03-14-2015, 06:59 PM | #1 |
29
Rep 243
jb4 install
For the guys who are installing the jb4 themselves what are you guys doing to gain access to the MAP sensor. please list the tools and any technique you are using. the space seems very tight
03-14-2015, 07:22 PM | #2 |
117
Rep 105
It's actually quite easy to remove the MAP (TMAP is the one with easy access) without removal of the overflow reservoir. You can pry up the clip a little with a flathead to make it easier but even that is not necessary.
03-14-2015, 07:26 PM | #3 |
29
Rep 243
03-14-2015, 08:08 PM | #4 |
216
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
I usually use a long right angle pick to get it out and if necessary a long needle nose pliers to get it back in. Takes me about 5 mins max to install stage one
LIVE FAST..DRIVE FASTER!! |
03-15-2015, 12:40 AM | #5 | |
311
Rep 645
Garage: 2015 991.1 GT3 | 2016 AMG GTS Sold | 2015 C7 Z06 Sold | 2015 M4 SO/6MT Sold
Instagram: M.Tonee |
03-15-2015, 10:37 AM | #7 |
29
Rep 243
how do you get the map sensor out. do you take the overflow reservoir out? thanks for the offer. I will try myself and if can't do it might need your help.
thanks |
03-16-2015, 02:57 PM | #9 | |
Gone Fishin’
7318
Rep 12,125
07-17-2015, 04:29 PM | #11 |
262
Rep 658
For the MAP plug are you all pushing the tab down or pulling the tab up to disconnect.
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
09-15-2015, 11:54 AM | #12 |
262
Rep 658
If there are Doctors here I used a long fine right angle to get to the Tmap. First install was over an hour without it. Just reinstalled in 10 minutes without touching the reservoir at all with this.
