no significant difference in tire pressure. Hopefully more information soon. |
05-04-2018, 07:20 AM | #12 |
5394
Rep 3,737
Drives: 2016 M4 DCT Tanzanite/Amaro
geez, what a relief: I thought i was just too fat (LHD), and yes, I have the same observation to the same degree as everyone else.
05-05-2018, 12:55 PM | #15 |
1326
Rep 1,481
05-22-2018, 07:33 AM | #16 |
21
Rep 43
Incase anyone in this thread hasn't seen the other thread that has found the answer...
http://f80.bimmerpost.com/forums/sho...1278907&page=3
2013 BMW 135is Alpine White, DCT
2017 BMW M4 ZCP DCT (turned in) 2011 BMW 335i Manual (sold...enjoy kid!) 2006 BMW 330i Sedan Manual (Sold) 1992 BMW 325i Sedan (Sold) |
